What ATF do you use, and why?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tan4x4, Oct 8, 2015.
  1. Oct 29, 2015 at 8:44 AM
    #41
    Voyager
    Voyager Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    Last time I did a drain and fill, I went out on a ledge and used the exact same stuff that was in there...OEM Toyota Type T-IV fluid. Seriously, a safe bet is to use what your Toyota owners manual says to use.
    I did approx. 4.5 qts, but have an aftermarket B&M transmission cooler (70268).
    NAAC3TACO likes this.
  2. Oct 29, 2015 at 3:49 PM
    #42
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Amsoil Universal ATF is what I use. Usually do 30K drain and fills. This last time I went 60K and still looked pretty good. A year ago I bypassed the radiator cooler and installed a tru cool 4454. Normal driving my temps get no higher than 180.
  3. Mar 10, 2016 at 8:29 AM
    #43
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    AND GIRTH!!!!!
    Sign me up.
  4. Mar 11, 2016 at 6:35 AM
    #44
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    I used Valvoline Max Life when I did the service on mine. Its what we have in bulk here at the shop. I did drop the pan and change the filter too. it's an 01 V6 so may be a different tranny to those that are stating they dont have a filter
  5. Mar 11, 2016 at 7:35 AM
    #45
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I use max life atf because it's compatible with my transmission, synthetic, and inexpensive. Plus it's readily available in the 4qt hugs for $17 at Walmart
  6. Jun 27, 2021 at 7:58 AM
    #46
    tmross
    tmross Well-Known Member
    2002 Tacoma 2.4L 2wd Reg Cab
    Thinking about doing a drain and fill today, dipstick says use Dexron II. I see Dexron VI is compatible with II, but lots of people here use the valvoline maxlife, any real difference between the valvoline dexron VI and maxlife? Any recommendations? This fluid hasn't been changed on my watch (65k miles), its pretty brown and burnt.
  7. Jun 27, 2021 at 8:33 AM
    #47
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Dexron VI is backwards compatible with Dexron II and III, however is is a full synthetic lower viscosity fluid. It will probably work fine in your transmission. I know we use it in older GM transmissions at the Chevy dealer I work at with no issues at all. Valvoline Maxlife is also a full synthetic fluid, but I think it is closer in viscosity to the original fluid. That’s what I would use. JMO.
  8. Jun 27, 2021 at 9:31 AM
    #48
    tmross
    Ok, and curious what is the definitive correct fluid to use, considering dexron II doesn't exist anymore... I guess I could call the dealership tmrw and see what they'd use for an 02 2.4L. I've read like 10 threads here on this subject and frankly have more questions than answers now lol.
  9. Jun 27, 2021 at 12:00 PM
    #49
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Not a bad idea.
  10. Jul 2, 2021 at 10:29 AM
    #50
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    As phrased, it's an impossible solution if the only defined fluid is no longer available ... so what you're needing is indeed a replacement.
    For what it's worth I also run MaxLife in my 2004 DoubleCab and it's great. But I also use an external trans cooler, and if your fluid is brown and burnt in your 65K miles you should consider one as well; you're hitting it pretty hard it sounds like.
  11. Jul 2, 2021 at 11:59 AM
    #51
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Ditto
  12. Jul 2, 2021 at 12:52 PM
    #52
    tmross
    By that I meant what would Toyota use if they serviced it, and I called the dealership today and they said Toyota T-IV.
    A local veteran Toyota specialist recommended Mobil 1 Synthetic ATF.
