What caused change in my avg MPG?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by grangicon, Jun 11, 2023.
  1. Jun 11, 2023 at 4:14 PM
    grangicon
    grangicon [OP] Well-Known Member
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    I’ve been getting 21-22 mpg hwy. I went in a trip this weekend, the same trip to visit my parents that I’ve been getting 22-22 on, and I’m hovering at 18.3-18.7.
    I got new tires Thursday (Goodyear wrangler workhorse AT 265/65R17) to replace the Toyos that came with the truck 50k miles ago (in the same size).
    My transmission also spent a LOT of the drive hunting and my engine spent a lot of the drive straining to maintain the posted 75 mph on virtually flat land.
    What gives? Does my truck suck now?
  2. Jun 11, 2023 at 4:16 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    bad gas is my first guess
    Stevie17 and BC Hunter like this.
  3. Jun 11, 2023 at 4:17 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Wind direction? Did you use 87 or 88 octane gas?
    usmc2msu likes this.
  4. Jun 11, 2023 at 4:19 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The tires are more than likely heavier, and even the slightest bit of headwind will have a dramatic impact on MPGs. Since you were road trippin, you could have kept a higher highway speed, which also dramatically reduced MPGs.
    I just went Friday to shoot a Saturday match. The drive is 140 miles, 100 being straight highway. Going out I had a slight tailwind, going home I had a slight headwind, going the same speed, I got just over 1.5 MPG less.
  5. Jun 11, 2023 at 4:19 PM
    grangicon
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    Same as I’ve been using. 87 I think
  6. Jun 11, 2023 at 4:21 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Truck is fine, the tires suck.......suck gas that is. I give kudos to the good years on my truck but I took an almost 4mpg hit when I put them on.
    Chew likes this.
  7. Jun 11, 2023 at 4:22 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    wind, speed , gas are all variables. But if it does it again trade it in for the 4th gen
    BC Hunter and Chew like this.
  8. Jun 11, 2023 at 4:22 PM
    TacoDinner
    TacoDinner Well-Known Member
    Maybe the new tires were underinflated
    Squirt and Chew like this.
  9. Jun 11, 2023 at 4:22 PM
    grangicon
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    Hm
    Headwind is a given here. No getting away from it. Didn’t consider the tires might be heavier despite being the same size.
  10. Jun 11, 2023 at 4:23 PM
    Tacospike
    Two Trucks
    Drive the trip six more times and calculate from there
    Stevie17 likes this.
  11. Jun 11, 2023 at 4:24 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Maybe the old tires were over inflated??
    Hahaha, just messin with ya! Good point though, tire pressures will also have a noticeable impact too.
  12. Jun 11, 2023 at 4:24 PM
    grangicon
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    Oof
  13. Jun 11, 2023 at 4:25 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    This! One data point is an anomaly.
  14. Jun 11, 2023 at 4:25 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    If you check the websites of the respective tires (old and new) they should have the weights of each.
    I also agree that it could be due to under-inflation. Although I would guess it’s probably just the build of the tire itself.
    Stevie17 and grangicon[OP] like this.
  15. Jun 11, 2023 at 4:25 PM
    grangicon
    Stephen
    Lubbock TX
    '18 TRD Sport
    Camper top
    Both actually. 3 tires stayed at 31psi, but the 4th got bumped to 38 last time I had a flat fixed, and I’ve been waiting ever since to see if it would go down
    Chew[QUOTED] likes this.
  16. Jun 11, 2023 at 4:26 PM
    Rusty66
    Rhode Island
    Ha ha, I actually over inflated mine to see if it helped and it does, not 4 mpg better but maybe two?
  17. Jun 11, 2023 at 5:13 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Got this yesterday doing 75-77 mph...
    Stock everything tires are at 35psi.
  18. Jun 11, 2023 at 5:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Even though the new tires are the same size, they could be as much as 1" taller than your old tires. Tires wear down as they wear and by the time you have 40,000 miles on most of them, they are in reality one size smaller than when new. You were driving about 5% faster, and farther than you were on the old tires.
    When your speedometer said 75, you were closer to 79. And in my experience right around 70 mph is like hitting a wall as far as fuel mileage goes. Anything over 70 kills fuel mileage; getting close to 80 really kills it. You also drove farther. If your trip meter said 200 miles, you drove closer to 210.
    Chances are good you were getting false, optimistic readings with the old tires since they were undersized in relation to your trucks computer. In my experience moving up to 265/70/17's give a more accurate speed and odometer reading. The numbers you're getting now are probably accurate and the old numbers were inaccurate.
    Old goat1914 and Squirt like this.
  19. Jun 11, 2023 at 5:56 PM
    B1gDaddyT
    B1gDaddyT Well-Known Member
    2019 Cement Taco TRD OR 4x4 DCSB
    New tires have greater rolling resistance. It'll get better over time but fresh tires are usually always mpg killers.
  20. Jun 11, 2023 at 6:17 PM
    happyvirus
    happyvirus Well-Known Member
    I get about 16-17 MPG on 90% hwy driving.
    I don't accelerate hard. How are you guys getting such high MPG?
