What brand brake master cylinder?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BarnBoy, Apr 9, 2018.
  1. Apr 9, 2018 at 2:50 PM
    BarnBoy
    BarnBoy [OP] Well-Known Member
    96 Tacoma 2wd
    1996 2wd 5 lug 2rz-fe. I suspect master cylinder is going bad. With engine on, brakes pump up and get hard, then slowly the pedal fades to the floor. Will still stop the vehicle but want to get it fixed before taking it on the road.
    What brand is best? Rockauto usually carry good master cylinders? Are rebuild kits worth the time/effort/money?
    Thanks
  2. Apr 9, 2018 at 2:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Acdelco is a good brand if you want after market, oem is of course best. If you have the time to rebuild the oem i would just do that
  3. Apr 11, 2018 at 2:11 PM
    BarnBoy
    96 Tacoma 2wd
    I have heard rebuilding master cylinders can often be a waste of time and can leak past the seals again if not done properly. Anyone have any first hand experience rebuilding master cylinders that they can share? Sperrunner, if could elaborate on why you would rebuild vs buying aftermarket?
    I found a Cardone Select master cyl. on RockAuto. I think it was @ $60 or so. Any reason to avoid Cardone Select?
  4. Apr 11, 2018 at 2:42 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I rather just flush $60 down the toilet than install anything by Cordone or Dorman the same goes for Centric.
    I'm sure it will work fine, but in the last four years a lot of aftermarket shit is batting zero in my garage
    BillsSR5 and OneWheelPeel like this.
  5. Apr 11, 2018 at 3:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    A properly rebuilt oem one with oem parts will last longer then some after market stuff. I personally would just pay oem price to buy an oem one.
  6. Apr 12, 2018 at 8:23 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    :thumbsup: and if you like doing your own work, then rebuild the thing yourself. It's no big deal.
  7. Apr 16, 2018 at 9:19 AM
    BarnBoy
    96 Tacoma 2wd
    Huh. Ok. I just bought a Dorman steering shaft for our '05 Sienna, hopefully it turns out ok.
    Yeah I cant afford OEM at this point. They want an arm and 2 legs for it from the dealer.
    Thanks for the help, I havent decided yet but will keep researching and considering all options. I have been told not to rebuild but IDK. Part of me wants to just to say I have done it and to gain better understanding of the internals of a master cylinder.
  8. Apr 16, 2018 at 9:26 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Search the classifieds see if you can find a good oem one that someone is selling. Ive seen a number of part outs here and im sure ebay or craigslist will have some
  9. Apr 16, 2018 at 9:27 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    call the Gunny
  10. Apr 16, 2018 at 3:51 PM
    BarnBoy
    96 Tacoma 2wd
    Ok, I have been in touch with Gunny before, good guy. I will see what he gets for a OEM one.
    I didnt think about the used route....would be a viable option but I wouldnt want to pay a lot for it. I would be leary of getting another one with the same problem.
