what are u getting for MPG??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by onelifeoneride, Feb 4, 2008.
  1. Mar 17, 2008 at 4:00 AM
    #101
    shores11
    shores11 Member
    Dave
    Atlanta, GA
    2013 PreRunner TRD Sport
    Just filled up yesterday - getting 23+ mixed city/highway with the 4cyl, Prerunner Accesscab
  2. Mar 17, 2008 at 4:38 AM
    #102
    Mellow
    Mellow Well-Known Member
    Dallas, TX
    08 Ext Cab SR5 4-Cyl Prerunner
    With 1,500 miles on the clock, I'm steady at 21 mpg hwy, city or mixed.. LOL.. I thought I'd get a little better on the hwy, 23 at least but I've heard I'll get better mpg after the next few thousand miles.
  3. Mar 17, 2008 at 4:59 AM
    #103
    dwb
    dwb Well-Known Member
    Pine Mountain, GA
    05 Double Cab, TRD Sport/4X4, mostly stock with a few mods.
    Bilstein 5100's all around, 265/70/R17 BFG AT's, TRD seat covers, True Flow XDI Intake System. Fog light mod. More to come.
    I've owned my truck for 3 years now, and it's got 16,525 miles on it. I only drive it to and from work, Home Depot etc... Consistantly I get between 19-20 mpg city and have never checked a tank on the hwy. Air pressure is a huge factor in fuel mileage. Pump those puppies up tight and you will see the difference. I run 45psi front, and 40psi rear on my BFG AT's. If you run low pressures, you are creating drag. Also I would say the True Flow XDI has probably given me another mile per gallon at least. Hey, just be glad you drive a Toyota and not a Chevy, Ford, GMC or Dodge. Those guys are getting GPM not MPG. My 18 yr old nephew drives a 2002 GMC 2500 HD 4X4 (gas) lifted with 35's and gets about 8 mpg. :eek:
  4. Mar 17, 2008 at 5:09 AM
    #104
    cmfranks
    cmfranks Well-Known Member
    Craig
    Austin,TX
    08 DC Pre-Runner 6in Pro Comp Lift
    BHLM, Pro Comp Skid Plate, AFE Drop in Air Filter, Tint, Pioneer AVH 4000 DVD,Polk Audio 6.5 components, Polk 6.5 co-ax's, Polk Audio 400.1 amp, Polk Audio 500.1 amp, (2) Polk Audio 10 in Momo subs, Mr Marv sub box, Sockmonkey decals, Redline Elite hood struts, Bak Flip tonneau cover, N-Fab Nerf bars, Painted Center Console & Window/Door Lock Panels Black, Amber LED Dome/Map Lights
    so what pressure should i have for my 305's Pro Comp Xtreme A/T's for better MPG
  5. Mar 17, 2008 at 5:34 AM
    #105
    dwb
    Pine Mountain, GA
    Well my friend, that will depend on what size wheel you are running. Is it a stock width rim or a wider rim? Also, read the tire for it's max cold pressure, but don't use that, it's just an inflation maximun. On a tire your size and tread design, you want the entire tread area to sit as flat on the pavement as possible. If you go with too much pressure, you will wear out the center of the tire, too little and you wear out shoulders and get a cupped tread effect. It's a balancing act but not one that's too hard to figure out. Never run the same pressure front to back on a pickup truck. There is almost no weight on the rear as opposed to the weight on the front.
  6. Mar 17, 2008 at 5:38 AM
    #106
    cmfranks
    Craig
    Austin,TX
    Thanks,
    the rim size is 17x9 I believe the tires are 305x65x17's
  7. Mar 17, 2008 at 5:56 AM
    #107
    dwb
    Pine Mountain, GA
    Okay, your cold max pressure is probably something like 50 or 60 psi, it could even be 80psi cold....but don't go there.
    If I had those on my truck I would start with 45psi (front) and 40psi (rear). But it would be better to know the actual max pressure rating on the tire before you mess with them. That is a soft rubber compound tire, with a 6 ply tread and 3 ply sidewall. It's one bad ass tire, and you paid for them, so you want them to wear like a hogs nose.....
  8. Mar 17, 2008 at 6:03 AM
    #108
    dwb
    Pine Mountain, GA
    Sorry dude,:sorry: you have the Xtremes, and for some reason I was thinking you had the Xterrains. Anyway, you have a 40,000 mile tread wear warranty with those bad boys, and that's a huge plus.
