What backspace should I get?
Discussion in 'Wheels & Tires' started by firefighter3224, Apr 23, 2010.
  1. Apr 23, 2010 at 9:35 PM
    firefighter3224
    firefighter3224 [OP] New Member
    Clay
    Gastonia, NC
    2010 SR5 4x4
    3" lift, bed storage box lock mod
    Im new to the forum and I am beefing up my Taco some but I am not sure about the wheels I am looking at.
    I have a 2010 DC and I got a 3 inch lift on it, and I am wanting to put 285/75/16's and new wheels on it and the wheel I am looking at has a 4.5 backspace will It fit or do I need to get a different backspace on it to keep it from rubbing to where I have to do more than cut the fender wells?
  2. Apr 23, 2010 at 9:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! That BS will work, but you will still need to trim a little bit with that size tire.
  3. Apr 23, 2010 at 9:44 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    4.5 sticks out a little bit giving it a more of an aggressive stance.
  4. May 8, 2010 at 2:07 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    just to bring this thread back, i have the same question and want to run the exact same thing. what offset should i run with 4.5 backspacing?
  5. May 8, 2010 at 2:16 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    4.5 BS with a 0 offset should work... I just ordered some AR Tactic 16x8's for $540 OTD!
    - Rich
  6. May 8, 2010 at 2:29 PM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    will 0 offset stick out any? or should i get a -12 offset? i've heard good thing about -12 but im gonna ask
  7. May 8, 2010 at 2:44 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    Haha aint this a good thread. Ive always wondered if its better to stick with positive offset or go with 0 or negative offset.
  8. May 8, 2010 at 3:10 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    A -12mm 4.5 bs wheel is usually 9 inches wide. where as a 0mm 4.5bs wheel is 8" wide. the -12mm will stick out farther than the 0mm. Both will work for what your wanting. but the 0mm may require a little less trimming.
