What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. Aug 31, 2018 at 4:07 PM
    #201
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    My cousin (owner/operator of a tree care company) has one in his saw bag, when I was working with him I used it quite a bit and it worked well for me, he typically doesn't sharpen chains as by his calculations it cost him more to sharpen a chain then to replace it. he keeps his used chains and sharpens them when he makes time but he would rather spend his home time with his wife and kids vs sharpening a chain.
    wilcam47[QUOTED] likes this.
  2. Jan 1, 2019 at 6:25 PM
    #202
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    I run and use 3 diff saws. Only because I inherited 2 from my great father-in law (now passed on). All Stihls: 310 20inch, 021 16inch, and a 170 14 inch. All run great and I would be hard to convince any other brand would be better.
    As a note: all seem to have their own starting quirks (not bad), once you know your saw they should always start the same depending on how cold or warm the saw is on initial start-up. I would think this should be the same for any brand of saw as long as you keep the air filter breathing well. Just remember if you are seeing excessive dust in your filter you are probably (trying to) cut with a dull chain. You might as well try to "piss up a rope" and you are wasting time to say nothing of overheating your bar. The overheating of the bar is evident if you see any "bluing" of the steel anywhere on the bar
  3. Jan 4, 2019 at 8:09 PM
    #203
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    I have a husky 350 that I have had since 2002 and I beat the ever living piss out of it every year, not sure how or why it still works. I also have a stihl 028 that was given to me, that thing is heavy and impossible to start. I need a new saw but not sure what to get, I want something that will run a 24" bar if needed so I can give my 350 a break once in a while. I want a commercial/professional saw but need to do some research, maybe get a used jonsered 2071 or something like that.
    Toyko Joe likes this.
  4. Jan 5, 2019 at 5:25 AM
    #204
    ralfnjan
    ralfnjan Well-Known Member
    I've been trying to resurrect a older Stihl 038 AV Super. Hadn't run in hyears, but some gas in the plug hole...ran it out. Gas in the carb throat...ran it out. Starts on the first pull after it's run a bit. Just put a new intake manifold and impulse line on it...same problem. A carb kit is on the way. It's like the diaphram doesn't pull fuel into the carb on start. After it's had a little run it will pull fuel. The diaphram was a little crunchy sounding. If the kit doesn't fix it it's worth an aftermarket carb for such a good saw.
    It will make a 4th saw for 2 farms to work with. 1 Echo, Husky 365 SP, new Husky 365 and the Stihl. Only 2 of us cutting at a time.
  5. Jan 5, 2019 at 6:00 PM
    #205
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    My Dad came up with a method for starting his Stihl, which is also hard to pull/start. Cut yourself a piece of wood on which you can put your weight to trap and stabilize the saw to the ground. Works really well. Sorry, I don't have a pic this evening, but it's a simple concept you could make work many ways.
    His is shaped like this (works on either side depending on preference/dominant hand):
  6. Jan 5, 2019 at 6:07 PM
    #206
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Stihl MS250 with 18" blade. Doesn't get heavy use, but it's taken down several trees and cleaned up a lot of limbs & debris. I do keep it in the back of my truck during hunting season as there are often downed trees on the forest roads that I frequent. Had a freak snow storm one October that downed a lot of Alders along the edge of the road. I had to slowly cut my way out for about 2 miles.
    underaroof likes this.
  7. Mar 9, 2019 at 8:13 PM
    #207
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    ^^I also run a Stihl MS250 with 18" bar. Great for firewood and trees across the road. Nice and light for brushing.
    wilcam47 likes this.
  8. Mar 10, 2019 at 6:15 AM
    #208
    ralfnjan
    I got that Stihl running! Intake manifold, impulse line, carb kit. 2 pulls on full choke (don't wait for a fire) then high idle choke until it fires, then "run" and it goes every time so far.
    I learned a bunch I didn't know before. An echo, husky and stihl all with Oregon bars...we'll just put a 24" on the Stihl. No we won't! The slot for mounting to the power head are different from each other. Stihl mounting studs have a shoulder on them, the bar slot is widest. Husky is narrower, Echo is narrowest...no bars are interchangable. I've only ever dealt with one brand of saw at a time in the past (almost 40 years cutting my firewood), so this never came up before.
