What carport do you have?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grego67, Jun 27, 2015.
  1. Jun 27, 2015 at 4:24 PM
    Grego67
    Grego67 [OP] Well-Known Member
    2015 4x4 V6 Tacoma
    Hello everyone. My house does not have a garage and I would like something park my truck under to keep it out of the sun in the summer, and to keep it from getting burried in snow in the winter. I have a spot along the side of my house that could fit a carport big enough to completely cover my truck. What kind do you all have? How does it stand up to wind, and is it strong enough to hold snow without caving in? Any input would be great. Thanks.
  2. Jun 27, 2015 at 4:50 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    My 07 Taco sits in the sun year round. Poor little thing! The only protection is a windshield screen. We don't get snow but it gets pretty hot in the summer. Paint is holding up. I'll be interested to see what is available too.
  3. Jun 27, 2015 at 10:10 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If you own the house, I would build your own with 4x4 posts and a sloped roof. You can decide between steel or composite roofing depending on what works best for your budget and style.
  4. Jun 28, 2015 at 5:52 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    I have a 20 x 22 (12ga) frame carport, my truck does not like sitting out in the bad weather. :thumbsup:
  5. Jun 28, 2015 at 6:13 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    My 2011 sits out year round. So far only the headlight lens are starting to yellow.
  6. Jun 28, 2015 at 1:58 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You might want to consider building something than buying. Any carport I have ever seen is really flimsy and looks like hell after a few years. I would guess you could build one cheaper than buying if you did the labor yourself. Just some 6x6 posts cemented in the ground with a slanted roof would be alot sturdier than some of the carports out there. As for the roofing, I used this for my shed....
    http://www.lowes.com/pd_12747-1115-158_1z13cgm__?productId=3010607&pl=1
    I'm no carpenter but it is easy to use and it looks great. Just use the correct nails.
  7. Jun 28, 2015 at 4:32 PM
    Grego67
    2015 4x4 V6 Tacoma
    Thanks a lot for the suggestions guys. I will look a little more into what I would need to build one. No doubt I could build one for cheaper. The some what nice aluminum I found are well over a $1000. Definately not trying to spend that much on something that will probably only last a couple years.
