What axle ratio do 2015 4 cylinder 4x4 manuals come with?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBecker, Feb 14, 2015.
  1. Feb 14, 2015 at 3:08 PM
    JBecker
    JBecker [OP] Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Title says it all. Curious what axle ratio comes standard in the 2015 2.7 4x4 manual trans trucks? Specifically the SR package if it makes a difference.
    I've ordered mine but it's not in yet and I seem to be unable to find that info on the Toyota website. Also I understand it comes with a limited slip differential. Is it a normal LSD or one of those types that uses the braking system to operate? Thanks in advance.
  2. Feb 14, 2015 at 3:18 PM
    JBecker
    Virginia
    Well I guess I found the info. I was looking under the wrong section. They list the axle ratio as 4.1 on the manual transmission and the diff is an auto LSD.
  3. Feb 14, 2015 at 5:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    all the 6 lug 4cylinder trucks come with 4.10 axles.
    trucks 2009+ do not have mechanical LSD's any more, they have brake actuated "LSD"
  4. Feb 14, 2015 at 5:57 PM
    JBecker
    Virginia
    Thanks for the info on the diff and confirming the axle ratio.
