What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. Nov 1, 2022 at 8:05 AM
    #1221
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I wish it was that easy. I have since segmented it up into about 4 ft pieces since that was about as much as I could muster to roll out of my back yard. I had a beetle kill oak fall down that had a rotten base which landed on my fence and metal gazebo. It was a giant pain in the ass to clear up but now its behind my property and as the saying goes, out of sight out of mind. I'd still like to get it cleaned up. With the burl on it and its odd shape and width at most the widest, I cant wrap my arms around it. I measured using two levels and got about 38" at the widest. Now where its resting is impossible to get a vehicle back there to move it. I'd have to tear down 2 segments of fence and my children's swing set to drag it to the street. I have neighbors on my left and right with a creek behind the property so no way to easily reach it through the forest. I guess pictures would help so here's when I started cutting it into manageable pieces.
    I'm at work so I'll have to check to make sure that link works when I get home since that site is blocked but according to my phone, that's the correct link. Anyway, I'd like to salvage the burl or at least slice it correctly. Fear not, I'm not about to make any rash decisions on that burl yet and it is still in tact. Hell, its been sitting back there for over a year since a deployment prevented me from doing anything with it and its back to 'out of sight, out of mind'.
    -J
  2. Nov 1, 2022 at 2:24 PM
    #1222
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ok you only need a 20" bar then to cut though it.
  3. Nov 1, 2022 at 5:29 PM
    #1223
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I had to make 2 cuts from opposing ends just to slice it into manageable pieces, there's no way I can slab it with a 20" bar. My 18" Poulan Pro gave up the ghost which resulted in me going out and buying the Husqvarna. The Rancher made quick work of it but still, Oak is a tough nut to crack. Unless you weren't talking to me specifically, I couldn't tell. I did fix the photo in my post though. That was after I took the top of the tree off. Just that slice you see there was 20". You can see that it widens as it gets closer to the burl to at least 36" at its widest. I was under the impression that Alaskan mills needed to be completely through the log since the oiler is attached to the tip of the saw blade. I figured I'd need at least 4" of extra saw sticking out the side so I guestimated 42" just to be safe.
    It doesn't have to be this one specifically, but this is what I had in my mind when I think Alaskan Mill. I know there are smaller ones without a secondary chain oiler. I could turn those slabs into tables and recoup the cost of the mill but Id rather not break the bank.
    -J
  4. Nov 20, 2022 at 6:21 AM
    #1224
    Glueboy
    Glueboy Well-Known Member
    2019 Cement TRD OffRoad DCSB
    Husqvarna 550XP
    Canadian Joe likes this.
  5. Nov 21, 2022 at 6:27 PM
    #1225
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Added a 16” light bar to the 261.
    born with a 20”, grew into an 18” and now will live as a 16. The 400 will be for bigger lumber. CFF67E87-3F2B-478B-A2E6-C5F20AE623FF.jpg
    Coolerman and Toyko Joe like this.
  6. Nov 21, 2022 at 7:16 PM
    #1226
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    16" bar on a 261 that thing must be a ripper!
  7. Nov 21, 2022 at 7:47 PM
    #1227
    jester156
    Cumberland, RI
    I’ll let you know when I have time to retune and get into it.
  8. Nov 22, 2022 at 12:56 PM
    #1228
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I've got a 20" on my ported 026 and it does just fine but one of these days I'd like to throw an 18" bar on there.
    jester156[QUOTED] likes this.
  9. Nov 26, 2022 at 9:48 AM
    #1229
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    The light bars are super nice! I put a light 20” on my 261. I guess the thin kerfs are starting to catch on. Overseas they’re really popular.
  10. Jan 15, 2023 at 3:17 PM
    #1230
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Well the 046 performed well today. Yesterday I climbed 70’ up to limb and set a cable. Today we took it down. The old growth cedar was 100’ tall and 18’ in circumference. That is 69” in diameter. I’m running a 28” bar with a skip tooth. So I had to get to the sweet spot of 14.5’ in circumference for a 55.5” diameter. That was about 9’ off the ground. Built a scaffold around the base. But still had to cut at shoulder level. Double cut the notch and the back cut. Went right where I told it to go. Even jumped the scaffold. Will send three 25’ sections to the mill and will end up with a cord of limb wood to sell for firewood. Stay Well…Stay Safe
  11. Jan 15, 2023 at 5:39 PM
    #1231
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Nice work! Do you usually run your chain that loose?
  12. Jan 15, 2023 at 5:49 PM
    #1232
    Pointeman
    Mark
    Thanks. No…Picture was taken just after getting it in the ground. It was a new chain after 30 minutes of cutting at shoulder height and in all kinds of opposing angles. Slack was tightened for next tree though.
  13. Jan 15, 2023 at 9:20 PM
    #1233
    w.adventures
    Nowheresville, SC
    What is the best way to get into climbing trees? YouTube videos? Don’t really have any time to apprentice with anybody. Also don’t really have any need other than it looks like fun.
  14. Jan 15, 2023 at 9:31 PM
    #1234
    Pointeman
    Mark
    Great question. I worked for Davey Tree for several years while living near Yosemite National Park. We were responsible for maintaining the clearance near the power lines. I worked my way up from groundsman to climber. Learned from some great climbers. It’s very technical and lots of room for things to go horribly wrong. Sometimes you can find classes or logging jamborees where they will give you the opportunity to try it out. Maybe check out a local tree service to see if they would be willing to let you try it out using their gear. Good luck…be safe.
    w.adventures[QUOTED] likes this.
  15. Jan 15, 2023 at 9:40 PM
    #1235
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d definitely want to have a mentor.
    I have worked with a tree company a few times when they were down a man or 2.
    (It’s a friends business).
    I don’t climb. But there’s more to it than climbing.
    Knots, equipment, rope types, ect.
    The type tree you are climbing, where to tie off, and even where you place your equipment.
    It’s a dangerous job. Things can go wrong fast.
  16. Jan 15, 2023 at 9:46 PM
    #1236
    Pointeman
    Mark
    This is the truth.
  17. Jan 26, 2023 at 10:50 AM
    #1237
    jester156
    Cumberland, RI
    Added some new teeth to the 400.
  18. Jan 27, 2023 at 11:58 AM
    #1238
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Currently :
    Stihl: 661 R MTronic, 661R standard carb, 462R standard carb, 461R standard carb, 362 standard carb, 261 standard carb, 193T & 194T
    Husky: 395, 576, 350 with ported 346 top end
    Sold the 500i last year
  19. Jan 27, 2023 at 12:43 PM
    #1239
    StihlToyota
    Mark
    No. Idaho panhandle
    M Tronic 661R, my guess is 15-20 hours on the saw
    That metal didn't seem to damage the chain much after inspection.
    Sometimes you get lucky & other times it's a short day if no back-up chains
    Box wedge food
    jwctaco likes this.
  20. Jan 30, 2023 at 3:34 PM
    #1240
    StihlToyota
    Mark
    No. Idaho panhandle
    Looks a bit like the 572
    web pic, not my saw
    jwctaco likes this.
