What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. Sep 1, 2014 at 6:15 PM
    #61
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Buy another one, remove probably two nuts, take off plate, insert new one (with new chain), replace plate and nuts, tension chain, complete.
    Simple.
  2. Sep 1, 2014 at 7:02 PM
    #62
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Cool, I may do that this weekend
  3. Sep 1, 2014 at 7:06 PM
    #63
    pike588
    pike588 Red/Black life
    coastal SoCar
    08 rad red work truck
    de chromed,un badged..
    stihl 390
  4. Sep 5, 2014 at 10:43 AM
    #64
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Going firewooding with my old tough husqvarna 51 18" and my new husqvarna 55 rancher w/autotune 20" this weekend. My old 51 is my favorite. The carb on the rancher was garbage and replaced under warrenty. Now I love the autotune feature. It works great at 10,000 feet without ajustment.
    I keep 3 chislel chains rotated for each.
  5. Sep 5, 2014 at 10:48 AM
    #65
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Bars are VERY easy to replace, and every time the saw comes into my shop for anything MORE than a chain adjustment, the bar comes off, gets cleaned, the saw gets cleaned, bar is lubed, and reassembled with a sharp/new chain.
    Howard
  6. Sep 5, 2014 at 11:06 AM
    #66
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Pick up a grease gun for the roller tip too, when you get that new bar.
    Love my 51. Starts every time, no matter how cold or how hot or how long I've been using it for. It's probably cut 200 cord of wood so far and I haven't had to do a rebuild on it yet.
  7. Sep 5, 2014 at 11:16 AM
    #67
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Wow-that got HOT-is the tip sproket frozen? have that happen on occasion.
    I did not see an oil hole for the tip! is it on the opposite side?
    Take a pic of the bar guide to show the wear-with usage and wear sthe grove becomes UNEVEN and Flat with incorrect usage.
    I ususally "flip the bar" when changing chains or removing to sharpen.
    From the looks of that tip-it appears that it was NOT GETTING lubricated OR they were using the WRONG OIL.
    Bar oil works best--30 weight is a good substitute when you have nothing else.
    Were they using old motor oil or none at all?
    Easiest just to get a new bar--but if the old one is just a frozen tip-see if it has sawdust lodged in it.
    A quick look can save you some time.
    Always keep a spare bar and a couple chains-if you are going to do a lot of cutting.
    Better yet--have a second saw!!!!! LOL
  8. Sep 5, 2014 at 11:39 AM
    #68
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Received a McCulloch PM610 from my parents when I was 10yo. It still runs great to this day (25 years later) and Ive never rebuilt the cylinder or carb. It kept our house warm for years and now sits idle in my shed now that I moved to suburbia a decade ago. Last time I used it was to dispose of 20 poorly spaced trees in my yard when I moved in.
    One day Ill replace the bar oil seal so it stops leaking on my floor when I use it.
  9. Sep 5, 2014 at 11:50 AM
    #69
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Stihl MS261, and an MS170.. Plus theres an old 034 at the cottage
  10. Sep 5, 2014 at 11:57 AM
    #70
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    Stihl MS 361
    Ported
    Big Stud Mod
    20" and 24"
    Only pic I could find... Firewood hunting.
  11. Sep 13, 2014 at 7:52 PM
    #71
    Idaho
    Idaho Well-Known Member
    North Carolina
    Sithl MS 261
  12. Nov 24, 2014 at 8:56 PM
    #72
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
  13. Nov 25, 2014 at 4:38 AM
    #73
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Anyone run one of the Husky 562 XP's with Autotune? Ran one last weekend, think I'm going to have to pick one up, it was a pretty stout saw.
  14. Nov 25, 2014 at 6:28 AM
    #74
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Stihl 029 Farm Boss, 18" bar.
    I have both safety (anti-kickback) and non-safety chains, depending on what I am cutting.
    Great saw!
  15. Nov 25, 2014 at 7:09 AM
    #75
    knuckleduster271
    ohio
    98 sr5 xtra cab
    I really like mine, the 029's cut better than the newer 290 series. They have a less restrictive muffler and I think are tuned a little different. I know I can tell the difference between the two using them.
  16. Nov 25, 2014 at 7:15 AM
    #76
    Scott B.
    Scott
    Georgia
    I think I bought it in 1997. Aside from cleaning it, the only maintenance I have done is change the spark plug. (Not that there is that much to do anyway!) And, I keep my chains sharp with my Dremel tool.
    I only use it seasonally. Last year, I was cutting logs for firewood for Country Fried Weekend. We had 3 saws running - I cut way more than the other 2 combined!
    Love my Stihl!
  17. Dec 17, 2014 at 10:42 AM
    #77
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    [​IMG]Husky 351 with a Stihl blade guard. (Only thing of worth they make...)
    I kid I kid. Stihl makes fantastic saws too.
  18. Dec 17, 2014 at 10:51 AM
    #78
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Sthil Farm Boss. 7 years old, and hasn't let me down yet.
  19. Dec 17, 2014 at 10:57 AM
    #79
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I have a small tree buisness and had a husqvarna that let me down, my STIHL's are the best no questions asked love my ms-192tc
  20. Dec 17, 2014 at 11:30 AM
    #80
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    stihl 038av awesome saw
