What can it be?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Crikks11, Oct 14, 2016.
  1. Oct 14, 2016 at 10:22 PM
    Crikks11
    Crikks11 [OP] Member
    1997 Taco v6 4wd
    My taco idles about 200rpm over idle 750.
    Things done
    New vacuum hoses clamps
    Iac cleaned new gaskets
    Tb cleaned new gaskets
    Maf cleaned
    Kn air filter
    New plenum gaskets
    Elbow greased plenum
    New fuel filter
    New water pump t belt pulleys tensioner
    New v cover gaskets
    Symptoms
    When first started idles perfect
    After putting in gear around 850-950 rpm if I slap it around 5k rpms it goes back to perfect idle
    Any suggestions much appreciated
  2. Oct 14, 2016 at 10:22 PM
    Crikks11
    1997 Taco v6 4wd
    Manual tran
  3. Oct 14, 2016 at 10:26 PM
    Crikks11
    1997 Taco v6 4wd
    No codes tune up done 2 months ago
  4. Oct 15, 2016 at 1:16 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Are you sure the throttle is closing completely? That's all I got.
  5. Oct 15, 2016 at 2:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You do lube the throttle linkage at least at every oil change ??
    Have you checked around the pedal that the pedal is able to move freely ??
  6. Oct 15, 2016 at 1:00 PM
    Crikks11
    1997 Taco v6 4wd
    Pedal is moving freely did not lube tb. I just went thru my first oil change last month. What is best for lubing white lithium grease. Graphite grease or just plain?
  7. Oct 15, 2016 at 1:04 PM
    grntacoma
    grntacoma Member
    Austin
    South louisiana
    2000 toyota tacoma 4x4 5spd
    Deck plate, 3inch lift,2 inch wheel spacers,33inbfgkm2,aero turbine exhaust
    Mine did this after cleaning sensors and throttle boddy and changing vaccum hoses. After about 4 days everything was back to normal
  8. Oct 15, 2016 at 2:08 PM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Could it be related to your AC? Usually when the defrost/AC is on the idle speed is bumped up due to the increased load of the compressor. I can't say for sure this happens on my truck, never noticed, but every other car I have had did this. I don't know how this functions though, i.e. what to test or which might be malfunctioning if it is. However you might try cycling the AC on and off by hitting the AC button (with the HVAC fan on) and see if you notice any change in the idle speed.
  9. Oct 15, 2016 at 2:44 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I use Kroil to spray the throttle linkage because I always have a can handy
  10. Oct 15, 2016 at 5:49 PM
    Crikks11
    1997 Taco v6 4wd
    @grntacoma I'll see its been 2 days so far.
    @travelfeet as I turn on heater/fan they jump up and than settle. With ac on yes a touch higher
    @Wyoming09 Regardless if it will help thank ou for the tip
    @DrZ yes it's closing correctly
    Thank you for response and possible resolutions I'll keep looking if you'd come across Sth please post it if I find something I'll do the same
