What backup cameras do you use?
Discussion in 'Audio & Video' started by Burner1061, Jun 20, 2021.
  1. Jun 20, 2021 at 12:12 AM
    Burner1061
    Burner1061 [OP] Active Member
  2. Jun 20, 2021 at 1:07 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    I use the one that come in the truck. Why would you want to change the stock one ?
  3. Jun 20, 2021 at 3:22 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    He said "add" one so maybe the truck didn't have one originally?
    If it does have a OEM backup camera, I would use that.
    I added one to my base model truck and I bought a Toyota one.
  4. Jun 20, 2021 at 3:23 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  5. Jun 20, 2021 at 8:14 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    It appears to be an 06 based off his profile info and they didn’t come with cameras then
  6. Jun 20, 2021 at 9:19 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I used dozens of them from tailgate camera . com. Good quality, come built into the handle, etc.
    I will say that the biggest factor will be your install. Solder, heat shrink, use grommets and loom, run the wire as protected as you can get it. Nearly every aftermarket camera failure I’ve ever seen was actually an install failure, not a product failure.
    soundman98 likes this.
  7. Jun 20, 2021 at 10:29 AM
    Burner1061
    Nope I don't currently have one. It's a 2006
  8. Jun 21, 2021 at 1:39 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    First thing is you need to see if your truck has the plug at the bottom of the tailgate for the camera. Mine did but I had to buy the camera and the small harness that's inside the tailgate.
  9. Jun 26, 2021 at 5:38 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I have an '06.
    I use the original cameras that came with me. I turn around and LOOK.
    You'd be surprised what a camera doesn't see.
    Larzzzz likes this.
  10. Jun 29, 2021 at 1:23 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Try this: in a comfortable driving position, tilt your ear down to your shoulder. Then adjust the mirror so the body line is just coming into the mirror.
    The way it worked out for me was that when the car behind me was leaving my rear view mirror it was coming into the side mirrors. By the time it left the side mirror, it is beside me and I can see it.
  11. Jun 29, 2021 at 11:40 PM
    Burner1061
    Since I'm upgrading the head unit I was going to use the camera input since I have the option. It's not like I NEED it but it's a cool gimmick that might come in handy sometimes.
  12. Jun 30, 2021 at 1:26 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