    Now the only problem is the Stihl leaks bar oil when it sits between uses. First world problem, I know. Not much oil in total, but messy. I need to check out videos on oil pump replacement. And need to decide on bar/chain size for the Stihl...24 like the other saws, or stay with the 18? Probably better see how it works before spending more money on it. Total investment so far: $35 parts, $45 shipping parts.
    Ralph
    Taco-Grinder and wilcam47 like this.
  9. Mar 10, 2019 at 2:50 PM
    #209
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    18" is fine...no need to run a bigger one, might bog it down too much is my only thought. Get a chainsaw case, then any oil just leaks in the case ;)
  10. Mar 10, 2019 at 2:55 PM
    #210
    Guitarman
    Guitarman Member
    2015 Tacoma TRD Sport 4x4
    Center counsel light, Topper w/ LED lights, JBL Sound system, Locking tailgate, Towing Package, Bed Mat
    Husqvarna and Stihl. Inherited the Husky and bought the Stihl before the Husky came into my life. Both real fine saws.
  11. Mar 12, 2019 at 8:42 AM
    #211
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Stihl 290, 271, 041. Also have a pro grade 026 with the lightweight engine block (magnesium?).
  12. Mar 13, 2019 at 5:49 AM
    #212
    ralfnjan
    The only problem running the 18" bar on the Stihl is most of the son in laws wood is over 20" diameter...up to 30 sometimes.
    And that's 2/3rds of the wood I cut in a year.
  13. Oct 4, 2019 at 6:43 PM
    #213
    95 taco
    95 taco Battle Born
    Dad killed his MS170 today, set it on the track of the skid steer and then forgot and moved the skid steer.
    He wanted to replace it anyway and will be going to check out a 261 tomorrow.
    E204A0F0-CDE4-4AB4-8503-FE229FDE58BB.jpg 1C58098B-F57B-4FB4-94C4-386580782EC4.jpg
    Coolerman and wilcam47 like this.
  14. Oct 27, 2019 at 8:19 PM
    #214
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Broke in my new MS 461 today, ran the first four tanks of fuel through her. E7EF9724-7241-4786-9748-14ECDCFD5C8D.jpg
    Opted to go with the 32” bar.
  15. Oct 27, 2019 at 8:36 PM
    #215
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    I have a Poulan that I got from my dad. It's probably about 50 years old. I used it last week to cut off some fence posts and cut up some landscape timbers to put in the trash.
    Gritto and wilcam47 like this.
  16. Oct 27, 2019 at 8:38 PM
    #216
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I've got a little Stihl MS251 w/ a 18" bar that i've given a good workout at our ranch in TX. I don't cut any big trees with it, but it does a great job w/ small oaks and cedar. I keep 3 chains and swap them out as needed. I will say I don't waste my time shappening the chains, as its only a few bucks to have my local shop do it.
    This would also be a great saw for the average do it yourself guy, or to throw in the bed of your truck for a trail saw. Compact and lightweight.
    geekhouse23, 95 taco and wilcam47 like this.
  17. Dec 8, 2019 at 5:24 PM
    #217
    yeahkkyle
    yeahkkyle Well-Known Member
    Kyle
    PA
    2002 Tacoma TRD Offroad 3.4L 5spd
    I have a MS361 that I picked up used back in 2014. Runs great. I wouldn't mind picking up another Stihl in a smaller model to run a 16'' bar.
  18. Dec 8, 2019 at 5:29 PM
    #218
    Tallgrass05
    Tallgrass05 Well-Known Member
    I have an Echo CS400 with an 18" bar, it's been reliable for a number of years. I got a DeWalt cordless chainsaw with a 12" bar during the summer, I've just used it for some trimming but it is way handy.
  19. Dec 8, 2019 at 5:37 PM
    #219
    Pickup90
    Pickup90 Well-Known Member
    North Carolina
    09 DCLB TRD Sport
    MS271 with a 20" bar. Works great for my needs!
    95 taco likes this.
  20. Dec 8, 2019 at 5:40 PM
    #220
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    STIHL MS360 for felling and sectioning, STIHL MS280 for bucking and limbing.
