What can I do about driving safely on ice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ihatetacomas, Dec 28, 2016.
  1. Dec 28, 2016 at 7:16 PM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Other than drive really really slowly? Should I be using my LSD? (not exactly sure how all the options work)
  2. Dec 28, 2016 at 7:22 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Like a frozen lake, or icy roads?
  3. Dec 28, 2016 at 7:24 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Studded tires are the only thing besides chains that will help on ice.
    If you hate Tacomas, why are you on here?
  4. Dec 28, 2016 at 7:30 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Not very much you can do :notsure:
  5. Dec 28, 2016 at 7:31 PM
    Pigpen
    Dan
    Northwest Montana
    The ABS will try to kill you while driving on ice.
  6. Dec 28, 2016 at 7:34 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    I stay home.
  7. Dec 28, 2016 at 7:36 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I think he was referring to his name
  8. Dec 28, 2016 at 7:39 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    your right, forget my advice....
  9. Dec 28, 2016 at 7:41 PM
    Gearheadesw
    Davenport Fl
    Problems?
  10. Dec 28, 2016 at 7:44 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    4whi works fine
    Easy on the skinny pedal
    Stay off the brake
    Allow for longer stopping
    Go slow
    Give plenty off room
    Be Curtious to others (even when they piss you off, better pissed off than pissed on)
    Leave early if you really hafta get out
    idahbro likes this.
  11. Dec 28, 2016 at 7:51 PM
    Pigpen
    Dan
    Northwest Montana
    But the ABS...
  12. Dec 28, 2016 at 8:00 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    What it's the 2ng gen equivalent of the grey wire mod?
    Does OP have a rear locker?
    Surely there is a mod to turn off the ABS (?).
    I just stay off the breaks as much as possible.
  13. Dec 28, 2016 at 8:03 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Um Don't drive.
  14. Dec 28, 2016 at 8:20 PM
    Pigpen
    Dan
    Northwest Montana
    There are a couple versions of the ABS on/ off switch, depending on whether you have the locker or not.
  15. Dec 28, 2016 at 8:34 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    I don't know much about the 2nd gen stuff as I have a 1st gen. I did the grey wire mod for my locker but, have never been concerned about just turning off my ABS.
    I guess Elko, NV gets ice.:notsure: Didn't think it got much of any water in any form.
  16. Dec 28, 2016 at 8:39 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Can't you just pull the ABS fuse?
  17. Dec 28, 2016 at 8:39 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    If you are going to do it frequently / seasonally, consider investing in a second set of wheels / tires. Studded or studless winter tires (like Blizzaks) work great.
    Keep it in four wheel drive.
    Keep some weight in the bed.
    Drive slower, anticipate your braking early.
    Have an escape path in your end for every braking situation - better to run into a snow berm than someone's back bumper.
    I drive on M+S rated tires in four wheel drive without issue. Our roads have ice about 5 months out of the year.
  18. Dec 28, 2016 at 8:40 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    If you go really, really slow with the LSD engaged. That worked for me in January 2016. Actually slid down a hill and went off the road into a ditch without damaging my truck, then got out and back up the hill with nothing but patience, prayer, and my LSD.
  19. Dec 28, 2016 at 8:41 PM
    PennSilverTaco
    Charlie
    Also, when it snows, I take it advantage of this and shovel snow into the bed for weight over the rear wheels...
    ItalynStylion and DustStorm4x4 like this.
  20. Dec 28, 2016 at 9:22 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    Hicks-, Larzzzz and Jeffas7 like this.
