What can a 1st gen tow?
Discussion in 'Towing' started by Toyotafan1234, Mar 14, 2016.
  1. Mar 14, 2016 at 4:13 PM
    Toyotafan1234
    Toyotafan1234 [OP] Member
    Cam
    Hi All,
    I'm looking at buying a 1st gen Tacoma and would like to know what the 4 cylinder and 6 cylinder can tow.
    I have a ski boat and it ways around 3000lbs can I tow it with a 4 cylinder?
    I won't be driving very far and at most I would drive about 20 miles and it would be all back roads.
  2. Mar 14, 2016 at 4:20 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It will do it. Turn off overdrive.
    The 4 cylinder has plenty of low speed torque. Make sure Trailer has brakes.
  3. Mar 14, 2016 at 4:23 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's won't be fun.
  4. Mar 15, 2016 at 11:56 AM
    tgear.shead
    tgear.shead Well-Known Member
    It will be TONS of fun.
  5. Mar 15, 2016 at 2:18 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you like shifting a lot.
  6. Mar 15, 2016 at 7:09 PM
    tgear.shead
    So DON'T SHIFT A LOT. Pick the proper gear and let it be.
  7. Mar 16, 2016 at 4:52 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  8. Mar 16, 2016 at 4:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I owned one they are no ball of fire yes it will tow it but it won't be happy about it. My 97 was flat out geared too high to make it an easy tow and that was at the time with just with a popup camper. If you are just on back roads you'll probably be OK but it won't keep up too well with highway traffic with 3000+ pounds of weight.
  9. Mar 16, 2016 at 6:49 AM
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    We use to tow a 19' travel trailer behind a gen 1, 4 banger with a 5 speed 4x4. It would make it to the beach about 2 and a half hours away mostly flat highways. The truck wasn't happy about it but it did it. My concern with a ski boat would be getting it it of the water.
  10. Mar 16, 2016 at 12:29 PM
    tgear.shead
    If it seems overgeared, you've picked the wrong gear. You don't have to use 5th.
    Now granted the newer engine (2TR-FE) has a vastly flatter torque curve thanks to VVT than the older 4-cyl engines (now are we talking 2.4 or 2.7?), but 3000 pounds really is not all that much. Especially if your load is reasonably aerodynamic. For instance, a ski boat (like OP is talking about) is FAR more aerodynamic than a camper, even a popup is a square brick. Generally on the highway, weight won't impact your ability to "keep up" with traffic, just how long it takes to get there, and what it takes to climb hills. The thing that really holds you back, is aerodynamics. Wind resistance. Get to a hill and it needs a downshift, throw it into third, drop the pedal to the floor, and let it rip. You just don't want to be doing that on flat roads to keep your speed at the speed limit.
    Not really sure what you mean by "it won't be happy about it". Toyota 4-cyl can do a million highway miles in 3rd gear and when you're done, it'll beg for more.
  11. Mar 16, 2016 at 12:30 PM
    tgear.shead
    Why would that be a concern? Getting in and out of the water is a function of traction. You apply all of 5 horsepower to do the work.
    Just don't do it like the mexicans on youtube and boat launching is an easy task that can be done with a ford fiesta.
    TN_Tacoma likes this.
  12. Mar 16, 2016 at 12:31 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Having towed with 4-bangers before, this theory only works if you're towing someplace flat.
    In low range & 1st gear it should walk a boat up the ramp without any problems. If my tired '96 Hardbody could do it, a Tacoma can do it. :notsure:
  13. Mar 16, 2016 at 12:58 PM
    tgear.shead
    Works everywhere.
  14. Mar 16, 2016 at 1:08 PM
    Noelie84
    Noel
    Wales, Maine
    Sure it does. I don't know what I'm talking about. After all, I only drove 4 cylinder 5 speed 4x4's in hill country for years. Couldn't possibly have any personal experience to draw from. :rofl:
    A 4 cylinder truck towing 3000lbs on the winding, hilly back roads of Western Maine requires frequent gear changes if you want to maintain anything remotely close to the posted limit and not burn through fuel like Charlie Sheen burns through coke. It just does. If you don't believe me you can come to the state and test it out.
    scocar likes this.
  15. Mar 16, 2016 at 1:15 PM
    tgear.shead
    While you are climbing a hill, do not upshift unless it can actually SUSTAIN speed in the higher gear, otherwise you will just be downshifting again, which is what automatics do. Its called gear hunting. Don't be an automatic transmission!
    Downshifting to the *proper* gear at the BOTTOM of a hill, and then upshifting at the TOP of a hill, is not "frequent gear changes". It is NORMAL DRIVING.
  16. Mar 16, 2016 at 1:17 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    I towed a small Uhaul across the country in my v6 automatic. As said before, it will do it. It just won't be happy about it.
  17. Mar 16, 2016 at 1:24 PM
    scocar
    scocar hypotenoper
    tgear.shead, sounds great in theory (and all the caps really help support your argument), but then there is the real world. Grades and curves and traffic conditions are not linear and uniform. And your NORMAL DRIVING is FUCKING TIRESOME.
  18. Mar 16, 2016 at 1:24 PM
    tgear.shead
    I think that the driver is the one who isn't happy.... and probably because of the automatic.
  19. Mar 16, 2016 at 1:24 PM
    Noelie84
    Noel
    Wales, Maine
    Yes, I'm aware of how to drive a manual transmission, thanks. Been doing it on the road since I was 15. But long hills with changing grades or sharp curves aren't always conducive to that strategy, which means that you will have to shift before you crest the hill. Some roads don't go in straight lines or have sustained grades. Around here, that's most of them. :notsure:
    Not knowing where the OP's from, it might be irrelevant. But it might not.
    scocar likes this.
  20. Mar 16, 2016 at 1:25 PM
    tgear.shead
    This isn't theory. This is daily experience.
    You might consider switching to a wheelbarrow if you don't feel like shifting EVER.
