What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. Nov 18, 2020 at 7:12 PM
    #401
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Those are some serious sawing pants! Iv upgraded from holy jeans to non holy jeans... I got tired of emptying my boots filled with wood chips!! I’m going consider chaps soon.
    Sig45[QUOTED] likes this.
  2. Nov 18, 2020 at 7:18 PM
    #402
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    One close call (blade caught my pants) years ago is all it took for me to buy some chaps.
    Pointeman and T-yoda[QUOTED] like this.
  3. Nov 18, 2020 at 7:21 PM
    #403
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Finally found an Oregon website stating that the chain I bought will in fact fit my saw.... I think some of the facts are outdated and need some updating... so now I’m off to catch some shuteye ... I’ll update on the new chain after Sunday’s use.... Oregon m80 is the chain I’m running and comparing it with the sp33g ... all have a great night
  4. Nov 18, 2020 at 7:22 PM
    #404
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Glad nothing bad happened... I’ll be ordering chaps soon
    Pointeman likes this.
  5. Nov 18, 2020 at 7:27 PM
    #405
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Have you modded the muffler on that yet? Opening up the muffler makes that saw come alive.
    T-yoda likes this.
  6. Nov 18, 2020 at 7:33 PM
    #406
    sabasarge
    sabasarge Well-Known Member
    central Columbia Gorge
    2020 Sport AC MT cement
    Working on that
    Back in the early ‘70’s I was cutting cedar bolts for shakes on the Oregon coast for a living and was using a Husqvarna 36” and a Poulan 42“ and both served me very well in tough conditions.
    Now I heat with firewood only, going through about 4 cords a winter, and have two Echo’s, a 24” and a 16”, and while years back I wouldn’t have touched an Echo, today they make a fine product and mine have been going hard for years.
    T-yoda and Pointeman like this.
  7. Nov 18, 2020 at 8:26 PM
    #407
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Just my 2 cents. Unless you are cutting in the winter I wouldn’t waste money on winter blend bar oil. If you are going to run it and your bar oil is too thick to flow, then there are other cheaper options. There were times it was so cold when we were cutting that we resorted to using old motor oil (free) or canola oil (cheap.) In fact when we were trimming on certain properties (upscale communities or chicken, turkey, pig farms) veggie oil is all we could run. Yeah I know it doesn’t stick to the chain and makes a mess but it alway flowed nicely even in the coldest of temps. Also, Ethanol is a carb killer. So if your local gas station runs ethanol blend you don’t want to leave that in your saw for extended periods. I believe if I remember right. Ethanol fuel has a shelf life of 30 days. So if your not going to run it over the winter months I would empty it out and then run a stabilizer through it. I use one marketed by Stihl. Pour a little in and then run it until it’s gone or saw quits. Again just my 2 cents.
  8. Nov 19, 2020 at 2:09 AM
    #408
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    I was looking at echo as well, then I compared the weight of these units and they were couple pounds heavier. Knowing I’d be operating a saw for several hours at a time, became a factor in my decision
  9. Nov 19, 2020 at 2:09 AM
    #409
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    https://www.amazon.com/gp/product/B07NDNP32H/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    I bought 5 of these chains for my MS-250, 18". At $9 each, they're throw-away, or I can sharpen them, some lazy summer afternoon. They come seperately packaged. I have used one so far. I don't see any difference in cut speed, chip size, etc. I wondered if it might need more frequent sharpening, but even if it does, could be any number of other factors. So it is what it is. If nothing else, I won't be caught 1/2 way through a cut with a chain problem. I'll have few spares, can switch to a new one and continue. Peace of mind out here in the boonies.
    I pinched the bar in a cut once, had to remove the saw from the bar, extra bar and chain, new cut beside to release the stuck bar. Extra bar and chain saved the day.:thumbsup:
    T-yoda likes this.
  10. Nov 19, 2020 at 2:12 AM
    #410
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Have you used them yet? Wonder how they cut? My factory chain is still going strong after all the oak we cut.
  11. Nov 19, 2020 at 3:09 AM
    #411
    06Tacooo
    06Tacooo Earth Czar
    Mark
    Have seen this, not uncommon for me to cut logs on the ground. Dirt will make a few sparks. I'll cut from the top, roll the log, brush it off with a stiff scrub brush, finish cut (also helps with my aim). Notice a few sparks in low light.
    They say you should see just a little oil coming off the nose. I don't see any, but when I clean it, there's oil in the fines, and the oil tank needs refilled. There's no oil adjustment on my MS250. I clean out the vent hole, behind the chain cover when I clean up the saw, see no evidence of the chain or bar not getting enough oil.
