What brand oil and oil filter do you use?
Discussion in '4 Cylinder' started by The Shape, Apr 9, 2009.
  1. Mar 1, 2010 at 10:52 AM
    #61
    2003 TRD Man
    2003 TRD Man Well-Known Member
    Edison N.J.
    03 TRD automatic
    pennzoil platinum 5w30 and K&N filter
  2. Mar 1, 2010 at 5:03 PM
    #62
    Waking the Dead
    Waking the Dead Well-Known Member
    Raleigh, NC
    2010 TRD Sport DC LB Gray
    Thanks for the detailed description. It helps a lot.
    It makes sense to me that if you change the oil on a regular basis with simple petroleum-based products and don't stress the engine you should be fine.
    And a good filter of course.
    I've heard you can go longer with full synthetics but not changing your oil every 5000mi. affects your warranty.
    I would be worried that they wouldn't honor the warranty if I changed the oil every 10,000mi.
  3. Mar 2, 2010 at 10:02 PM
    #63
    One Owner
    One Owner Member
    E. OR
    97 Taco XtraCab 4wd
    1.5" Rancho lift, NW Offroad header
    Mobile 1 and a Puralator Pure One filter.
  4. Mar 2, 2010 at 10:06 PM
    #64
    toyotaco03
    toyotaco03 Member
    Drew
    Reynoldsburg
    03 PreRunner
    Niteshaded taillights, new tokico shocks
    Castrol GTX high mileage and K&N performance gold oil filter
  5. Mar 13, 2011 at 11:00 PM
    #65
    Spitfire12
    Spitfire12 Well-Known Member
    Castrol gtx high mileage and toyota oil filter
  6. Mar 14, 2011 at 12:37 AM
    #66
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    use mobil1 filters, they're the same thing and a dollar cheaper.. like not "same in quality" like same plant same parts used same templates
  7. Mar 14, 2011 at 2:05 AM
    #67
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I do my LOF every 3,000 miles. Going a year, 10K, 15K on a oil change...N.U.T.S. (to me at least)
    I run a Full Syn, usually between Valvoline and Castrol. I would prefer the Castrol every time, sometimes the Valv is on sale, gotta save a buck where you can, still quailty oil. Wally World typically has 5 qts jugs for a little over $20 of either one.
    Oil for the most part, and for what you need it for comes down to really 4 basic choices. Within each group is so many different variants.
    A Convential oil - pure, basic stuff.
    A Semi-Syn Oil - A blend of Conv. and Syn. Get some of the benefits of a Full Syn without the higher price.
    A High Mileage Oil (A semi-Syn with a tad extra for high miles)
    Or a Full Syn. - the best of the best.
    Most of the difference is in molecular structure. The molc's in a convential oil all vary. They are of different sizes, some small, some larger. In a Synthetic Oil, all the molc's are supposed to have uniform molc structure. This is important in how the oil breaks down. The engine will break down the small molcs in the convential oil faster than it will break down the uniform molcs in a Full Syn.
    But really, just change the damn oil, REGULARLY. Only bad things happen when you don't change the oil. The oil itself, even the convential can last for quite awhile, it's the additives in the oil that wear out and then thats when damage starts happening. (Think Sludge). Additives wear out, oil gets overheated and turns into sludge. It gums everything up.
    Regardless of the oil you choose, just freaking change it on time and you should never really have any issues. Some like the full syn, it does improve gas mileage a tad bit and IMO, I think an engine just overall seems to run a little better with a Full Syn, but that might just be in my head.
  8. Mar 14, 2011 at 9:34 AM
    #68
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    just changed oil last night. Mobil1 filter and Mobil1 5-20w.
  9. Mar 14, 2011 at 12:18 PM
    #69
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Mobil 1 0w-20 and Mobil 1 filter.
  10. Mar 27, 2011 at 1:35 PM
    #70
    checksix
    checksix Member
    wisconsin
    black no frills
    bull bar, hitch, tonneau
    Is power steering fluid lighter than brake fluid?
  11. Mar 27, 2011 at 1:42 PM
    #71
    checksix
    checksix Member
    wisconsin
    black no frills
    SO... if i found out my son added a small amount of power steering fluid to my brake fluid can i just flush the reservoir? He only braked twice, once backing out and once pulling in.
  12. Mar 27, 2011 at 1:50 PM
    #72
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    One of the best posts on the subject I've seen. Well said Sir! :bowdown:
    ....of course that's just my humble opinion. :D
  13. Apr 1, 2011 at 3:03 PM
    #73
    bigrooster
    bigrooster Member
    frank
    FC
    00 taco ext sr5 Blue
    Mobil1 10w30, toyota OEM filter, k&n air filter. i use 10w30 because its better than the crap it says to use on the oil cap. i use the best for my 2.7.
  14. Apr 1, 2011 at 4:40 PM
    #74
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    your moms tampons...
    this ones beaten into the ground aint it.
  15. Apr 2, 2011 at 6:39 AM
    #75
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    OEM Toyota Filter
    5w-30 Wal-mart Supertech Synthetic oil
  16. Apr 2, 2011 at 6:58 AM
    #76
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    my first oil change at 1000 miles I went with Mobil 1 "dino" 5w-30 and Factory Filter. My next will be at 5000 miles and will consist of TRD Oil Filter (got a deal on them) and Mobil 1 5w-30 full synthetic
  17. Apr 2, 2011 at 7:02 AM
    #77
    JDeLuca
    JDeLuca Well-Known Member
    Joe
    Staten Island NY
    2013 TRD Sport MGM
    TRD Cat Back Exhaust, Bed mat, Weather Techs wet okole seat covers
    Mobil 1 5w 30. Use Toyota OEM filter, Japan.
