What can I do subwoofer wise in 2004 tacoma double cab?
Discussion in 'Audio & Video' started by CEREAL KILLER 04, Aug 11, 2014.
  1. Aug 11, 2014 at 10:42 PM
    CEREAL KILLER 04
    CEREAL KILLER 04 [OP] New Member
    Evan
    Bakersfield, CA
    4X4 Sr5 V-6
    Fabtech Lift K&N Intake 16'' Black steel wheels 33'' Falken At's
    I've noticed there wasnt as much room as I thought might be behind the seat. What are my options? I've looked around but haven't found a solid answer. Thanks.
  2. Aug 11, 2014 at 10:44 PM
    Texan Tacoma
    Texan Tacoma Texas Tech University
    Lubbock, Texas
    07 PreRunner v6
    SAW 2.5s , mb vortex wheels, AeroTurbine 2525 with dump, Spyder headlights, Rocklights, custom bumper, SOS offroad carrier, etc..
    My friend has subs in his, I'll ask him and try to get some pics to post.
  3. Aug 11, 2014 at 11:05 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    For behind the rear seat, there are two off the shelf options that I know of.
    Car Audio Factory box for up to 10" shallow sub
    http://caraudiofactory.com/2001-toyota-tacoma-prerunner-p-386.html?osCsid=8112a6e2134986b9faa64f82b1701be4
    and
    Supercrewsound dual shallow 8"
    http://www.supercrewsound.com/04tacomadbldual.html
    I have owned both..... the dual 8" first and then the single 10". The 10" gave me the best bass and still leaves a lot of the area behind the rear seat for storage.
    I chose a 10" Pioneer TS-SW2501S4 and had to do a little trimming/Dremeling to get it to fit in there. A 8" would be easy.
  4. Feb 10, 2015 at 10:26 AM
    Qbranch
    Qbranch New Member
    Ian
    Central Florida
    03 PreRunner
    Matt, are you powering up your 10" sub separately or using one amp for the whole system. I've been following your posts as I have the same truck and I think your set up will work nicely for me.
    Thanks for your time!
  5. Feb 10, 2015 at 10:28 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    more than enough room behind the seats of a DC :)
    If your willing to build a custom box you have a ton of options from 2 8s ported to 2 12s even sealed.
  6. Feb 10, 2015 at 1:18 PM
    mtucker
    Escondido, CA.
    03 Prerunner DC
    I am powering it separately. I have a four channel amp for the four door speakers and then use a Fosgate 400-2 bridged into the subwoofer. I run the subs dual 8 Ohm voice coils in parallel to make a 4 Ohm load for max power out of the amp.
    The shallow sub in a very small sealed enclosure isn't the most efficient setup, but power is cheap these days. Run plenty of power and it helps to have a bass boost (either in the radio or in the sub amp). My amp has a bass boost control (at 45Hz) that can be remotely mounted and adjusted. It really helps bring the deeper bass out. I wouldn't be nearly as happy with my setup without that bass boost. I haven't checked to see if they sell that Pioneer speaker still, but it takes a bit of filing and "Dremling" to get it to fit in the Car Audio Factory box.
    I don't think you could fit a 12" back there even without a box. In the 2005+ years that is a different story, but 2004 and before is very tight back there.
  7. Feb 10, 2015 at 2:09 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Crap your right! I totally didn't see its for a 04 :p
    For the 04s the 8 inch subs ported seems to be solid way to go :)
