What can be used to remove hardened adhesive dripping?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, May 21, 2017.
  1. May 21, 2017 at 10:21 AM
    aleriance
    aleriance [OP] Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Made my own old school FJ grille for my 3rd gen using the original bezel, a $70 CCG Grille from eBay, and an original TOYOTA emblem I found on eBay for $25. Used some 3M automotive adhesive to put it all together. Pleased with the results, thought I just noticed some of the adhesive dripped down a bit before completely drying and it is visible. Is there a trick to remove this? It's hard no almost like hot glue... I tried some acetone with no luck.
  2. May 21, 2017 at 10:23 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I'd just hide it with paint. Anything that will soften the adhesive will probably ruin the paint and plastics. Maybe trim it with a razor, then paint over.
    Looks good tho!
  3. May 21, 2017 at 10:25 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Goo be gone? Or use a hair dryer on it and see if it can be softened enough to pull off
    rolled93slc and shakerhood like this.
  4. May 21, 2017 at 3:06 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Trim it back with a razor and then clean the residue with WD 40.
    Clay7160 likes this.
  5. May 21, 2017 at 7:18 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    A solvent will work without hurting the paint. Might be best to use a razor to cut most off and just use the solvent to get the little bit off with a rag, so your not soaking and scrubbing for a long period of time which could start to discolor something. Mineral spirts would probably work too just be careful if using that as its a little stronger than prep solvent
