What bolt is this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Petrinj2003, Sep 9, 2024.
  1. Sep 9, 2024 at 5:04 PM
    Petrinj2003
    Petrinj2003 [OP] New Member
    Joshua
    2nd gen Tacoma
    Hey guys doing some work on the bead and ended up stripping these bolts. I've gone to multiple stores looking for the bolt and no one seems to have it. I'm trying to avoid having to spend $80 for 2 new tie downs and all I need is the bolts. Does anyone know what the bolt is?
  2. Sep 9, 2024 at 5:45 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    BKinzey and Jimmyh like this.
  3. Sep 9, 2024 at 8:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The issue is, the bolt is collared. It has to be so that the D-ring can swivel.
    Blockhead and GilbertOz like this.
  4. Sep 9, 2024 at 8:52 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    You can buy an independent collar and use proper size bolt.
  5. Sep 9, 2024 at 9:35 PM
    TnShooter
    Deogee
    STOCK
    Yes, You could.
    But that would require finding the right collar size.
    One may have to get handy with a lath, mill, or rudimentary file and drill method.
  6. Sep 9, 2024 at 9:46 PM
    Stuck in VT
    Utah
    2019 SR SX MGM
    Just found a place, aluminumspacer.com .Site is not phone friendly so I couldn't check the site.
    TnShooter[QUOTED] likes this.
  7. Sep 9, 2024 at 10:16 PM
    SamS
    SamS Well-Known Member
    Vancouver Island, BC, Canada
    06 Access cab 4x4
    Could go to a junkyard to get some cheap.
    Stuck in VT likes this.
  8. Sep 10, 2024 at 12:10 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    That is called a "shoulder bolt"
  9. Sep 10, 2024 at 6:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Stuck in VT and TnShooter like this.
  10. Sep 10, 2024 at 11:00 AM
    Stuck in VT
    Utah
    2019 SR SX MGM
    Thanks! Didn't know it was called a shoulder bolt. Should have thought of McMaster.
    Learn something everyday on the forums.
    Hopefully, the op has luck with that and maybe posts back.
    Torspd[QUOTED] likes this.
