What backspacing do I need?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBTWENTYTWO, May 6, 2014.
  1. May 6, 2014 at 7:12 PM
    JBTWENTYTWO
    JBTWENTYTWO [OP] Well-Known Member
    2011 Prerunner
    Cooper Discover STT tires 285/70/R17 (33s) Procomp 7032 matte black wheels 17x9 -6 offset. Front lift: Bilstein 5100 Adjustable Shocks set at 0. OME 885x coils. Rear lift: Bilstein 5100 shocks. 1.5 inch 3 leaf progressive. I still have stock UCAs but plan on getting aftermarket ones later. I ordered the shocks and coils from headstrong offroad and the 1.5 inch 3 leaf progressive from Wheelers Offroad. 50" Radius Light bar (From Sidetracked Offroad) Mounts from Relentless Fabrication.
    I'm going to be putting on the 3" OME lift here shortly as well as new tire and wheels. I'm uncertain what backspacing I'm gonna need. I'm gonna be running 285/70/R17 Cooper Discoverer STT tires and 17x9 Procomp 7032 wheels
  2. May 6, 2014 at 8:44 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If those are the wheels you're going with, I don't think you have a choice. They are only offered with 4.75" back space.
  3. May 7, 2014 at 6:30 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Really cutting it close on stock UCA's with a 4.75" BS. Ideally, 4.25-4.5" of BS will work but 4.75" will probably rub. You can always get 1/2" spacers if needed or do a test fit if possible.
  4. May 16, 2014 at 7:35 AM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Dude you have to post pictures on TW once your all installed maybe some front and rear shots. I have the 3inch OME and Pro Comp 7089's as well. Have you ever though of 255/80/17 its 1inch narrower than the 285's which will be better on fuel, maybe acceleration, and better for snow. I already have the Nitto Terra Grapplers in the 285's and wanna try another tread. The Cooper Discoverer S/T Maxx look sick i cant wait to get them. Also the 255's are $216 and the 285's are $262
    Discount Tire Prices for Cooper Discoverer S/T Maxx
    255's = $864 not mounted and balanced
    285's= $1048 not mounted and balanced
    Difference in price is $184
  5. May 16, 2014 at 7:40 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Not sure what BS those wheels come in but with 33"s, 4.5" BS is pretty much standard or a -12MM offset.
