What bushing need replaced at 200,000 miles?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Nov 2, 2016.
  1. Nov 2, 2016 at 11:58 AM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Im about to order the energy suspension master bushing kit for my 02' 4wd.
    What bushings other than those should I replace while its all taken apart??
    Drive line, steering, etc.
    Thanks for any help.
    ChadsPride likes this.
  2. Nov 2, 2016 at 12:24 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The ones that are worn out!!
    All depends on your driving habits and the people before you.
    I am at 200,000 plus all my bushings are still the original but for the rear springs which were replaced with the springs
    I belong to if it ain`t broke don`t break it just to fix it.
    Sicyota04 and OneWheelPeel like this.
  3. Nov 2, 2016 at 12:35 PM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    Agreed with the above. Depending on when you got your truck or how much knowledge you have about it's past life I'd look into sway bar end links and steering bushings. I'm at 136k and those are what needed replacement on mine.
  4. Nov 2, 2016 at 12:40 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
