What coilovers give the best ride quality?
Discussion in 'Suspension' started by DevL, Jul 29, 2010.
  1. Jul 29, 2010 at 11:12 AM
    DevL
    DevL [OP] Well-Known Member
    I have researched and researched... what coil overs give the softest and most compliant ride with 2.5" of lift. Or will they all be the same at that level?
  2. Jul 29, 2010 at 11:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    King, Fox, Sway-A-way, etc, use a Progressive dampening, and will be a little softer on the road, while Icon uses a Digressive dampening, and may be more firm on the road, but softer on the bigger hits.
    0210 likes this.
  3. Jul 29, 2010 at 5:15 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    the stiffness of the CO will also depend on how much preload (lift) you have on it.
    if you set it at 2.5" and it's too soft or stiff you can adjust the preload to change the ride quality
    i've only ran Icons, so i only have experiance with them, but both sets of my Icons have been great shocks, took all the abuse i threw at them in the dirt and rode great on the trip home.
    they are great shocks
  4. Jul 29, 2010 at 5:26 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I've got Fabtech's on my Taco, and I have absolutely no complaints with the ride. They're set at ~3" of lift, and still ride nice on the hiway, and even nicer off road!!
  5. Oct 28, 2016 at 1:02 AM
    12345 1st time taco owner
    Wahiawa 96786
    2013 v6 2wd
    K&n intake/borla
    I have fabtech 3inch coilovers and they ride stiff. how can I soften it.
  6. Oct 28, 2016 at 7:10 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    Have them revalaved
    How much preload do you have on them?