  9. Mar 17, 2008 at 6:10 AM
    #109
    flavalk
    flavalk 2-Broke 2-Care
    Orlando, Florida via Huntsville, Alabama
    '07 PreRunner SR5 Double Cab 2WD - Short Bed - Automatic- Silver Mica
    Not much. Toyota bed mat, Toyota step bars, tinted windows, Toyota seat covers, Toyota all-weather mats, quart of Wild Turkey in the glove box, KelTec PT3AT in the center console, backseat full of old speeding tickets
    I get just over 18 mpg in town and anout 21 on the highway. I ONLY use 87 octane fuel because that is what the manufacturer specifies. Higher octane is a waste of $$$ and you get zero benifit from it.
  10. Mar 17, 2008 at 6:24 AM
    #110
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    Uh oh, I sense and ass-whuppin' comin' on!! I don't disagree with you, think that putting higher octane gas in a car/truck which specifies 87 is unnecessary, and I said so in another thread and got dog-piled!! But I'm a no0b here and didn't realize that this is a touchy and controversial subject.
  11. Mar 17, 2008 at 7:02 AM
    #111
    flavalk
    Ain't skeered :lalala:. The truth will set you free :D http://autorepair.about.com/od/generalinfo/a/aa060504a.htm
    There is tons of info to supporting this fact
  12. Mar 17, 2008 at 7:52 AM
    #112
    dwb
    Pine Mountain, GA
    I always thought it was a no-brainer that higher octane gas does NOT give you better mileage, in an engine that does not require it, such as the Toyota trucks we all drive. You are absolutely throwing your $ out the window if you use high octane fuel in a Tacoma with a stock motor.
    WOW....I can't even imagine doing that.......:der:
  13. Mar 17, 2008 at 8:22 AM
    #113
    HardCase
    Robert
    Kalispell, Montana
  14. Mar 17, 2008 at 9:29 AM
    #114
    gsxr3000
    gsxr3000 Well-Known Member
    08 TRD Sport
    OME Lift Kit, TRD S/C CAI EXHAUST
    dumped a bunch of highway miles on the truck this weekend... avg 17 mpg with 93 octane fuel. my wife has a prius, so whatever fuel i waste - she saves for me.
  15. Mar 17, 2008 at 9:37 AM
    #115
    HardCase
    Robert
    Kalispell, Montana
    Eeeeooowww! We don't even have 93 octane reasonably available around here, our "premium" is 91, mid-grade is 89 and regular is 87.
    How does your wife like her Prius? Most people who own them love them.
  16. Mar 17, 2008 at 9:45 AM
    #116
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    My understanding is that the 2nd gen. V6 Tacomas compression ratio is right on the border for needing the higher octane. It's even mentioned in the owners manual that 87 is a recommended grade but 91 will give higher performance. That's been backed up by some of the owners here at TacomaWorld.
  17. Mar 18, 2008 at 5:19 AM
    #117
    gsxr3000
    08 TRD Sport
    Wifey loves her Prius... shocking, but it has great pickup and the package she chose has just about the same whistles and bells as my mom's lexus.
  18. Mar 18, 2008 at 6:12 AM
    #118
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Fellow aviators:
    Echo Tango Alpha checking in, 3 miles southeast of Seal Beach VOR, requesting the ILS to LGB
    :bananadance:
    My 99 taco gets about 16-17 avg. I keep a precise log of my mileage. I hope to do a little better in the new taco to be. So many electronic gadgets I want to get and scan gauge is one. Wish they made it to blend a bit better with the dash/looks of the new tacos, it looks like it could be standard in the 99. Will report back with data.
  19. Mar 18, 2008 at 6:39 AM
    #119
    dwb
    Pine Mountain, GA
    Delta Whiskey Bravo responding to Echo Tango Alpha; what the hell is ILS and LGB? :confused:
  20. Mar 18, 2008 at 7:26 AM
    #120
    gsxr3000
    08 TRD Sport
    ILS = instrument landing system - used during IMS under IFR operations
    LGB = Long Beach / Daugherty Field - Long Beach, CA
    my mother wanted me to be a pilot, but my father misunderstood and now I'm a pirate.