    T-yoda[QUOTED] likes this.
  12. Nov 19, 2020 at 3:15 AM
    #412
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Iv learned to cut 3/4 of a cut, roll and finish :thumbsup:
    06Tacooo[QUOTED] likes this.
  13. Nov 19, 2020 at 3:28 AM
    #413
    riot4wyatt
    riot4wyatt Well-Known Member
    Travis
    Port Allegany, Pa
    '14 TRD off road spruce mica
    Bilstein 6112/5100 1.5" icon aal Dometic cfx40 fridge
    Lol yep. Gutted the muffler, Port and polished, and the jug is turned down for a little more compression. She's a runner!
    KB Voodoo[QUOTED] and T-yoda like this.
  14. Nov 19, 2020 at 3:37 AM
    #414
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    More POWA!! :thumbsup:
  15. Nov 19, 2020 at 4:18 AM
    #415
    Sig45
    Mark
    Maine
    There have been periods where I've run Ethanol (E10 here in Maine) without issue in my chainsaws and leaf blowers. I run it in my snow-blower and lawnmower without issue. I store both with a full tank during the off-season. They both fire right up when called to action. So far, I've not experienced the typical issues associated with Ethanol.
    :fingerscrossed:
    Some mitigation points/tips:
    1. I do try and run ethanol free in my 2 stroke power equipment
    2. Heated garage helps with the freeze/thaw cycle and the water separation issues inherent with Ethanol
    3. I mix my 2 cycle gas up in 2.5 gallon batches, so I rarely have any that lasts more than 30 days (some has and it's been fine)
    4. I use the blue Marine Stabil additive in addition to the Stihl Ultra or Husqvarna 2 Cycle Oil (which I believe also has stabilizers)
    5. If it's below freezing and I'm using equipment away from home, I'll run it dry and will not fill it up until I need to use it again
    T-yoda and Pointeman[QUOTED] like this.
  16. Nov 19, 2020 at 7:35 AM
    #416
    06Tacooo
    06Tacooo Earth Czar
    Mark
    I don't use the saw on a regular basis. I had to stop using regular gas in it, tried 93 octane, helped somewhat, but canned gas works best for me. There are cheaper brands than Stihl, I've used a couple, zero issues with them, even leaving it in the tank for long periods works. One nice thing, I can buy it online. It's shippable, even though it's on USPS website as not. I've bought it on eBay and it shipped UPS.
    I store regular unleaded gasoline for a home generator in Jerry cans, with PriG stabilizer. It will last 2+ years easily, only 10mL. (two teaspoons) per 5 gal. Actually cheaper in the long run. I rotate it through other vehicles, always keeping the freshest for an emergency. I usually have 40-50gal. on hand.
    I trashed my plastic gas cans, they all breathe, even a 55gal. steel drum will breathe, can't be stopped, leaves the moisture behind in the gas. Sealed jerry cans don't breathe, hence NO WATER left behind. Don't fill them beyond 5.0 gal., they need the extra space that's left for expansion.
    Sig45 and T-yoda like this.
  17. Nov 19, 2020 at 9:11 AM
    #417
    Sig45
    Mark
    Maine
    X2 on the all metal gas cans. I ditched plastic years ago.
    T-yoda likes this.
  18. Nov 19, 2020 at 6:20 PM
    #418
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Those look really nice. Too bad they don't have a size for me. :(
    I do wear chaps - they're not too uncomfortable.
    Years ago, when I was working in the ER while getting my EMT, a guy came in with a cut to his leg - from his chainsaw. He was lucky, only needed a few stitches. His wife, however, was extremely unhappy.
    I never cut without leg protection.
    Sig45[QUOTED] and T-yoda like this.
  19. Nov 19, 2020 at 6:24 PM
    #419
    Scott B.
    Scott
    Georgia
    I never thought about my plastic cans breathing like that. I think I will dump them and switch to metal ones (like I have for the truck.)
    Years ago, I used E10 for mix gas. My saw ran OK. For the heck of it, I tried some of the canned gas. What a difference! Now, I only run 90+ octane non-ethanol (mix or straight) in any of my power tools.
    06Tacooo[QUOTED] and T-yoda like this.
  20. Nov 19, 2020 at 6:25 PM
    #420
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Home Depot had a set . 49.00. Didn’t look very hard at them yet. Ace had a set. 130.00 ... is there that much difference between the 2? One was echo branded I think and the other was stihl
