What causes speed wobble that's not tire balance/alignment?
Discussion in 'Technical Chat' started by mermalady, May 18, 2018.
  1. May 19, 2018 at 7:59 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not the most likely cause, but you could have a separated tire. Some people think this problem would be easily seen. Not always the case.
  2. May 21, 2018 at 8:06 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    If tires and all other parts are fine check to see how many rocks are stuck in you're tread or mud on the back side of a wheel. Those two problems plague me on a regular basis. Either one will cause a wobble with a perfectly balanced tire. Or, if you have the tires balanced once all the rocks are thrown out or the mud is washed of you'll get a wobble/vibration.
