What can you tell me about DIFF DROPS?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jaren1512, Jun 21, 2012.
  1. Jun 21, 2012 at 3:30 PM
    Jaren1512
    Jaren1512 [OP] Well-Known Member
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    Deck plate mod, all chrome plasti dipped, 32" BFGs, fogs, 3" bilstein coilover 5100s/5150s in the rear, manaflow exhaust, smoked tail lights, rooftop lightbar, upgraded alpine sound.
    Just put a 3" lift on my taco and was told i needed to install a diff drop kit on it in the near future. What is it? Why is it necessary? THANKS!
  2. Jun 21, 2012 at 3:31 PM
    Manwithoutaplan
    ID
    diff drop gives your Cv axles a better angle. If your CV axles are to steep of angle they will wear out quicker.
  3. Jun 21, 2012 at 3:36 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    And that severe angle can cause your boots to tear, which will also wear out you axles faster.
    The effectiveness of diff drops is debatable. I have one because the few bucks possibly wasted is worth it to me if it helps an CV just a little bit.
  4. Jun 21, 2012 at 3:53 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    thats all i needed to hear! 30 bucks now will save me a couple hundred later. Was it pretty easy to install?
  5. Jun 21, 2012 at 3:56 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Paging Chris4x4.... I want to hear his opinion on these things again. I forget what it was but he convinced me they were pointless
  6. Jun 21, 2012 at 4:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They are not needed. They only lower the front of the diff. This in turn, only lowers the axels about 1/3" or so, and changing the actual angle about 1.6* They also reduce ground clearance by the full 1". Odds are, if there are vibes due to a lift, its due to impropperly torqued bolts/nuts, bad alignment, etc.
  7. Jun 21, 2012 at 4:24 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Exactly. Diff drops are worthless junk they try to sell you to make $ off of nothing. Do not buy into their lies.
    Also, vibes are sometimes due to carrier bearing angle.. Sometimes. Though I had no vibes with 9" of lift.
  8. Jun 21, 2012 at 4:25 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    also MJP2 has some strong words regarding diff drops :laugh:
  9. Jun 21, 2012 at 5:09 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    There is also a large debate about 1st gen vs 2nd gen. The general 2nd gen consensus is they dont work (as you can see above), there are many more 1st gen diff drop supporters.
  10. Jun 30, 2012 at 12:12 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    So I keep hearing this talk about "vibes". Im not really sure what exactly that means. With the lift I have right now i feel damn near every bump in the road. sometimes it feels like my truck jumps 6 inches left or right every time i hit a tiny bump. is this something the diff drop would fix? how can i improve the ride quality?
  11. Jun 30, 2012 at 12:13 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    I have one on my truck (1st gen) and it has helped alot.
  12. Jun 30, 2012 at 1:17 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    You said in a thread you created you have a spacer lift. You answered your own question as to why it rides like shit. Diff drop wouldn't do anything. They don't do anything as is.
