What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. Nov 6, 2020 at 4:19 PM
    #341
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Sharp Blade = Big Chips
    Dull Blade = Saw Dust
  2. Nov 6, 2020 at 4:23 PM
    #342
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    You might have to file down the depth stops slightly
    95 taco and Sig45 like this.
  3. Nov 6, 2020 at 4:23 PM
    #343
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Farm Boss!
    95 taco likes this.
  4. Nov 6, 2020 at 4:23 PM
    #344
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Angle may have been too flat. I always use a round file at 30 degrees. As I’m moving forward I twist slightly in a clockwise motion
    Edited
    if a new chain it shouldn’t be an issue but the rakes might need to be adjusted slightly if an older chain. I don’t do this often because if you don’t do it right it will try to cut circles
    95 taco likes this.
  5. Nov 6, 2020 at 4:25 PM
    #345
    Sig45
    Mark
    Maine
    Did you also file down rakers?
  6. Nov 6, 2020 at 4:51 PM
    #346
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thanks, if the bite limiters are filed down too much it will bog but what about if the bite limiter needs to be filed?
    That's what I was leaning towards.
    I'll try 30*, I didn't check with a square but the marks on the harbor freight sharpener said it was about 35*. I typically use a round file but they're all at work so I borrowed the electric sharpener.
    The chain is pretty old, about 2 years, maybe 50 cutting hours on it, it's been sharpened a few times by hand.
    Negative, I didn't have a flat file on hand to touch them.
    I'm considering getting a 20" skip tooth chain for the 20" bar and going with an 18" bar for my general use, the 20" seems on the verge of too much bar for the 271 and I only need the 20" for felling and flush cutting.
  7. Nov 6, 2020 at 4:57 PM
    #347
    Sig45
    Mark
    Maine
    If the rakers are too tall, they'll prevent the teeth/cutters from cutting and you'll see a lot of dust as a result. If the rakers are too short, the teeth/cutters will grab too much wood and that could cause bogging down if the saw is underpowered for the blade/bar setup.
    95 taco[QUOTED] and Pointeman like this.
  8. Nov 6, 2020 at 4:57 PM
    #348
    Pointeman
    Mark
    No need to be super precise it is more of a uniform angle. Too steep it dulls quickly and too flat will bog down the saw. Either one will also cause your saw to buck or kick back more aggressively. One thing you mentioned is that you were stumping with it...that being said you may have hit dirt or some stones that took the sharp right out of the chain.
    95 taco likes this.
  9. Nov 6, 2020 at 5:01 PM
    #349
    Sig45
    Mark
    Maine
    For my usage, I've found that I have to file down the rakers every 3rd sharpening.
    95 taco and Pointeman like this.
  10. Nov 6, 2020 at 5:01 PM
    #350
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Usually just walk with mine..
    95 taco likes this.
  11. Nov 7, 2020 at 2:41 PM
    #351
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Went to brother joes this afternoon and ran a tank through the new husky 550... what a nice saw. Couldn’t be happier . :thumbsup:
    scottalot, Sig45 and Pointeman like this.
  12. Nov 7, 2020 at 2:45 PM
    #352
    Pointeman
    Mark
    T-yoda[QUOTED] likes this.
  13. Nov 7, 2020 at 2:49 PM
    #353
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    I decided not to do much today just because it’s so nice out and I felt kinda blah all morning. But kicked things in gear enough to hang with brother joe. :thumbsup:
    Pointeman[QUOTED] likes this.
  14. Nov 7, 2020 at 2:51 PM
    #354
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    F27313F4-3BE9-4750-A0B5-30763CC2F5C0.jpg Did this Thursday in my day off... flew solo and had 4 wagons full ... not much of a day off ;-) I love it that way:thumbsup:
    scottalot and Pointeman like this.
  15. Nov 7, 2020 at 2:53 PM
    #355
    Pointeman
    Mark
    I don’t know...that sounds like a great day off to me. Hahaha. Some of my best memories involve cutting and splitting firewood. Stay safe...
    scottalot, Sig45 and T-yoda[QUOTED] like this.
  16. Nov 7, 2020 at 3:02 PM
    #356
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Heck yea... we play it safe and recycle the laid trees. So much goes wasted. We give most of the wood away to whom who “need” to heat there homes. Been doing it 2 years now. Well this is our second year. Makes you feel good inside knowing you can help people by just giving wood.... go figure ;-)
    Pointeman[QUOTED] and Sig45 like this.
  17. Nov 8, 2020 at 12:15 PM
    #357
    95 taco
    95 taco Battle Born
    I took the bite limiters down a hair and re-sharpened the chain, it cuts really well horizontally but the grain of the wood must stop the cut progress vertically, it still doesn’t like to cut down.
    T-yoda and Pointeman like this.
  18. Nov 8, 2020 at 12:31 PM
    #358
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Very hard to cut that way.... no matter what your using
    Sig45, 95 taco and Pointeman like this.
  19. Nov 10, 2020 at 3:48 PM
    #359
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Iv got the urge to fire up the new saw again!
  20. Nov 13, 2020 at 3:40 PM
    #360
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Going to drop an oak tree tomorrow morning that’s already been limbed:thumbsup: sounds easy ... we’ll see how this new saw does. It’s not close to any structures and we’ll haul to brother joes to split and add to the pile to give out next year:thumbsup: only concern is that the ground is very moist due the all the rain we’ve had last couple days. We may have to work them 4x4’s to haul the wood out... :fingerscrossed:
    Pointeman likes this.
