What camera are you shooting with?
Discussion in 'Photography' started by mtxsub, Sep 27, 2012.
  1. Sep 11, 2020 at 12:41 AM
    #361
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Practice practice practice and more practice. Digital makes it cheap and easy, all it costs is time... once you have the computer, the editing program, and the hard drive space of course.
    I started with a darkroom class in high school. One of the test rolls we shot in the beginning were doing equivalent exposures to see how each setting changes the image, with the goal of having every frame properly, and more important equally, exposed. So take a roll off of Tri-X 100 iso film out on a sunny day, and shoot:
    1/60 f22
    1/125 f16
    1/250 f11
    1/500 f8
    1/1000 f5.6
    1/2000 f4
    1/4000 f2.8
    1/8000 f2
    Lots of old cameras top out at 1/500 or 1/1000 though, which was fine when there was still iso 25 and iso 50 film commonly available. You only got 12, 24, or 36 shots on 35mm anyway, so you could change your iso when you ran out of film in the camera. Then you spend an hour developing the roll, another hour later making contact sheets just to see what you got if anything. I miss the process a lot but it is unquestionably easier to import digital files in to Lightroom...
    Back on topic, Try shooting something moving at 1/30s, both while keeping the camera still
    as it goes by as well as trying to track it with the camera and keeping it in the frame. Try again at 1/1000. Set up a tripod and shoot some flowing water at 1/1000, then 1/125, then 1/15, then 1 second.
    Play with depth of field. Shoot something at f16, f8, f5.6, at f2 or f1.8. Keep the camera to subject distance the same with each shot. Try it with a landscape. A upper torso portrait. A head shot. On something as close as you can focus and big enough to fill the screen, like a flower.
    Do these enough and you’ll start to learn how much shutter speed you need, or what kind of aperture you’ll want, for the image you want to make.
    Then do the same sort of test, but with iso, to see how far you can push iso before image quality degrades too much for you. Try this inside, so you have room to work (and you see how it looks in low light, when you’ll likely be using high iso). Using my example before for inside, tweaked again, you’ll need a tripod or a stand...
    1sec f8 iso 100
    1/2 f8 200
    1/4 f8 400
    1/8 f8 800
    1/15 f8 1600
    1/30 f8 3200
    1/60 f8 6400
    1/125 f8 12800 (if your cameras goes that high)
    1/250 f8 25600 (same)
    Compare the images. How far can you go before image quality is noticeably worse on screen? Significantly worse? Unusably bad?
    Don’t trust the screen on your camera, you have to look at it on a computer. This helps inform your exposure choices and decisions. My first Nikon D40 was ok at iso 1600, my Pentax K-30 was good to 1600 and ok at 3200. My current Pentax KP is solid to 6400 and workable up to 25600(!).
    And take notes! Get a cheap notebook and write it down
  2. Sep 11, 2020 at 6:56 PM
    #362
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    i’d say about F-16 for the fraction. The sharpness does depend on the lens and on average sharpness is around F8-F11. Does depend on what you’re shooting because at 5.6 is sharp for landscape.
    medic2230 likes this.
  3. Sep 11, 2020 at 6:58 PM
    #363
    5150Bronco
    Bay Area, Ca.
    I would wait to shoot a long focal lengths at sunrise so you might get some separation in the horizon, fog and any other lateral lines with the smoke...
  4. Jan 9, 2021 at 8:31 AM
    #364
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Hello. My name is Curt and I am an addict. Relapsed. :(
    Early 80s I bought a Canon AE1. Then an A1. Then... lenses. :spending:
    Then along comes DSLR. Will my lenses fit a Canon? Nope. There was an adapter that didn't work well.
    I quit SLR cold turkey. And bought an A70. And a cell phone. Complete recovery! Until...
    Last Oct Nikon offered the Z5, use it for a month and return it if I don't like, all on their dime. Told wife I'll get it and return it. Sure I will. Got the 24-200 lens. 1st pic I took was a candid of my wife from 2 rooms away. Blew me away and her too. She said keep it. I did.
    So here I am, and I haven't figured out half the things it can do. :dunce:
    btw Nikon still has the offer, $200 cheaper than what I paid. :annoyed:
    https://www.nikonusa.com/en/nikon-store/mirrorless-camera-bundles.page#!/tag:ikc:Z 5
    https://www.nikonusa.com/en/nikon-products/product/mirrorless-cameras/1641/z-5.html
    PzTank, Fargo Taco and medic2230 like this.
