What can I plug into the back of truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lisa, Aug 17, 2010.
  1. Aug 17, 2010 at 5:19 PM
    lisa
    lisa [OP] Well-Known Member
    Lisa
    Manitoba
    09 DC TRD Sport
    Access Tonneau,U Guard Step Bars,Short Antenna,Clear Bra,AFE Pro Dry,Cylon Front Emblem by MetalMaster,Cylon Raider Decal,Cylon third brakelight decal and a hanging cat on the tailgate...:)
    Well..I am taking the two nieces for a weekend camping trip! We are just going to tent it by a lake and do a little swimming and fishing.What I am wondering is what can my inverter(?) in the truck bed handle?..Can I plug in a kettle to get my morning caffine fix? Should the truck be running?..I was also thinking of bringing a portable flourescent lamp ( a 3 ft tube one I use for work) ..would I be able to use that without running down the battery? Or should I just spring for an electrical site?Can I hear your experiences of using the inverter? Thanks in advance :)
  2. Aug 17, 2010 at 5:23 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    you can use lights, radio, even TV, i dont think a coffee put would work. it will not have enough juice to power anything with 2 stage motors like a saw, drill, air compressor. i think coffee pots kinda a 2 stage or whatever its called
  3. Aug 17, 2010 at 5:30 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    bring a perculator,and make a camp fire.
  4. Aug 17, 2010 at 6:32 PM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    400W / 120 VAC = 3.3 Amps. Look on the appliance info tag somewhere to see the watts/amps output. You can do 400W or 3.3 Amps with the engine on and in park/neutral.
  5. Aug 17, 2010 at 6:40 PM
    lisa
    Lisa
    Manitoba
    09 DC TRD Sport
    Thanks,guys..I guess the kettle is out..1000W..well..I may have to find a campfire perc....it's good to know I can use it for other things..the light will come in handy.Thanks for the input!
  6. Aug 17, 2010 at 6:45 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    it powered my jigsaw and small shop vac jsut fine. not that either of those are usefull to you in this situation , but that's an idea of the power. i have a ryobi 18 volt powertool set that cam with a really bright flashlight that uses the ryobi rechargable batteries and i charge them up all the time with the truck.
  7. Aug 17, 2010 at 6:51 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Blender for the drinks?
  8. Aug 17, 2010 at 6:51 PM
    lisa
    Lisa
    Manitoba
    09 DC TRD Sport
    Thanks,Colin...but a battery charger won't make me coffee..j/k..:).Good to know about those other things tho.I just checked the inverter in my work truck..only 600W..damn..should have went full boar with the corporate card and bought a bigger one..lol.
  9. Aug 17, 2010 at 6:54 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    FWIW - You can run the inverter at full capacity for over an hour with the truck off before you need to be worried about a dead battery. I used it to plug our pop-up camper in for 3 hours a day while on a 16 day road / camping trip. It provided every bit of power to charge the rv, and from the rv battery, we ran our pump, lights, inverter(for DW's hair dryer...), phone chargers, everything.
  10. Aug 17, 2010 at 7:02 PM
    Big Red 10
    Big Red 10 Member
    VA
    TRD Off Road
    Hey Colin B17 - The outlet is cool. Just cn't figure out a real reason to use them, I don't think I could let the truck run in idle while charging batteries. Anything else? And how long did that take?
  11. Aug 17, 2010 at 7:06 PM
    Big Red 10
    Big Red 10 Member
    VA
    TRD Off Road
    Hey Isthatahemi - thanks for your answer. Would you clarify though? I am sure I misunderstood when yo usaid we can run the inverter for an hour with the battery OFF. By inverter you DO mean what charges the outlet in the bed? If so, I thought the truck had to be running to use it? I just want clarification because I'd like to use it sometimes but who wants to let the truck idle, killing fuel. Thanks!
  12. Aug 17, 2010 at 7:11 PM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I can run a Dremel but it trips the breaker if the cutter bogs down :p
  13. Dec 29, 2010 at 10:11 AM
    06RedComa
    06RedComa Yotas For Life!
    Kyle
    Tempe
    06 4x4 DC Sport
    Camburg 2.5" Coilovers, Camburg 1.25" UCAs, Kings, Deaver Progressive leaf pack, AFE SI, TRD exhaust, Grillcraft grille, Bed Lights, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Wanted to bump this cause i was wondering if anyone else used the outlet without the truck running and if so how long?
    Thanks
  14. Dec 29, 2010 at 11:22 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2011 Tacoma Double Cab 4x4 T|X PRO
    The "reserve rating" on the battery in my truck says 165 minutes (that's pretty big actually....) What we really need is the amp/hour rating for the battery. I've found three different formulas:
    RC x 0.3 = Amp/hours from http://www.whistlergroup.com/faq-inverters-answers.asp#04
    RC x 0.4 = Amp/hours from http://www.speedace.info/car_batteries.htm
    (RC/2)+16 = Amp/hours from http://www.chem.hawaii.edu/uham/bat.html
    Using these formulas, we have an amp/hour rating of 49.5 to 98.5 amp/hours. I'm more inclined to go with the first or second formula.
    Let's take the second formula, which gives us an amp/hour of 66. A general rule of thumb is that an inverter will require 10% of the rated wattage in amps from the battery (400W x 10% = 40, so 40Amps per hour to run 400W continuously). Taking our 66 amp/hours divided by 40 amps is just under 2 hours before the battery is no longer able to run the inverter (66/40 = 1.7 hours.)
    As has been mentioned, 400W gives you a maximum of 3.3 to 3.6 Amps at 110/120. Not a lot. A circular saw usually draws close to 15 amps. We'd need a 2500W inverter to run any sort of serious power tool. And of course, the amount of time to run a 2500W inverter goes way down.... (I figure 15 minutes of continuous use before the stock battery is depleted.....)
  15. Dec 29, 2010 at 11:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I used a little MR. COFFEE maker (the 4 cup version) on it. Brewed hot water with it and made hot chocolate (with truck running).
  16. Dec 29, 2010 at 1:57 PM
    7068ca
    7068ca Member
    central Alabama
    2011 TRD Offroad Access
    Mudflaps shortened by 3"
    I could not get power to the outlet in my 2011 TRD offroad with the engine off. The owners manual also says the engine must be running.
  17. Dec 29, 2010 at 2:54 PM
    06RedComa
    Kyle
    Tempe
    06 4x4 DC Sport
    My 06 lets me run it if the key is in the on position and the button has been pushed in
  18. Dec 29, 2010 at 3:44 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You can run Christmas lights
  19. Dec 29, 2010 at 4:00 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I use mine to inflate a 9' pontoon boat...works great.
  20. Dec 29, 2010 at 4:19 PM
    Tippett's TRD
    Tippett's TRD Well-Known Member
    Josh Tippett
    Lake Linganore, Maryland
    2010 Speedway Dbl Cab L/B 4x4
    6" Pro Comp Suspension Lift, LEER Cap, NFAB Nerf Bars, Avid Off-road Bar, K&N Intake, Weathertech Liners, 2011 Grille, BedRug, Westin Taillight Guards, Tinted Windows, RedLine Hood Struts, Mag Lite Mod, Stubbie Antenna...
    I went tailgating and used a SMALL george foreman grille... it worked well, but would trip off every once in a while. Made some damn good dogs though :)
