What can cause this ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jolly Onion, Mar 3, 2024.
  1. Mar 3, 2024 at 8:33 PM
    Jolly Onion
    Jolly Onion [OP] Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    Hello everyone
    I hope that you are doing well
    2004 Tacoma, 6cyl.
    A few weeks ago it would not hold idle, lights would dim when idling, blinkers would work normal, then start flashing fast, then really fast. ABS light came on.
    Shut the truck and tried to start - nothing, no lights no starter clicking. As if the battery was disconnected. Truck would not start.
    I disconnected the cables from the battery for half hr, and connected the + to - cable to drain the system. Also cleaned the throttle body really good.
    After reconnecting the battery, the truck ran as it should for a few days
    Today it started doing the same thing ?
    What should I check / replace next ?
    Thanks everyone
    Alex
  2. Mar 3, 2024 at 8:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the battery voltage when this happens?
    Weird things start to happen when they don't get the correct voltages.
    FWIW, I'm not saying it's the battery. But that would be a good place to start.
    Gen3TacomaOBX, ridefreak and dbittle like this.
  3. Mar 3, 2024 at 9:18 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    How’s the corrosion on your battery & alternator cables? If those are a mess I’d disconnect, clean, and reconnect then check alternator output and voltage regulation including alt-S fuse.
  4. Mar 3, 2024 at 9:22 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I would questions grounds and battery cables first.
  5. Mar 4, 2024 at 2:42 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    OBD II codes at all?
    Bivouac and ControlCar like this.
  6. Mar 4, 2024 at 10:59 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Thanks for the replies gentlemen
    I will check / clean the cables and see if it helps.
  7. Mar 11, 2024 at 7:24 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Good AM everyone
    As suggested by you, I cleaned and lightly sanded the battery posts, and the cables, and the problem went away. So it must have been a bad connection
    While at it, I cleaned the mass airflow sensor and ordered a fuel injection cleaner from Amazon, just to make sure everything works as it should
    Have a nice day and thanks
    Alex
  8. Mar 14, 2024 at 10:51 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Hi Folks
    Truck runs well overall, the fuel injection cleaner made the car crisper - going by the seat of the pants.
    Something else I noticed. When the car is idling the blinker flashes fast, when I step on the gas, it flashes normal (slower).
    What can cause this?
    Thanks
    Alex
  9. Apr 2, 2024 at 3:50 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
  10. Apr 2, 2024 at 4:29 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Cra Cra.
    Thanks for update and follow up
    Mental Note: no Master Disconnect for me.
    wilcam47 likes this.
  11. Apr 3, 2024 at 4:35 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I had one of those disconnects for years. Kept trying to use it in my old Saab Turbo. It always got corrosion between the contact surfaces leading to low voltage and current. What a piece of junk it was.
    What looked like brass construction wasn’t. It was diecast zinc pot metal, plated with something to look brassy.
  12. Apr 3, 2024 at 6:02 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    I focused on battery cables and voltage as mentioned by several people here. The problem is when the car starts, it is all good for a while, then the car started acting up. I even had a skilled mechanic hook it up to the scanner machine 2X , no error codes. We even disconnected the old alarm system (not working any longer) to isolate the issue. Finally he suggested we bypass the cutoff switch, and bingo.
    Madjik_Man likes this.
  13. Apr 4, 2024 at 8:03 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You don't really want to use those anyway since they reset fuel trims, timing, and emissions functions every time, just like unplugging the battery