  5. Jan 28, 2021 at 12:10 PM
    #365
    KE5TXK
    KE5TXK Cactus Hobbit
    Cody
    Sonora, Texas
    2021 Voodoo Blue TRD Off Road
    None atm.
    I am shooting a Fuji Film X-T4. I also have an X-T3 and love them both. I am coming from few Canon's. I started with an EOS 50D then a 90D then bumped up to an EOS R. I decided to change platforms after I went to some forensic trainings that utilized the X-T1IR. I use the X-T1IR for work and back it up with the X-T4 and T3. The X-T1IR is an amazing camera and can capture some amazing things with ALS.
    Anton338 likes this.
  6. Jan 28, 2021 at 12:37 PM
    #366
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I just downsized from a Fuji X-T3 with 16-80 f4 to a barely used (like new) X-T20 with 16mm f2.8.
    Wanted something a little simpler and small enough to throw into a jacket pocket. Mostly use it when doing outdoor activities.
    Sold the X-T3 outfit for nearly what I paid.
    Anton338 and PzTank like this.
  7. Feb 11, 2021 at 9:23 AM
    #367
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    It's been a long time since I've had a nice camera. This may be controversial, but I'm super psyched with the Leica Q-P I just grabbed (used, I need money for Taco MODZ :cool:).
    Years back, when I was living in NYC, I had a Leica M6 that I regrettably sold after I moved to CO. I wish you didn't have to pay so much for Leica's, but there is something about these cameras that speaks to me. Maybe…one day I'll get a used digital M.
    Likely will sell my Ricoh GR3 if anyone is interested.
  8. Feb 20, 2021 at 5:27 PM
    #368
    bassmusic
    bassmusic Coastal Redwood Cultivator
    Spicoli aka ChrisTOEpher
    Chapel Hill NC
    19 Tacoma SR5
    a d7100 that has seen better days, and stashing coin away for a D850 and a new water housing.
  9. Mar 18, 2021 at 4:39 PM
    #369
    bassmusic
    Chapel Hill NC
    19 Tacoma SR5
    I got my Biden Bucks the other night, so I'm about to buy a D850 - looking at KEH, Ebay etc for a good specimen.
  10. Mar 18, 2021 at 5:39 PM
    #370
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Brownmatthall likes this.
  11. Mar 29, 2021 at 3:09 PM
    #371
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    :rofl::rofl::rofl::rofl:
  12. Apr 2, 2021 at 7:18 PM
    #372
    bassmusic
    Chapel Hill NC
    19 Tacoma SR5
    D850 ordered, paid $120 for overnight shipping and insurance through Fedex, and it didn't make it today by 4:30pm.
    I'm really losing faith in Fedex and UPS. I don't know if anyone else has had a lot of late deliveries, yes, some will say it's the pandemic and the amount of volume. Maybe.
    I don't know. But, since this is not a Saturday delivery, my overnight shipment now turns into a wait til Monday shipment.
    Grrrr.
    PcBuilder14 likes this.
  13. Apr 2, 2021 at 7:20 PM
    #373
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Hope it was worth the 120
  14. Apr 2, 2021 at 7:25 PM
    #374
    bassmusic
    Chapel Hill NC
    19 Tacoma SR5
    Well obviously not. Thankfully I found some good ammo on Fedex's website for disputing the charge altogether with my bank.
  15. Apr 2, 2021 at 7:26 PM
    #375
    JKO1998
    Utah
    You musta REALLY wanted some bunny pictures to pay that much
  16. May 3, 2021 at 2:18 PM
    #376
    88seriesiii
    88seriesiii Well-Known Member
    2007 Access Cab 4x4 TRD Off Road 6cyl MT
    OEM with ARE CAP
    I have a '15 D7200, but also would like to move into a D750, D800 D850... Still waiting for the prices to drop a bit more ... hope you like yours
  17. May 8, 2021 at 9:55 PM
    #377
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Oh my.
    Zim
  18. May 8, 2021 at 10:02 PM
    #378
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Sony a6600, Sigma 16mm 1.4, Sony 18-135 3.5-5.6. I started with the F2 in the US Navy, had (2) FM2 for personal use. Loved all of them especially the FM2. Could throw the thing across the room and it still worked. Bullet proof camera, except when rock climbing.
    Zim
    88seriesiii likes this.
  19. Jun 25, 2021 at 7:43 PM
    #379
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Mostly? Pixel 4XL.
    Planned pics? Eos RP
  20. Jun 25, 2021 at 7:44 PM
    #380
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Fujifilm X
    .劉煒 likes this.
