What clear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by inesshell, Nov 15, 2011.
  1. Nov 15, 2011 at 12:21 PM
    inesshell
    inesshell [OP] blah blah blah
    All stock Superwhite 10' AC
    Finished the grill last week after a repaint since the first clear yellowed the white. Im debating of adding a clear but wasn't sure which brand to use that wouldn't cause this? Super white is a bitch to match and i want to prevent another strip down.
    thoughts on any rattle can clears would be great.
    Thanks guys.
    Bennett707 likes this.
  2. Nov 15, 2011 at 12:32 PM
    T A C O M A
    T A C O M A Well-Known Member
  3. Nov 15, 2011 at 12:40 PM
    Aw9d
    Aw9d That one guy
    did you rattle can this bumper or just wanting to use rattle can clear? If you did rattle can the bumper, what paint did you use and how well does it match up?
  4. Nov 15, 2011 at 12:53 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    OP, how long did you let the paint cure before clear coating. I have no experience in this, however, it seems I've read on this site that you'll have better results if you let the paint cure out completely. Some paints take as long as a month. Rattle cans don't have the same hardeners as body shop paints do. Remember also, enamel over lacquer is OK, but not lacquer over enamel.
  5. Nov 15, 2011 at 4:39 PM
    inesshell
    i use the duplicolor superwhite. i believe its acrylic and its been curing for at least a week now.
  6. Nov 15, 2011 at 4:52 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    I used rust-olium pait for plastic clear and had no problems with it.
  7. Nov 15, 2011 at 6:44 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Unfortunately most rattle-can clears cause yellowing. I've never seen one that doesn't... Might want to consider getting a body shop to clear it for ya. Should be cheap, MUCH better clear, and it won't yellow. Even get them to throw some flex-addative in there, so it's extra durable!
  8. Nov 15, 2011 at 9:44 PM
    inesshell
    ^^ ill look into all considerations thanks.
  9. Nov 16, 2011 at 6:28 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Rattlecan 040 duplicolor and duplicolor clear.. Let it dry in the sun for 21 days hit it with light wet sandpaper (600 grit) and put on the clear. 4 mo in the Fla. sun and it looks good so far...Jim[​IMG]
