What Combination Fixed Your Driveline Vibs
Discussion in 'Technical Chat' started by 4milestogo, Sep 12, 2010.
  1. Sep 12, 2010 at 8:29 AM
    4milestogo
    4milestogo [OP] Well-Known Member
    North East, Indiana
    2005 DC SR5
    885's, 5100's, Toytec top plate spacers, LR UCA's & 2"' AAL, black two tone, debaged, BHLM, smoked taillights, smoked lamin-x fogs, Grillcraft upper & lower, afe CAI and Dynomax SS cat-back.
    I've been researching all possible fixes for driveline vibration at take off after a 3" lift is istalled. I would like to know what combination of parts fixed your vibration problem.
    What worked best 2,3 or 4 degree shims, CB drop, onepeice driveshaft or any combination there of?
    I have the CB drop with no real differece noticed and will purchase any of the parts that will fix this condition but I would like to do it once... with some perdictibility of success.
    Help a brother out:)
  2. Sep 13, 2010 at 9:06 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I put a 1/4 inch spacer and that seemed to work for me and go on the search and put driveline vib and there's a lot threads on this and hope that helped
  3. Sep 21, 2010 at 5:28 PM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
    I think I may have found my vibration! I have tried everything, cb drop, front diff drop, 3 degree shims, Etc. The cb drop made it worse! The 3 degree shim helped a little, but I noticed today that my drive line is not exactly inline with the flange on the rear of the tranny! I loosened the cb and shifted it to one side as far as possible to try and straighten the Driveline, drove the truck and the vib was at least 75% better! I am taking it to toyota this week to see what happened??? It vibrated as soon as I bought it, but after the lift it was horrible!
    So everyone with the Vib's check your driveline where it mounts to the rear of the transmission! My drive line was obviously not straight with the flange. When looking at the flange and the driveline, if there is a problem it will be obvious!
    Loosen and move the cb which ever way you need to, to make the driveline as straight as possible!
    I can't adjust mine any farther but it needs to go a little more-Here I come Toyota!
  4. Sep 21, 2010 at 8:58 PM
    BAMFTACO
    Juan
    Kings bruh
    Good luck and hope it gets fixed and post up any updates if it works out
  5. Sep 30, 2010 at 5:35 AM
    MAtrdguy
    MAtrdguy Well-Known Member
    Pete
    Western Ma ( on the lake) / Danvers N Shore
    06 Taco DC LB
    None YET
    I knowthis sounds crazy but mine seems to have gone away on its own ( 90% of it) its SO strange !!!
    I got on the gas pedal a few times 100+ mph and it seems to be a very slight buzz now.
    Had the stealership replace the motor mounts ( TSB) and it felt the same but got better over the week. They told me that the U joints were ok ( but I still have about 1/2 " of rotational play in it ( NONE in 4x4)
    I know they didnt take out the joints to inspect the, ..just wondering if the needle bearings are shot. ( I tried the CB drop..didnt do much)
    Another member on here replaced his with Napa heavy duty U jints and said that his truck drives great....
    I'm really getting tired of this BS....I'm tempted to go test drive an FJ and trade this Taco !!!
    I never had any of these mod issues with my Tundra...but i cant afford another tundra right now ( or in the near future).....
    any comments ??? ( I mean OTHER than flaming)
