What ATF do you use, and why?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tan4x4, Oct 8, 2015.
  1. Oct 8, 2015 at 8:06 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I put in valvoline last time, next time I will be going with amsoil
  2. Oct 8, 2015 at 8:49 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Factory issue, these transmissions are wickedly expensive to deviate from factory fill. Oddly enough Toyota doesn't even recommend changing it? I did anyway cause it looked a little brown. It takes nearly 4 quarts not two like the manual states. There's no filter to speak of, just a screen to rinse out if you choose to do so.
  3. Oct 8, 2015 at 11:22 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    Just to get a feel for different brands? Or did you have a bad experience with it?
  4. Oct 8, 2015 at 11:58 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Mine started to fail shortly after my first drain and fill...
    The guy who rebuilt my tranny said to use max life. Before this I went to the dealer and they told me to go to Napa and get any dextron III.
  5. Oct 9, 2015 at 3:57 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Amsoil is highly recommended as its been proven to give a boost of 20hp, let you drive up Mt. Everest, and add both length AND girth.
    ancient11 likes this.
  6. Oct 9, 2015 at 4:35 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Dex 2 & 3 are not Toyota type 4 compatible. But the newer Dex 6 states it is compatible with Toyota type 4. I have only ever used type 4 for two drain and fills and have no issues as I approach the 200000 mile mark. Bogh those drain and fills were done around 160000 miles and made a big difference in shifting. There have been numerous people on here that have used Dex 2-3 and have experienced slipping in the past.
  7. Oct 9, 2015 at 5:46 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I work at a GM parts dept and can tell you that Dexron VI is backwards compatible with Dexron III in automatic transmissions. In fact GM doesn't even sell or license Dexron III anymore. However, it is not backwards compatible in some transfer cases and manual transmissions that originally used Dexron III. For those applications we have a different fluid with the very original name of Manual transmission and transfer case fluid.
  8. Oct 9, 2015 at 6:09 AM
    TACO TX
    Kelly
    Denison ,Texas
  9. Oct 9, 2015 at 10:09 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I use Valvoline max life full synthetic, simply because its the only full synthetic they sell around here that also came in gallon sizes so I could do a full system flush.
  10. Oct 9, 2015 at 10:12 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I use the tears of my enemies.
  11. Oct 9, 2015 at 10:27 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ramonortiz55 was asking about full flushes. If your trans failed after a drain and fill, it would be for one of these reasons:
    • Transmission was already on its last legs.
    • Fluid level was off by a gross amount.
    • Rare bad reaction between two different brands of fluid - both fluids claim to meet Dexron III performance requirements, but chemically different and the additives worked against each other. To prevent this, either be sure to refill with the same brand as previous, or do a full flush. :)
    Max Life is a good fluid that's claimed to meet almost all the import-vehicle specs in common use (Dexron III, Toyota T-IV, Toyota WS...). The guy who rebuilt your trans might prefer it simply because it reduces the number of fluid types he has to stock. And if you use Max Life in subsequent fills, you avoid the mixing issues.
  12. Oct 9, 2015 at 1:19 PM
    bellassaiw10
    Currituck NC
    I've ran amsoil in my truck for oil for a while now and now I'm a dealer so I'm gonna flush and refill
  13. Oct 10, 2015 at 7:09 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Many carmakers re-brand their own flavor of whatever the current version of DEXRON is available for license from GM. This is what T-IV and WS from Toyota are.
    DEXRON VI is a synthetic and it's better than any previous DEXRON, which is why it supersedes them and why GM doesn't even license the earlier ones anymore.
    And so any other brand besides GM, such as Valvoline MaxLife that specs out to DEXRON VI is just as good.
    Fresh DEXRON III/IV is better than nothing, but it's certainly not "better" for an older vehicle simply because it "matches" what came with it.
    NAAC3TACO likes this.
  14. Oct 11, 2015 at 5:53 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Because people don't go in for trans service usually till they have a problem. They get a flush and shortly after they have failure it was coming either with or without the flush..
  15. Oct 11, 2015 at 6:06 PM
    #35
    TACO TX
    Kelly
    Denison ,Texas
    It mostly depends on what kind of flush. Any type that pulls the fluid out of the transmission vs pushing it out is bad. The best way is to pull a return line or just do regular drain and fills.
  16. Oct 21, 2015 at 12:59 AM
    #36
    skidrow
    skidrow Well-Known Member
    robert
    2002 double cab 4x4
    Bilstine adjustable 3" front--add leaf rear--skid row plates +
    Im more confused now..... i whent to the dealer they told me to just use dex lll was using toyota lV now i dont know what the hell to use and dont want to lose a trany over a simple mistake..... so is the Valvoline synthetic the one i should switch over to???? I just do drain and refills about 2x a year with about 190k miles. HELP!!!!!
  17. Oct 21, 2015 at 3:24 AM
    #37
    Caligula
    Los Angeles, CA
    T-IV is Toyota's version of DEXRON III !!!111!!1!!!!!!111!!!!!
    I sympathize with your confusion. So many here jockeying for the brand of fluid that they would lay down their lives for. Like i said before, it turned into a religious argument.
    The truck calls for Dexron II/III, so use Dexron II/III. If you go to the dealer for the fluid change, they will use T-IV. If you want to kick it up a notch, go with any high end synthetic fluid thats compatible for $12/quart. It wont change anything.
    skidrow[QUOTED] likes this.
  18. Oct 21, 2015 at 5:48 AM
    #38
    deckeda
    As Caligula (and me, I think?) said, don't think of them as different fluids so much as good enough vs. better fluids. The confusion lies in the fact that everyone is striving for greater longevity today --- where possible --- and ultimately ya gotta have something better than DEX III/IV for that.
    Would it matter to an old transmission with nearly 200K on the clock? Probably not, especially if you're already in the habit of regularly swapping out at least some of the fluid each year. :)
  19. Oct 21, 2015 at 8:50 AM
    #39
    skidrow
    robert
    2002 double cab 4x4
    Ok thanks guys im going to just use up the rest of the 2 gallons of standard Valvoline Dex 3 then I'll just switch back to Toyota IV im about to hit 200k miles and never any kind of trans issues what what ive been doing
  20. Oct 28, 2015 at 2:49 PM
    #40
    Mischief
    Mischief misadventurer
    Christi
    Duke City NM
    2004 Tacoma crewcab TRD
    I drained and filled mine today, I drained almost 4 qts and it took a little over 4 to bring it back up to where the dipstick indicated. What's up with the owner's manual stating it only takes 2? The toyota dealer parts guy looked for a while then told me there was no filter to replace but the haynes manual that I have states to replace it. I hate haynes manuals, they want to give all sorts of generic info then tell me how to overhaul my engine. Why can't they actually include info that I can use? :notsure:
