What coils to get to achieve between 2.5-3 inches of lift with 5100 set to 0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMGARCIA31, Apr 2, 2018.
  1. Apr 2, 2018 at 3:41 PM
    JMGARCIA31
    JMGARCIA31 [OP] Well-Known Member
    Luis
    Jacksonville, NC
    2015 silver trd offroad dcsb 4x4 auto
    5100's @2.5 and add a leaf. 255/80R17 Cooper ST Maxx.
    Currently running 5100's set at 2.5 with stock coils and ride is rought. trying to get around the same height or more with new coils. Have heard of eibach and ome coils just not sure which ones to get. I need some help. Pictures of stance would also help.
  2. Apr 2, 2018 at 4:07 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Ome 887s
    ChadsPride, REDdawn6 and Benzdriver81 like this.
  3. Apr 2, 2018 at 4:08 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    x2 for 887s.
  4. Apr 2, 2018 at 4:13 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Yup 887's it is.
  5. Apr 2, 2018 at 5:13 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Or the ToyTec Eibach 2.5” coil
  6. Apr 2, 2018 at 5:16 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Eibach 2.5”
    REDdawn6 and BassAckwards like this.
  7. Apr 2, 2018 at 5:16 PM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    887s
  8. Apr 2, 2018 at 6:51 PM
    baodown
    baodown Well-Known Member
    13 DCSB 09 600RR 15 Aprilia RSV4
    3" with OME 885s because mine is a prerunner :)
  9. Apr 2, 2018 at 8:53 PM
    Pigpen
    Dan
    Northwest Montana
    I put on 885s. Then I ended up putting spacers over them to get to 3". If I was doing it again, I would get 887s.
  10. Apr 2, 2018 at 8:56 PM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    887s set at 0 are supposed to get 2.75" on a second gen.
  11. Apr 2, 2018 at 9:00 PM
    Pigpen
    Dan
    Northwest Montana
    That's an "average". Body style, 4x4/2x4, v6/I4, armor, tools, etc will all change the amount of lift from a given spring. My Access Cab is heavier than most DCLB Tacos out there. Unless comparing bone stock trucks to each other, each one will be a little different.
  12. Apr 2, 2018 at 9:03 PM
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    The "supposed to" was for a truck with no extra weight and also was an average. Every truck will be a little different.
  13. Apr 2, 2018 at 9:34 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    That softopper is awesome!! Love it.. Truck looks great
  14. Apr 2, 2018 at 10:04 PM
    Chase8059
    Chase
    ESVA
    Thanks! It's one of my favorite purchases for the truck.
    ChadsPride likes this.
  15. Apr 3, 2018 at 2:48 AM
    JMGARCIA31
    Luis
    Jacksonville, NC
    How's the ride quality with 887s and eibach 2.5"?
  16. Apr 3, 2018 at 3:15 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I got about 2.75" lift with 887's and 5100's at 0, ride quality was better than stock to be sure, after a little beating on my truck and carrying a full set of underbody skids full of dirt they started to sag, I moved them up to notch 1.
    If they start sagging again I'm going to 886's as a quick fix. Ultimately I need true blue coil overs but that's got to be down the road some.
  17. Apr 3, 2018 at 5:55 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
