What coil overs/struts should I get for my 253k truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Nov 21, 2024.
  1. Nov 21, 2024 at 1:04 PM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Value and quality is what I’m trying to weigh out here. Gabriel is the lowest I’m willing to go at 67 a piece. Kyb is like 123, which is pricy as hell. Are Gabriel’s junk? I just want my truck to not feel like complete shit when I hit a bump. Any insight or suggestions would be greatly appreciated. I always get the best advice on this site.
  2. Nov 21, 2024 at 1:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Bilstien 4600 would be a good upgrade.
    DRAWN and Clearwater Bill like this.
  3. Nov 21, 2024 at 1:27 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Man those are expensive af though. Ya I’ve put those on a blazer back in the day. I was hoping to get a deal on some from a lift fudd on marketplace, but Pickens are slim on there.
  4. Nov 21, 2024 at 1:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    Better look again. Check Amazon.
    WPDAWG11[QUOTED][OP] likes this.
  5. Nov 21, 2024 at 1:29 PM
    TnShooter
    Deogee
    STOCK
    I'd go with KYB over Gabriel or Monroe.
    KYB makes pretty decent stuff.
  6. Nov 21, 2024 at 1:32 PM
    TnShooter
    Deogee
    STOCK
    Yeah, I'm seeing a set of for for $315-$365
    Not too bad.
    Unless OP is talking about the coil assembly?
    Which includes springs and new mounting hardware?
  7. Nov 21, 2024 at 1:39 PM
    TnShooter
    Deogee
    STOCK
  8. Nov 21, 2024 at 1:48 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Ty for your suggestions fellow volunteer. I will do this. Ya I’m looking for the whole assembly. I put a remanned engine in last year which has given it more life, but it’s definitely not OEM. Now I’m just looking for bargains rather than sinking tons of cash into it.
    TnShooter[QUOTED] likes this.
  9. Nov 21, 2024 at 1:53 PM
    TnShooter
    Deogee
    STOCK
    If you don't wheel it.
    KYB will work.
    The 5100 kit doesn't come with springs. So you'd need to go to 6100's.
    And the are going to cost a good bit more.
    Monroe isn't bad. But they are a minimum for me.
    I'd rather have KYB. I ran them back in the day when I was fooling with Honda cars.
    Never had an issue.
    Gabriel is better than a "busted shock".
    If you can't afford anything, it is "ok".
    If you can afford something else, I'd suggest something else.
  10. Nov 21, 2024 at 2:10 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Gabriel’s are more expensive than the Monroe’s which has me confused. They are 94 where where the Monroe’s are 67
    Will I have to do an alignment after I do this?
  11. Nov 21, 2024 at 2:41 PM
    TnShooter
    Deogee
    STOCK
    Maybe.
    You may have to loosen the lower control arm bolts to get the assembly out. And that will affect alignment.
    You might be able to pry down on the control arms enough to get them out. You’ll just have to see.
    SethM and WPDAWG11[QUOTED][OP] like this.
  12. Nov 22, 2024 at 11:06 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    I just stepped on the LCA my coilover dropped right out, didn't want to mess with my alignment
  13. Nov 22, 2024 at 1:08 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I just went through the same thing in rebuilding a gen 1 Tacoma on a budget. I went with the KYB Gas-Adjust. No regrets.
    TnShooter likes this.
  14. Nov 24, 2024 at 9:17 AM
    TacoTuesday1
    FL
    If you want value and quality 6112/5160 is probably the minimum of that realm.
    that is why they come stock on some vehicles and people still upgrade from there.
    many vehicles nowadays come standard with shock reservoirs.
    A shock without a reservoir is not going to be better than one without.
    my 6112/5160 leaves stuff to be desired. But at this point I am not a software engineer at Google so I cannot justify higher than that, nor do I feel like I would get dollar for dollar smiles per dollar if I was to spend more on better. There is better.
    better would probably be rear relocate and Fox 2.5 adjustable of some sort.
  15. Nov 25, 2024 at 6:14 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Even though sellers have grown hip to selling take-off suspension and the price has gone up, you can still find very low mile 3rd gen Tacoma take-offs for relatively cheap. Years ago when I did our 2006, I got a set of nearly brand-new take-off coilovers and shocks for $150. Even if the price has doubled (and in most cases, it has), it's not a bad deal for a budget build. Or higher end suspension often shows up in the classified section here if you're patient.
    Rob MacRuger likes this.
  16. Nov 25, 2024 at 10:03 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    But third gen shocks won’t work on my second gen.
  17. Nov 25, 2024 at 11:49 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    That might be the case if you had a 5-lug (not 100% sure). Your profile says 4x4, so you have a 6-lug. They will fit. Virtually no difference between 6-lug 2nd & 3rd-gen frames/suspension.
    DesertRatliff likes this.
