What causes speed wobble that's not tire balance/alignment?
Discussion in 'Technical Chat' started by mermalady, May 18, 2018.
  1. May 18, 2018 at 2:24 PM
    mermalady
    mermalady [OP] Well-Known Member
    I have a pretty bad shake at 60-70mph, ish. Stops after going past that, though I usually just drive under that speed.
    I've had my tires balanced and aligned twice, just to be sure. The first time it helped, but in the year or so since it's gotten worse again. No noticeable cupping on wheels and no tire place has mentioned anything.
    What could it be? Should I be worried about tie rod ends/ball joints/wheel bearings? Should I be off the road? What should I check and how?
    No other symptoms that I can tell; I don't *think* the steering feels loose but I'll listen to your favorite way to check that.
    edit: I should mention, new shocks all around, and new discs up front. Though I did have to right my truck after a partial roll (see my post history)
  2. May 18, 2018 at 2:35 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Have you ever changed the wheel bearings and how many miles are on the truck
  3. May 18, 2018 at 2:37 PM
    mermalady
    Nope, and 190k. No whine or roar from the wheels.
  4. May 18, 2018 at 2:38 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Have you ever changed the shocks ?
  5. May 18, 2018 at 2:39 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    do you have all of your lug nuts?
    Comatose likes this.
  6. May 18, 2018 at 2:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    Could be a broken belt in a tire. Sometimes they'll balance ok.
    Rotate tires and see if vibration moves.
    inwood customs likes this.
  7. May 18, 2018 at 2:40 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The last balance was a year ago?
    Roadforce balance?
    Not a walmart balance right?
  8. May 18, 2018 at 2:43 PM
    mermalady
    There was a ballance a year ago, and then one a month ago after the roll. Nope, not walmart, and the guy passed muster with me for 'knowing his stuff and actually giving a shit about his work'.
  9. May 18, 2018 at 2:43 PM
    mermalady
    read my post. New as of 2k miles ago.
  10. May 18, 2018 at 2:45 PM
    mermalady
    Hm, i don't think it was road force. Could it make that huge of a difference?
  11. May 18, 2018 at 2:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. IF there is no tire damage and IF the tech knows how to use the machine right and IF they are willing to do the extra work needed if the machine indicates it's needed.
  12. May 18, 2018 at 2:49 PM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    check your tie rods for play
    hoverlover likes this.
  13. May 18, 2018 at 2:51 PM
    mermalady
    Best way to do that, anything besides having someone in the truck wiggling the steering wheel and me underneath watching?
  14. May 18, 2018 at 3:00 PM
    TacoMoose
    2017 Tacoma OR
    absolutely, pull the emergency brake, jack the front up so both the front tires are off the ground, and hold the tire in the 9 and 3 position and move it back and forth. any small amount of play will cause a vibration at high speeds. you have inner tie rods, and outer tie rods. the outer is rod is the one closest to the wheel, the inner tie rod is the one with the boot on it. it helps if someone is under it looking to see for movement, but if you dont have someone else you can just go by feel. a good tie rod wont have any loose play, the tire will be tight.
  15. May 18, 2018 at 3:02 PM
    mermalady
    I just moved and just have a single jack with me- is it still useful if i do it one wheel up at a time?
  16. May 18, 2018 at 3:02 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Check your ball joints as well.
  17. May 18, 2018 at 3:03 PM
    mermalady
    How do?
  18. May 18, 2018 at 3:13 PM
    hoverlover
    Mostly Zip-Ties
    This article is more thorough than I'm willing to type out on my phone. They may not be the culprit themselves but if your steering geometry is off and your ball joints are at the end of their lifespan you'll be a position to develop that harmonic vibration.
    https://www.google.com/amp/s/m.wikihow.com/Check-Ball-Joints?amp=1
    In Jeeps, at least.
  19. May 18, 2018 at 6:43 PM
    TacoMoose
    2017 Tacoma OR
    yes you can do it one at a time
  20. May 19, 2018 at 3:18 PM
    mermalady
    thanks!
