What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. Feb 18, 2022 at 4:22 AM
    #1061
    Toyko Joe
    Toyko Joe Here for the pictures
    Building a little chainsaw box for my Milwaukee.
    Philrab, [KD] and ohcaltexscar like this.
  2. Feb 18, 2022 at 5:16 AM
    #1062
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    The saw is 20 years old and never ran right out of the box. I tuned it after the lines were destroyed by corn gas. Replaced them, started running non-ethanol gas, limiter caps removed, H/L set right it starts, runs, and idles great.
    I think a lot of Poulans just need a little tuning to be a decent saw.
  3. Feb 18, 2022 at 5:29 AM
    #1063
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I used to buy broken saws and rebuild them as a hobby and one was a Poulan Pro 40's cc variant. i went through it and cleaned it up as much as possible restoring it to serviceable condition. They have a place but im just not a fan of them at any price point. Better offerings from other manuf for slightly more money.
  4. Feb 26, 2022 at 10:45 AM
    #1064
    Steve Urquell
    I'm no pro but there are times I feel unsafe felling certain dead trees and I will cut and pull them down rather than risk being under them when they go. I hope this is useful to someone in my shoes.
    This is a 16" cherry I mow under and those big dead limbs (big one 12" in diameter) had me worried so I knew this needed to come down. It is on a slope, leaning one way while the big limb is hanging out the opposite way
    Tied it up for a cable pull. I made a cable lifter out of an old extension pole and loop a cable around the trunk with my pull cable hooked to it. Let's me pull from 16ft up the tree while setting the cable from the ground.
    Tried a Humboldt notch for the first time.
    Made a back cut and then started pulling it. It resisted and I cut a little more and drove some wedges in the back.
    When this tree hit the ground the limbs shattered so I felt justified that I had put in the extra work to pull it. Someone better than me might have just dropped it but I didn't want to risk a dead limb falling on and killing me.
    Limbed it with my Poulan which did have a sharp chain and cut the bigger stuff with the MS291 which performed flawless. The lightweight Poulan did awesome on the limbs and <8" stuff.
    My little tractor lifting and moving the estimated 650lb trunk. It was bouncing the rear off the ground and I have 500lbs of weights on the back between the liquid tire ballast, wheelweights, and 150lbs on the rear hitch
    JGO and geekhouse23 like this.
  5. Feb 26, 2022 at 4:40 PM
    #1065
    Steve Urquell
  6. Mar 4, 2022 at 6:05 AM
    #1066
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I used my 80V Greenworks Chainsaw to cut down and buck to size for our smallish fire pit (the rest for the burn pile) two nasty seedling cherry trees yesterday, one about 12", the other smaller, 8" or so. The first (light) 2A battery did OK. I have 5 other batteries, so I reached for the heavy 5A battery. Yes a bit heavy, but that e-saw did great. This is with stock bar and chain - which I can see have limited life, and the chain rollers are wearing quickly - chain is "stretching". I have the Oregon replacements ready to go soon.
    I have zero regrets buying this saw, just the batteries are expensive.
    JGO and Coolerman like this.
  7. Mar 4, 2022 at 9:57 AM
    #1067
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
  8. Mar 4, 2022 at 6:50 PM
    #1068
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Rocking a refurbished Husqvarna 435 16” the saw has been rock solid. Cut down this willow oak today using a bore cut for the first time, tree had a nasty forward lean. Dropped it exactly where I wanted it to go.
    Pablo8 and Steve Urquell like this.
  9. Mar 5, 2022 at 10:42 AM
    #1069
    ralfnjan
    ralfnjan Well-Known Member
    I bore cut everything over 10 inches. Safest way to go. After I learned the techniques I wondered how I ever survived the previous 20 years.
    Pablo8 likes this.
  10. Mar 7, 2022 at 5:48 PM
    #1070
    w.adventures
    Nowheresville, SC
    Anybody use the small Alaskan mill? Thinking about picking one up and using it with my husky 435 realizing I will probably need a bigger saw in the future.
    Looks like it requires a solid bar, any good 16” solid bars? Or am I just wasting my money at this point in time?
    Would be nice to get use out of all the poplar, white oak and hickory I have been cutting down. They are all less than 16” at the base.
    https://www.granberg.com/product/g777-alaskan-small-log-mill/
    edit: after going down the rabbit hole it looks like I will need a much bigger saw. Husky 460 would likely get the job done but a 395xp sure would be sweet!
