What are you paying for 2020 Tacomas?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jet Jock, Oct 1, 2019.
  1. Sep 23, 2020 at 4:18 PM
    #6141
    Offroadr
    Offroadr Well-Known Member
    Thanks again for the info, I’ll send that pic to the salesman to see if he can double check before I drive up there.
    If it goes through the radiator, isn’t that cooling the trans fluid?
    I like the idea of the aftermarket cooler, but a main reason I’m buying a new truck is to have everything under warranty. I’d hate to give the dealer/Toyota a reason to say it’s not covered under warranty should something fail like the transmission
    I have a tendency to get a different truck every couple of years, wonder if this is a concern if I plan to sell the truck prior to the end of the warranty... I assume if the trans got hot and failed I’d be covered as long as I’m towing under the GVWR/Towing capacity..?
  2. Sep 23, 2020 at 7:26 PM
    #6142
    BajaBornTaco
    BajaBornTaco Well-Known Member
    Sold: '19 TRD OR - It will always be in my heart.
    It passes through the (main) radiator? Not sure how that would work. The radiator has water and anti-freeze, the transmission has ATF, those two would not be good to mix together. The article that was linked earlier says that in the Tundra, Toyota is using a synthetic oil that withstands higher temperatures. They may be doing the same in the Tacoma.
  3. Sep 23, 2020 at 7:28 PM
    #6143
    dave.h
    dave.h Well-Known Member
    SLC Utah
    2020 TRD Off Road DCLB
    technically yes- the transmission is being cooled by the radiator— but I suppose most would say that is only so efficient (and typical for non-towing applications). I think what it really comes down to is that Toyota has lowered the quality of their tow package and arguably th e capability but not the price wo th in the same model year. If you’re not towing significantly and not in high temps/significant climbs it may be a non issue beyond principle/transparency. I think scan guage is a great tool so I would say it’s a wonderful truck—maybe bring it up and try to reduce selling price, and add something that you can monitor your temps so you can just make sure you stay within normal ranges—. Main reason I bring it to this forum is bc I know for some people this will be a surprise after they buy. Good luck!
  4. Sep 23, 2020 at 7:35 PM
    #6144
    dave.h
    SLC Utah
    most standard vehicle radiators have separate plumbing inside for the coolant and for the trans fluid (So both fluids are separate but cooler via the radiator)— I’m honestly not familiar w the Tacoma’s that don’t have the aux trans cooler but that’s what I’ve read. I have to be honest I’m no expert on this but in my mind even if the atf can run at higher temps I still think higher heat on the transmission could decrease longevity (mainly bc higher heat not only can impact the atf fluid itself but the transmission seals, parts, etc).....so sure perhaps th e fluid can operate at higher temps but I’d be careful about the trans temps over 200 ....again for some people this may be a non issue- just throwing into the mix as you all are negotiating. Good luck!
  5. Sep 23, 2020 at 7:37 PM
    #6145
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
  6. Sep 23, 2020 at 8:04 PM
    #6146
    Offroadr
    I’m sure they are super simple to install but the whole point of a new truck to me is to have warranty on everything that’s not wearable (tires,shocks,etc). I could see the dealer or Toyota saying, the aux cooler must of failed and caused the transmission to fail so we’re not going to cover it because it’s been modified
  7. Sep 23, 2020 at 8:13 PM
    #6147
    Bleep100
    17 Sport
    I posted that for the guy who didnt understand how the ATF went through the radiator . I should have quoted him , have a good one .
    Offroadr[QUOTED] likes this.
  8. Sep 23, 2020 at 8:31 PM
    #6148
    BajaBornTaco
    I think you are referring to me. I didn't realize that the ATF cooler was in addition to it going through the regular radiator. That would make sense then that it would be easy to add an ATF cooler and for Toyota to easily omit it.
    Bleep100[QUOTED] likes this.
  9. Sep 24, 2020 at 9:49 AM
    #6149
    Offroadr
    To clarify, is the aux cooler infront of the radiator (meaning closer to the grill) or behind the radiator (closing to the engine)?
    Per your picture, it almost looks like the aux cooler is behind the radiator
  10. Sep 24, 2020 at 10:05 AM
    #6150
    thesoonerkid
    thesoonerkid Well-Known Member
    2020 Army Green Tacoma TRD Pro
    Autonation? Hello fellow las vegan.
  11. Sep 24, 2020 at 12:09 PM
    #6151
    dave.h
    SLC Utah
    The aux trans cooler is in front Of the radiator (that picture is oriented so that the front bumper/grill is to the right, and the radiator/engine bay to the left; I’m standing in front of the passenger front wheel looking down).
  12. Sep 24, 2020 at 6:31 PM
    #6152
    TheChanTaco
    TheChanTaco Well-Known Member
    Hi all, I am looking for a 2021 TRD OR DCSB with Technology pack only (i do not want to have any other factory add-ons).
    However, do I only have a choice between $1000 rebate or 1.9% interest rate if I want to finance thru Toyota?
  13. Sep 24, 2020 at 6:48 PM
    #6153
    kgs499
    kgs499 Member
    2021 Tacoma Sport Access MT
    As far as I know current Toyota incentives only include 2020 Tacomas.
  14. Sep 24, 2020 at 6:54 PM
    #6154
    TheChanTaco
    thank you. for the same question, for 2020, would I only be able to pick the cash rebate or 1.9%?
  15. Sep 24, 2020 at 7:02 PM
    #6155
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Yes, one or the other.
    deusxanime likes this.
  16. Sep 24, 2020 at 7:26 PM
    #6156
    kgs499
    kgs499 Member
    Old quotes I saw prior to proceeding with a 2021 included both the $1000 rebate and the offer of 1.9% interest. At least, the few dealers I spoke to made it seem that way.
  17. Sep 25, 2020 at 5:28 AM
    #6157
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Is there a 2021 "Tacoma Buying & Pricing" thread yet ?
  18. Sep 25, 2020 at 6:17 AM
    #6158
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
    SOSHeloPilot[QUOTED] likes this.
  19. Sep 25, 2020 at 6:25 AM
    #6159
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    The lower rates might make a come back. Inventory seems to be up, and I think sales are down, and that trend could continue.
  20. Sep 25, 2020 at 6:41 AM
    #6160
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    This tells me why my dealership is even entertaining my email and my lowball offer yesterday :D
