What Chainsaw do you run?
Discussion in 'Garage / Workshop' started by AgMechTacoma, Feb 4, 2014.
  1. May 6, 2023 at 7:09 PM
    #1341
    23SR5
    23SR5 Active Member
    Murray
    2023 Silver SR5
    Will be morphing it into my semi retired work truck
    Not exactly a chainsaw but this is thinning the pine plantation that we are part owners of .
    As I only run a tank of gas through a saw once a week on average cutting firewood have gone from a Husky 61 white top I bought with my dad when I was 18ish to a Makita 6100 . The Husky died 2 years ago , I am now 62 and I only drove the tractor over it once . Both companies are owned by Electrolux i believe .
    KWB17 likes this.
  2. May 7, 2023 at 8:12 AM
    #1342
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    "neccessary" is a subjective term, but I like toys.
    If I pick up an MS400, I would likely put a 28" or even a 32" Sugihara lightweight bar on it. I believe in long bars. Stand up and buck.
  3. May 7, 2023 at 5:18 PM
    #1343
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Can’t argue that. Buckin Billy Ray approves
    word of caution, upgrade the oiler if you put a bar over 25” on it, common issue with the 400. Z
    There are videos on swapping parts with the current ot buy a whole oiler for $100
    KB Voodoo[QUOTED] likes this.
  4. May 14, 2023 at 7:49 AM
    #1344
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Needed the grapple on the big Vermeer to help get the 200T out
  5. May 14, 2023 at 7:51 AM
    #1345
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Looks like a hard pinch!!
    StihlToyota[QUOTED] likes this.
  6. May 15, 2023 at 5:04 AM
    #1346
    ralfnjan
    ralfnjan Well-Known Member
    Where was your backup saw? I work on my own with 2, with the soninlaw with 4. Out of gas, grab another saw. Dull, grab another saw. etc etc
    wayupnort and Stelcom66 like this.
  7. May 15, 2023 at 5:28 AM
    #1347
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I bring two minimum, sometimes three.
  8. May 15, 2023 at 9:23 AM
    #1348
    StihlToyota
    Mark
    No. Idaho panhandle
    And with a back cut too
  9. May 15, 2023 at 9:26 AM
    #1349
    StihlToyota
    Mark
    No. Idaho panhandle
    Three other 200Ts and a first gen 201T which is a PITA for limbing running a 14" bar. The 3rd gen CM 201s are much better.
  10. May 15, 2023 at 10:03 AM
    #1350
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I have a Husqvarna and a Poulan 18". Been using the Poulan lately. Been having trouble with the Husqvarna stalling, even after the tune up kit so transferred the new spark plug to the Poulan.
    A few weeks ago bought an EGO 16", 56v battery for quick/brief cuts. Brought that and the Poulan to cut a downed tree in someone's yard. I was surprised that my 2.7L Tacoma did pretty well with the load, although it took 2 trips.
  11. May 15, 2023 at 10:24 AM
    #1351
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Little saws are about worthless for limbing. My favorite limbing saw is a MS362 with a 24" Sugihara bar.
  12. May 16, 2023 at 6:12 AM
    #1352
    StihlToyota
    Mark
    No. Idaho panhandle
    My arborist friend has used 200Ts for the last 23 years for limbing up to 12 " diameter, so don't agree with ya there.
    A lot less fatigue & in tight brush much better than longer bars; and it frees up a hand.
    His 200Ts are Not stock
    I never use anything longer than a 20" when limbing, much more agile; and many times an 18" bar will do just fine.
    Besides, very little limbing when the tree is on the ground. The grapple does the work feeding the chipper , up to 20" thick.
    Time is $, the less touches the better
    wayupnort likes this.
  13. May 16, 2023 at 6:36 AM
    #1353
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I prefer reach and power when limbing. Top handle saws are for climbing and nothing else, their ergonomics don't work on the ground.
  14. May 16, 2023 at 7:25 AM
    #1354
    StihlToyota
    Mark
    No. Idaho panhandle
    Using a long bar in heavy brush is nutty
    But you're obviously a pro ...
  15. May 16, 2023 at 9:03 AM
    #1355
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Give it a try sometime, you might be surprised. The smallest saw that I'll use to limb is a 50cc with a 20" bar.
  16. May 21, 2023 at 5:30 PM
    #1356
    WA7
    WA7 Well-Known Member
    Craig
    PNW
    2021 Trail Edition
  17. May 27, 2023 at 12:04 PM
    #1357
    StihlToyota
    Mark
    No. Idaho panhandle
    395 w/24
    KWB17 likes this.
  18. May 27, 2023 at 12:34 PM
    #1358
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    How do you like it with a 24” bar? Thinking about picking one up for mine.
  19. May 27, 2023 at 3:30 PM
    #1359
    jester156
    Cumberland, RI
    MS400 and 261 made quick work of felling limbing pines.
    Limbed and chipped.
    StihlToyota likes this.
  20. May 27, 2023 at 3:34 PM
    #1360
    StihlToyota
    Mark
    No. Idaho panhandle
    Easier to maneuver than the 28 or 32
    Unless the wood is 3 ft thick I normally always use a 24 on the big Hooskie
