What can cause code P11ED?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by woods17, Jul 15, 2023.
  1. Dec 20, 2023 at 7:33 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    It's a valve sealing issue, and it just seems to be bank 1. I have replaced several on Tacoma's and a hand full on Highlanders. IIRC they were all 17 and 18 model years. And almost every one of them was right at 50-55K.
    Every one I've done, I've replaced the head and all the exhaust valves. It'd pretty labor intensive. For the Tacoma's, it easier to pull the cab and pull the motor. The book wants you to pull the trans, then take out the engine.
    kona61 likes this.
  2. Dec 20, 2023 at 7:41 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There have been updates to the cylinder heads, but I don't know what the updates were or when they happened. For example, I am able to find the following:
    11101-09552 (Head Sub Assembly Cylin) - Right (Bank 1)
    11101-09551 (previous version)
    11101-09550 (previous version)
    11102-09182 (Head Sub Assembly Cylin) - Left (Bank 2)
    11102-09181 (previous version)
    11102-09180 (previous version)
    Here is a list of the codes and what cylinder they correspond to that I figured out a year or so ago:
    P11EC - cyl 1 (right front)
    P11ED - cyl 2 (left front)
    P11EE - cyl 3 (right middle)
    P11EF - cyl 4 (left middle)
    P11F0 - cyl 5 (right rear)
    P11F1 - cyl 6 (left rear)
    Most of the codes people bring here are P11EC or P11EE, which are cylinders 1 and 3 which are front and middle on the passenger side. Why those two are usually the problem, I have no idea.
    Then there's this thread we're in where @woods17 issue is P11ED, which is cyl 2 in the front left position. He has carbon buildup on all 3 left bank cylinders, and only the issue on the front cylinder, but no issues on the right side which is where issues almost always are on other trucks.
    Then you have the guys like @bigoldbeef who has one of the codes (I don't remember which one) and over 350K miles and has had the code for a while, continuing to drive on it anyways with no real problems besides resetting the code.
    Just overall a very odd/unexplained issue in general and still sometimes makes me question how long I may actually have my truck. If I was out of warranty, I'd probably just drive on it until that presented a problem, and then go get a used motor and install myself, rinse and repeat. We still have no idea why it actually happens, who is most likely to get it, etc. Seems like luck of the draw and it can happen early in warranty or way outside of it.
    Gfenza89[QUOTED] and pdxTacoSR5 like this.
  3. Dec 20, 2023 at 7:45 AM
    Bishop84
    Bishop84 Well-Known Member
    All for 20 hours, its super. Our hoists are in floor so we cant remove cabs, its amazing for everything BUT cab off. I did 3 frames with cabs chained to the rafters.
    I havent had to do a head yet but removing the 3.5 is dumb, and the 3.4 tundra is a pain too. Glad the v6 is dying lol.
    kona61 and rolled93slc[QUOTED] like this.
  4. Dec 20, 2023 at 7:48 AM
    rolled93slc
    Jerry
    Lynchburg VA
    We moved into a new store about 18 months ago, will 2 post lifts. The old shop was in ground lifts. They were ok for most everything, except engine and trans work. We had 2, 2 post lifts installed for doing frames. And that's the lifts I used to pull cabs for engine jobs.
    Bishop84[QUOTED] likes this.
  5. Dec 20, 2023 at 9:57 AM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    I’m not a mechanic but I do some pretty big jobs on track cars. The V6 ease-of-maintenance is one of the reasons I’d buy the 4th gen. It’s ridiculous that you have to pull the motor to do the timing cover or remove the cab to do a turbo replacement. I love how easy inline 4s and Chevy small blocks are to work on and pull.
    Gfenza89, BLtheP and Barsoom like this.
  6. Dec 20, 2023 at 10:49 AM
    BLtheP
    Plano, TX
    Agreed. The V6 has nearly the worst of all worlds. I wouldn’t say it’s unreliable but it’s certainly not known for being extra reliable like all the other V6s. It isn’t easy to work on when you do have a problem. It doesn’t have very much power and it doesn’t get good mpg. Where are the supposed upsides of this? I love my truck but the new turbo motor interests me way more, especially since it seems like Toyota gave it a good design.
    Gfenza89 likes this.
  7. Dec 20, 2023 at 6:45 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    I've been getting P11ed for around 80k +- miles. It typically throws P216D simultaneously. At 364k miles now.
    Its slowly getting worse. It has thrown a misfire code for cylinder 2 twice now in the past 10k+- miles.
