What can i expect after a Bilstein 5100 Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wayne2970, Sep 27, 2015.
  1. Sep 27, 2015 at 5:24 PM
    Wayne2970
    Wayne2970 [OP] Member
    Wayne
    North Texas
    07 Dbl Cab
    Stock
    2007 4x2 Double Cab 65K
  2. Sep 27, 2015 at 5:28 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Tight bolts that will need to be loosened and removed.
    Shocks that will be removed and exchanged for 5100s.
    5100s will be shiny and nice looking, the other shocks will be dirty.
    Bolts will need to be returned to their locations and tightened.
    That's about what to expect.
    Fronts need a coil compressor or you can use the floor jack method (be careful, do what is comfortable for you). Other than that, it's pretty straight forward. If you're doing it yourself and don't know what you're doing (and have the right tools) you'll probably burn an hour or so with the fronts, maybe longer. Definitely less than an hour per side but depends on how the bolts are (rusted stuck) and how your luck unfolds. Rears are easy, 30 minutes should knock out both sides.
    If you're having a shop do the install, it should be less than an hour and a half of work, by far. Air tools and legit compressors for the coils make quick work.
    TheTrooper likes this.
  3. Sep 27, 2015 at 5:34 PM
    Wayne2970
    Wayne
    North Texas
    07 Dbl Cab
    Stock
    Sorry...I was looking for ride characteristics vs the stock SR5 shocks
  4. Sep 27, 2015 at 5:43 PM
    VA Tacoma
    VA Tacoma Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    I used the ring groove to level the front. Have not noticed any negatives on the ride quality.
    Good luck
    Wayne2970[OP] likes this.
  5. Sep 27, 2015 at 5:50 PM
    T4RFTMFW
    Damn.
    Well I didn't notice anything over stock at .85. At 1.75 it was noticeably stiffer and I wasn't able to get a good alignment after that so the road handling was kinda unimpressive.
    At 0 it should be pretty unnoticeable, in a good way.
