What are your most useful specialty tools working on a 20 yo truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Aug 20, 2022.
  1. Aug 20, 2022 at 6:26 PM
    5efvz
    5efvz [OP] Well-Known Member
    After my last thread "[Help] Removing crankshaft bolt." where a 1 day job turned into a 5 day job because I had to order a special tool to get out a pulley that isn't budging because I need to get to the belt to replace it, I thought I'd make this thread.
    Specialty tools would be those outside of sockets, wrenches, drivers, etc.
    These would be tools where nothing else would do, even though you might only use it 5% of the time.
    Like a harmonic balancer removal tool. Or a feeler gauge.
  2. Aug 20, 2022 at 6:28 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I made a tool for doing the rear axle seals, specifically for removing the ABS reluctor and spacer rings.
    Beyond that don't know that I'd call any of my other tools "special".
    5efvz[OP] likes this.
  3. Aug 20, 2022 at 6:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    All my tools are special, because they're mine. :D
    otis24, SpokeWench, Bivouac and 3 others like this.
  4. Aug 20, 2022 at 6:49 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    My pickle fork has come in useful a handful of times.
    5efvz[OP] and Key-Rei like this.
  5. Aug 20, 2022 at 6:52 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Welder :burp:
    5efvz[OP], Tour991 and Key-Rei like this.
  6. Aug 20, 2022 at 6:55 PM
    0xDEADBEEF
    On a more serious note, the permanently attached spark plug socket + extension combo is amazing on the 3rz.
    Other than that, I haven't needed much special - usually its so buggered that I can use a universal tool (such as a sawzall).
  7. Aug 20, 2022 at 8:15 PM
    5efvz
    I superglued the rubber boot in the spark plug socket so it doesn't get left behind stuck to the sparkplug.
    JPinFL and Stuck in VT like this.
  8. Aug 20, 2022 at 8:27 PM
    0xDEADBEEF
    i always had trouble with the extension pulling out of the spark plug socket.
  9. Aug 20, 2022 at 10:33 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I always wrap a little electricians tape around the extension and spark plug socket to prevent this from happening.
  10. Aug 20, 2022 at 11:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Brake line clamps come in handy to hold the timing belt onto the cam sprockets when setting it up
    Yes a harmonic balancer puller is required sometimes, no way around it
    But thats the good thing about toyotas, you don't really need many specialty tools to work on them
    oldtimertoyota and 5efvz[OP] like this.
  11. Aug 20, 2022 at 11:30 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I literally have never used one of those and I currently have 5 1st gens.
  12. Aug 20, 2022 at 11:47 PM
    Five
    Five Well-Known Member
    People with manual windows would know the struggle. Worth every bit of the $7 or so.
  13. Aug 21, 2022 at 3:38 AM
    5efvz
    I got mine out with a hook/pick but scratched the door panel.
  14. Aug 21, 2022 at 5:31 AM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    I have crank windows, the (cloth) shop towel trick works great on getting the clips off, rotate handle to point open end of clip up, hold towel tight with both hands wiggle while pushing down between panel and handle the clip pops off and lands in door pocket. I think it’s somewhere on the internet.
    JPinFL likes this.
  15. Aug 21, 2022 at 5:55 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I use my car keys, once used a broken sawzall blade I found while in the junk yard.
  16. Aug 21, 2022 at 7:55 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I've gotten a lot of use out of my MityVac hand pump for changing brake fluid and power steering fluid. It's not strictly a required tool, but it's great if you work alone.
  17. Aug 21, 2022 at 8:42 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    3 lb sledgehammer is the most useful tool you can own.
    joeyv141 likes this.
  18. Aug 21, 2022 at 8:44 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    20 years old? Gas ax or induction heater.
    ''If it ain't welded now, it will be in 20 years'' is a Michigan thing.
    Bivouac likes this.
  19. Aug 21, 2022 at 9:22 AM
    0xDEADBEEF
    Yeah I think I tried that once, it was too hot and the tape was gooey :/
  20. Aug 21, 2022 at 9:44 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    few of my favorite things......
