What could bend a spark plug tab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gbeers, Sep 23, 2019.
  1. Sep 23, 2019 at 10:08 AM
    gbeers
    gbeers [OP] Member
    2007 Tacoma 4X4 V6 6 speed manual 152K miles. Tripped a P0305 Cylinder 5 Misfire. When i pulled the #5 plug the ground tab was bent over and just touching the center electrode. It didn't look smashed onto the electrode, just bent over causing a short. I re-gaped it and it runs good and the check engine light is off. However now there is a tapping noise coming from that side of engine like a valve tick at low RPMs and then I hear what sounds like a marble bouncing around in the cylinder but this noise only happens now and again. I did a compression test and it was normal 180psi. This just can't be good.
    b_r_o likes this.
  2. Sep 23, 2019 at 10:09 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    If you have access to a scope I'd pull the plug again and look in there.
    PzTank, SR-71A and whatstcp like this.
  3. Sep 23, 2019 at 10:16 AM
    gbeers
    gbeers [OP] Member
    Do you know if the cheap ones at harbor Freight are any good? Can you look up to see the valves as well?
  4. Sep 23, 2019 at 10:17 AM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Could be the 4.0 tick you hear, no?
  5. Sep 23, 2019 at 10:21 AM
    gbeers
    gbeers [OP] Member
    That is what I thought at first but random pops like a marble in the cylinder is way more that the "Taco Tick". Something bent that spark plug tab. I installed the plugs 15K ago and I would not have bent it over installing it.
  6. Sep 23, 2019 at 11:31 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did you change spark plugs not too long ago? If you are not careful feeding the plug down into the cylinder, the side electrode can get bent.
    If you heard the bouncing marble more frequently, I would wonder if something fell into the cylinder when you reinstalled the plug, but you say it happens occasionally.
    I also wonder if the "bouncing marble" is pinging?
  7. Sep 23, 2019 at 11:57 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Only time I seen that was on a 2 stroke string trimmer.
    A piece of carbon dislodged from the piston and messed up the plug tip.
    I'm not saying that is the cause of yours to be bent.
    It is just the only time I've seen it happen.
    PzTank, cruxofthebisquit and whatstcp like this.
  8. Sep 23, 2019 at 1:34 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    The motor has inhaled something....either internally or something you did when you changed plugs. Either scope it or send an extendable magnet into the bore. Ground electrodes don't bend by themselves.
    Cheers, jeff
    Da Boogie Man likes this.
  9. Sep 23, 2019 at 1:38 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If your ground strap was bent then expect to see damage in the combustion chamber of the cyl head . Something got sucked into the throttle body and into that cyl
  10. Sep 23, 2019 at 4:00 PM
    gbeers
    gbeers [OP] Member
    15K on the plugs, I'm very careful feeding them down the tube and always check the gap. I'm no expert on engine noises but it's more like a door knock than a ping. I'll borrow or get a scope and have a look inside. I made a video when it was making the random knocking and someone in work said it sounded like a worn wrist pin slapping around.
  11. Sep 23, 2019 at 4:06 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    US Marine is right on target. And I will add that whatever you are hearing bouncing around is possibly what has been sucked into the cylinder.
  12. Sep 23, 2019 at 4:06 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I would definitely scope it. Buy one, borrow one or rent one somewhere but I'd be ruling that out immediately.
  13. Sep 23, 2019 at 5:41 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Skyway and SR-71A like this.
  14. Sep 23, 2019 at 6:08 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I don't see how there could be anything bouncing around in a cylinder, he's been running & driving the truck. If there were something bouncing around in that cylinder, you'd already have a hole in a piston, bent, or burnt valve. They may be right, but my opinion, anything bouncing around inside a cylinder won't last even a minute, certainly not while you are driving around in it. Like I said, just my opinion.
    Sidney Vicious and SR-71A like this.
  15. Sep 23, 2019 at 7:07 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Nothing is bouncing around. If there ever was something it went out the chamber through the exhaust valve.
    Sidney Vicious likes this.
  16. Sep 23, 2019 at 9:17 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Or firmly embedded into the combustion chamber
  17. Sep 24, 2019 at 7:39 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Yeah, this doesn't sound good- something found its way into the chamber and bent the ground. Like many have said, they don't bend themselves. And now you have a knocking sound, so it's probably not a coincidence. Take a look at the throttle body for a missing screw
  18. Sep 24, 2019 at 2:31 PM
    Fullboogie
    Dave
    Houston
    I'm guessing a scope will show a piece of the ring land gone.
    AllenOne1 likes this.
  19. Sep 24, 2019 at 6:23 PM
    AllenOne1
    AllenOne1 Well-Known Member
    Allen
    Nashville, TN
    2013 TRD Sport / 2018 TRD Off Road
    Gen2: Access cab platform, Gen3: MESO Puddle Lights, KTJO Power Folding Mirrors,
    If it is a wrist pin when you rev up the engine and back off it will usually really rattle. You could have had a piece of carbon break off and bend the spark plug but it should have exited the exhaust port. Why it is an intermittent popping is the question. Better scope it and see if you can find anything. If something got in there and is bouncing around you will be able to tell in about 3 seconds when you put the scope down the hole.
  20. Sep 24, 2019 at 6:41 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    You should see what kind of damage Holley carb throttle plate screws can do and they're 8/32 ×.25 or even a holley bowl vent tube . I know because I had that happen to me