    Double edit: looks like the 460 doesn’t make that great of a saw for milling. Just need to save up for a 395xp.
    Toyko Joe likes this.
  11. Mar 7, 2022 at 5:50 PM
    #1071
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I have a Kobalt 80V Chainsaw. Quiet, easy to use, auto-turn off.
    Pablo8 likes this.
  12. Mar 7, 2022 at 5:53 PM
    #1072
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Pablo8 likes this.
  13. Mar 8, 2022 at 5:03 AM
    #1073
    Toyko Joe
    Looks interesting, have you held it yet?
    My M18 has a totally different feel from my Stihls. I didn’t watch the video but does it list the chain gage size for the saw? If it’s 0.043 then it’s the very narrow chain. Still interesting vs the Stihl 271.
    If I was going to do it again, I would have bought the DeWalt DCCS620P1 and a Milwaukee battery adapter or a Ryobi One+ HP18v chainsaw. I don’t need a big chainsaw anymore and realizing that I usually just grabbed my MS192TC most of the time these other saws would have fit the bill a little more, but that’s just my personal experience.
    Pablo8 likes this.
  14. Mar 8, 2022 at 5:35 AM
    #1074
    Toyko Joe
    Just make sure you get a Ripping chain. My friend runs an Alaskan with his MS440, loves it.
    https://www.oregonproducts.com/en/products/forestry/saw-chain-families/ripcut/c/ripcut-sc-p
    https://www.granberg.com/product-category/alaskan-mill/bars-chain/granberg-pre-cut-ripping-chain/
    w.adventures[QUOTED] and Pablo8 like this.
  15. Mar 8, 2022 at 6:14 AM
    #1075
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    The Kobalt and Greenworks pro 80V batteries look very similar. Are they the same (never held one)? Heck are the products the same?
    EDIT: Nope different. Web search: https://duckduckgo.com/?t=ffsb&q=Kobalt+and+Greenworks+pro+80V+batteries&ia=web
    I love my Greenworks Pro 80V equipment. The saw weight is less balanced and definitely back heavy with the huge 5AH battery. But I just pop in a 2AH battery for lighter carry.
    Yesterday I sawed the base of a stump that was around 18"! The chain got VERY hot, but still did fine. This is with the 5AH battery, then I popped the battery out, put it my stick blower (I have the backpack blower as well) - I then used the blower as a bellows for my huge wettish burn pile. Made an induction hole, locked in the blower at a medium low blow, set it down and tended the fire while I tilled my garden plots. The heat was INTENSE in the glory hole. Glassified the dirt in any sod clods. Blower ran a LONG time (over and hour), then I swapped in a 2A, and so on. Nothing left of burn pile and hardly much smoke. Winning.
    Slashaar[QUOTED] likes this.
  16. Mar 8, 2022 at 7:20 AM
    #1076
    jowybyo
    Joe
    Baltimore, MD
    Yes I’ve used it. It’s a 0.050” chain.
    Pablo8 likes this.
  17. Mar 8, 2022 at 1:14 PM
    #1077
    Slashaar
    Josh
    Kansas City, MO
    I lost a nut off mine and need to go to the hardware store and get a replacement so I have issues with the chain falling off as the tensioner bolt loosens. I didn't check them before first use and that's probably when I lost the secondary nut. All user error, I've cut down several trees in my back yard along my fence line since my neighbor let his property go and all his trees grow over into my yard and kill my grass with the metric ton of leaves they drop. I've cut up quite a bit of firewood on several occasions and if I'm going on some unserviced roads I pack it along since I can charge it off the bed outlet if I need to, but the 6AH battery lasts a long while, so I doubt I'd even need to.
    EDIT: Thinking about getting one of these: https://www.lowes.com/pd/Kobalt-300-Watt/1003166408
  18. Mar 8, 2022 at 1:22 PM
    #1078
    Slashaar
    Josh
    Kansas City, MO
    https://www.smartfamilymoney.com/use-greenworks-batteries-kobalt-tools/ looks like the only difference is the plastic guide rails.
  19. Mar 8, 2022 at 2:16 PM
    #1079
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    FYI standard bar nuts fit. I have spares in case.
  20. Mar 8, 2022 at 2:17 PM
    #1080
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
