What bump stops after removing airbags?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Squadbeee, Aug 6, 2024.
  1. Aug 6, 2024 at 6:25 PM
    Squadbeee
    Squadbeee [OP] New Member
    Hi everyone.
    I have a 2020 TRD OR and I had airbags installed as I towed a camper all the time for work. Now I have sold it and will be taking the airbags off this weekend.
    When having the airbags installed the OEM rubber bump stops were cut off. Am not worried about driving without the bump stops for a while but still want to put some back there.
    As of now I am thinking of getting something close to OEM ones but can not find anything.
    What bump stops should I get? Ideally I want the best ride possible with the stock suspension I have now. Also don't want to spend another ~$300 for some fancy bump stops.
    Any advice appreciated.
    A_Baum92881 likes this.
  2. Aug 6, 2024 at 7:01 PM
    A_Baum92881
    A_Baum92881 Well-Known Member
    2019 Taco DCSB
    King 2.5 OME heavy pack Camburg UCA's Magnuson Super Charger Super Pacific X1 (with built out bed) The list continues to grow as my bank account continues to suffer!
    I also had bags on the rear for a while and have since upgraded to the Sumo Springs. They are a little pricey but definitely a buy once, cry once type of deal.
  3. Aug 6, 2024 at 7:05 PM
    Squadbeee
    Got it. After the airbags I want as smooth of a ride as possible. lol.
    Are sumosprings any rougher than stock?
  4. Aug 6, 2024 at 8:30 PM
    A_Baum92881
    2019 Taco DCSB
    Sounds like you’re in the same camp as me when I removed my springs. I went with the Sumo Springs - Blue for the front and rear (rear is a must).
    There was a big difference with the change IMO. Also very much smoother than stock. The stock hockey punk type bump stops are very jarring (not as much as the air bags) whereas the sumo springs are a lot more forgiving for sure.
    Keep in mind, this is only the bump stop portion when it comes to the smoothness of the ride. After doing the Sumos I went Kings all around and it’s like driving a cloud now.
  5. Aug 7, 2024 at 10:33 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I went SUMOs on the front and rear and I think my truck rides better now. they work great if lifted 2/1 on 5100s.
  6. Aug 7, 2024 at 10:35 AM
    Squadbeee
    Appreciate the advice so far. My truck is stock for now and with normal driving having no bump stops will be fine. Will not be bottoming out. Ideally am looking for something similar to stock ones. Should I contact Toyota?
  7. Aug 7, 2024 at 10:43 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The OE ones are horribly hard,,, but if you’re not anticipating using them often (load), I’d just look for a used set. You can probably find em for the cost of shipping, as most go in the dumpster,,, mine did.
