What brand wheel spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake Denney, May 15, 2015.
  1. May 15, 2015 at 7:56 AM
    Jake Denney
    Jake Denney [OP] Member
    Jake
    2013 - Charcoal Tacoma - Extended Cab 4X4
    ProComp 3" leveling kit - 285/75R16 Toyo Open Country AT2
    So I'm new to the forum, and this is my first post, but here goes.
    I just put a lift on my '13 taco; pro comp 3" in the front, 1" in the back. I mounted 285/75R16 toyo open country at2's and it looks great. Fills the wheel well nicely but rubs like a b. looking to get some wheel spacers to try and reduce or eliminate the rubbing while also getting a more aggressive stance. I'm torn between the 1" and 1.25" but I know I want billet aluminum. Only thing, I'm not sure the best place to get them. Any suggestions?
  2. May 15, 2015 at 8:00 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    are you rubbing the uca's (upper control arms) or the cab mount (steel mount in the back of the wheel well where the body attaches to the frame)?
  3. May 15, 2015 at 8:08 AM
    Mademan925
    Nick
    Discovery Bay, CA
    The reason I ask is. If you have 285s on stock rims you will rub the Upper control arms... So wheel spacers will solve your problem. If you have aftermarket rim with different backspacing and you are rubbing the cab mount. Spacers will make it worse...
    The good spacers are bora, allpro, spydertrax...
  4. May 15, 2015 at 8:32 AM
    Jake Denney
    Jake
    Thanks for the reply, I'm rubbing the UCA's, still running stock wheels. Do you think 1" will be enough distance to stop it altogether? I know it's probably hard to tell without seeing it in person.
  5. May 15, 2015 at 8:37 AM
    Mademan925
    Nick
    Discovery Bay, CA
    I know the 1.25 clear it unless your rims have hella back spacing.
  6. May 15, 2015 at 8:45 AM
    Jake Denney
    Jake
    I'll probably go with the 1.25 just to be safe. I plan on getting rims later anyway so even if spacers don't completely fix it, I can make adjustments then.
    Thanks for the input
  7. May 15, 2015 at 8:45 AM
    medic2230
    Murph
    Bama! Roll Tide
    Where are you rubbing at on the UCA's? I'm running stock TRD wheels and only rub UCA's at full droop. If I add wheel spacers I'm going to have to do the cab mount chop. Fixing one problem creates another in this area. I'm also running light racing UCA's and have about a 1/2" of clearance between tire and UCA.
  8. May 15, 2015 at 8:46 AM
    Jake Denney
    Jake
    Nice build btw, that thing is sick
  9. May 15, 2015 at 8:54 AM
    Mademan925
    Nick
    Discovery Bay, CA
    Thanks. Also, Wheel spacer will cause rubbing on the cab mount.. But that can be fixed. with a cab mount chop or even just alittle hammering of the pinch weld on the body.
  10. May 15, 2015 at 9:22 AM
    Jake Denney
    Jake
    I'm rubbing on the forward portion of the UCA about an 2" forward of the UCA ball joint. I tried adding a picture but apparently I'm dumb. I had a friend that had the chop done but I'm ballin on a budget. I'm all for beating the crap out of something with a sledge, but sounds sketchy.
  11. May 15, 2015 at 10:35 AM
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    OP-when do your tires rub? Full turns to either side?
  12. May 15, 2015 at 10:51 AM
    Jake Denney
    Jake
    about 3/4 into the turn on either side. for some reason when I'm backing up it's worse though which doesn't seem right to me
  13. May 15, 2015 at 10:53 AM
    Jake Denney
    Jake
    ehh probably closer to 4/5 than 3/4 its almost at full turn that it starts to rub
  14. May 15, 2015 at 11:11 AM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Your rubbing problem is freaking me out! I am very curious what your wheel backspacing is.
  15. May 15, 2015 at 11:49 AM
    Jake Denney
    Jake
    I'm running the stock wheels for a 2013 Tacoma base 4x4..
  16. May 15, 2015 at 12:22 PM
    Mademan925
    Nick
    Discovery Bay, CA
    stock wheels are 4.5 backspace. to much back space to clear the uca with 285s
  17. May 15, 2015 at 3:08 PM
    medic2230
    Murph
    Bama! Roll Tide
    The stock UCA is probably one of the problems. A aftermarket one would have given a little more clearance.
  18. May 15, 2015 at 4:26 PM
    Jake Denney
    Jake
    So with these rims and stock UCAs should i put 1.25" spacers on? Or will it rub on the cab mount?
