What batteries are compatible with this electric bike?
Discussion in 'Off-Topic Discussion' started by Cutter_, Jun 20, 2019.
  1. Jun 20, 2019 at 8:18 PM
    Cutter_
    Cutter_ [OP] Well-Known Member
    '02 5VZ PreRunner
  2. Jun 20, 2019 at 8:33 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Lifted on 275/70/17
    The biggest difference is the 48v is Lithium ion. A much better batter. The 12v are lead acid. Both will work if you use 4-12v but I think the li-ion will last longer.
    Cutter_ [OP] likes this.
  3. Jun 20, 2019 at 8:36 PM
    Cutter_
    '02 5VZ PreRunner
    Can I use the 12v lead acid batteries on the 48v conversion kit?
  4. Jun 20, 2019 at 8:47 PM
    20tacoma17
    2017 DCLB Sport AT
    Lifted on 275/70/17
    That kit says it requires no less than 11.6AH. The 12v batteries are rated at 12AH so it would be close if the batteries are accurate. Golf carts use mostly lead acid batteries so I dont see why not. However you may want 12v batteries closer to 14-15AH. I would get ahold of Batteries plus to find out the best options for longevity and best range. I know a little but not an expert. :hattip:
