What could bend a spark plug tab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gbeers, Sep 23, 2019.
  1. Sep 25, 2019 at 9:11 AM
    gbeers
    gbeers [OP] Member
    So the scope I used was cheap with poor resolution but I could not see any damage compared to the next cylinder and I didn't have a mirror to look up at the valves. I did stick a pivoting magnet in there as well and nothing came out. I need to remove the valve cover next and see what the valve train looks like.
    cruxofthebisquit likes this.
  2. Sep 26, 2019 at 4:54 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Detonation will do this.
    b_r_o and Lester Lugnut like this.
  3. Sep 26, 2019 at 5:19 PM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    :boink:Out of calibration computer operated machinery or you...
  4. Sep 27, 2019 at 9:52 AM
    gbeers
    gbeers [OP] Member
    I checked the gap on the valves on the #5 cylinder and one of them has a gap of 42mils. It's one of the intake valves which is supposed to be 6-10mils. That is way out of spec. The valve is not seating properly. It's time to trade this one in while it has a little value. This is a lemon Taco. 12 New England winters on the frame and I never qualified for a new one. New tires, clutch, calipers, rotors, ebrake cables ............... I am disappointed in this one. Not so bullet proof.
  5. Sep 27, 2019 at 10:08 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    If you have a questionable valve, a compression test is a must. I don't know how much trouble it will be for you, but I can't imagine not doing it.
  6. Sep 27, 2019 at 10:22 AM
    gbeers
    gbeers [OP] Member
    In my first post I did mention that I did a compression test and it was normal.
  7. Sep 27, 2019 at 10:54 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    If an intake valve is not seating, how can a compression test be normal? Not trying to argue but that makes no sense to me. :notsure:
  8. Sep 27, 2019 at 1:08 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Way too early to give up. Like CurtB said, if the compression is good, the valve is seating & sealing properly. I don't know how these valve trains work, are the adjustments made with shims, or do they have adjusters? maybe it isn't as bad as you think, just need to get it figured out..
    SR-71A likes this.
  9. Sep 27, 2019 at 1:12 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Stick a straw down there and suck it out
  10. Sep 28, 2019 at 4:31 PM
    Waasheem
    Waasheem
    2007 xrunner
    A friend had a no start 2 stroke bike, pulled the plug, metal chunks crammed all in the ceramic, broken piston skirt, but thats a 2 stroke. You could try, disable ignition, pull the one plug, crank the engine in hopes whatevers in there will blow out the plug hole. Maybe to be safe, also disable fuel pressure, pull the fuel pump fuse. Maybe put some cardboard above the hole so if it does fly out it won't cause damage to anything.
  11. Sep 28, 2019 at 6:32 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    I replaced my plugs at 60k and found the last one difficult to get the socket over it to remove. Found broken ceramic pieces from the plug down in the hole.
  12. Sep 28, 2019 at 7:14 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm with you on this one. If the compression test is good the valves are seating.
    SR-71A likes this.
