What are you looking for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fire931, Mar 2, 2009.
  1. Mar 2, 2009 at 7:19 PM
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    ok so i'm getting ready to go into production with a very similar design to the rear bumper thats on my truck right now. but i am curious what is everybody looking for that they cant seem to find? for the time being i will only be fabricating things in plate but i will soon add tube as well. my ideas as of right now for the tacoma are rear bumpers, shock mount skids, possibly bed bar, possibly sliders, front hidden reciever. any ideas are appreciated. :D
  2. Mar 2, 2009 at 7:23 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    How about filler plates for under the taillights? When you remove the stock bumper, there is a huge space under the taillights, which looks hella ugly if you wanna use pre-runner style rear-bumpers. I would love to have some bolt in filler panels that i can paint match to my truck, so there is no gap when i install my new bumper.
  3. Mar 2, 2009 at 7:26 PM
    Fire931
    VA
    00 4Runner
    good idea... my only problem designing that is i no longer have the lower bedsides on my truck for mockup..
  4. Mar 2, 2009 at 7:35 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Where in Virginia would you be working from?
  5. Mar 2, 2009 at 7:37 PM
    Fire931
    VA
    00 4Runner
    Lexington
  6. Mar 3, 2009 at 6:37 AM
    Fire931
    VA
    00 4Runner
    a bolt on replacement bumper is planned, however it will take a little while longer being as though i cannot mock it up off my truck anymore. as far as the tire carrier, are you referring to a regular tire carrier that holds it vertical behind the tailgate?
  7. Mar 3, 2009 at 8:06 AM
    Fire931
    VA
    00 4Runner
    really... no input??
  8. Mar 3, 2009 at 9:14 AM
    ERdept
    ERdept Well-Known Member
    Light but strong. I want the toughness, but not the weight.
  9. Mar 3, 2009 at 9:18 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I say do that rear bumper, I personally like the style, and finding one like that is hard.
    If you were to start fabbing them as an bolt on affair, I am good to go in purchasing one.
    Already has the wife's thumbs up.
  10. Mar 3, 2009 at 10:40 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    i'm looking for a rear bumper that doesn't require factory hitch removal.
  11. Mar 3, 2009 at 12:58 PM
    Fire931
    VA
    00 4Runner
    as for the tire carrier, that is no problem. my only issue right now is that my truck no longer has the lower section of the bedsides obviously, so i will have to have a guinea pig before i can fab up a direct replacement bumper. as for the hitch, i want to make a version that will allow you to keep the factory tow hitch as well as one that integrates a hitch into it.
    keep the ideas comming guys!! the more ideas i get the more stuff i can produce!
  12. Mar 3, 2009 at 1:11 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    i am also looking for a tire carrier that goes in the bed, not at the end, but want to be able to use the rearview mirror at the same time. 4 wheel parts has them but i don't buy from them.
  13. Mar 3, 2009 at 1:22 PM
    Kicker_Of_Elves
    Kicker_Of_Elves If it bleeds we can kill it
    USA
    08 Tacoma Access Cab TRD Off Road
    Front Skid Plate, Exhaust Tip, Tinted Windows: 35% Front Sides, 5% Rear Windows, Devil Horns Emblem, Rear TSB, BLHM, Shorty Antenna, 6000k HID Headlights.
    Can you fab some sliders similiar to AllPro's kickout ones?
  14. Mar 3, 2009 at 1:45 PM
    Fire931
    VA
    00 4Runner
    i will be able to in the future. i havnt pulled the trigger on a tubing bender yet, had to decide between that and a plasma cutter, i chose the cutter first. :D
  15. Mar 3, 2009 at 1:46 PM
    Fire931
    VA
    00 4Runner
    not exactly sure i'm following you on this one. you want a carrier that bolts to the inside of the bed? holds the tire horizontal, angled, or vertical?
  16. Mar 3, 2009 at 5:50 PM
    bajamoon
    STEVE
    Whittier
  17. Mar 3, 2009 at 6:25 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    what am i lookin for?
    Super model, my house, now. But its not happening for some reason.
  18. Mar 3, 2009 at 6:25 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    oh yeah - and an overhead temp/compass
  19. Mar 3, 2009 at 6:48 PM
    chabro
    chabro Well-Known Member
    Houston
    2011 SR5 4x4 DC
    Any chance of doing a rear plate bumper for 1st gens?
  20. Mar 3, 2009 at 8:16 PM
    Fire931
    VA
    00 4Runner
    theres always that possibility.
