What could improve your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZachPrerunner, Aug 23, 2019.
  1. Oct 19, 2021 at 8:19 PM
    #261
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Full EV swap. Replace engine trans and t-case with duel electric motor. One unit up front with gear box attached and CV axles (like most ev s , find junk yard Tesla unit) the other Motor spins rear drive shaft to rear axle. Control front/rear motor speed split with electronic controller (AWD mode possible). No need to match gear ratios or even worry about re gearing or low range (due to basics of duel ev motor operation). 450 hp at least, 150 miles range , less bull crap , no gasoline or special oil filter wrench … all the pros of EVs but don’t have to wait for Toyota to make one .
    God mode would be 4 hub motors for each tire . No need for any cv joints or axles and no need for “lockers”/ traction control BS
  2. Oct 19, 2021 at 8:21 PM
    #262
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
  3. Oct 19, 2021 at 9:34 PM
    #263
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    Honestly I feel like the driving experience translates exactly appropriately to those numbers. 270ish hp/torque really isn’t a big number for a vehicle that heavy but it’s adequate and that’s how I’ve always felt about the power. It’s not fast but it’s not like I have any trouble passing on a two lane road either. My last post was just making a joke about how it feels slower than when I bought it after sticking a bunch of steel bits and big tires on it, it’s still fine.
    That said I have a manual and if the auto’s as dim witted as you all whine about I could see that making a big difference in how powerful it feels. That engine really doesn’t like being out of the powerband and if the auto is trying to keep you at low revs for fuel economy purposes it would feel really gutless.
    Yeah bet I need some fuel system cleaner, must not have anything to do with the steel bull bar, winch, sliders, skids, roof top tent, lift kit and tires with a few extra inches of diameter I put on over those years.
    vivid02 likes this.
  4. Oct 19, 2021 at 9:42 PM
    #264
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    Agreed!
  5. Oct 19, 2021 at 9:44 PM
    #265
    jmw2434
    jmw2434 Well-Known Member
    Verde Valley Arizona
    2016 QS TRD OR M/T
    Husky liners and Ruff Tuff seat covers
    I drive the manual too, 6th gear has been useful maybe 2% of the time over the course of the nearly 6 years I've owned the truck, 5th gear is useful less than 10% of the time. 1-4 works fine but having two overdrive gears where one is utterly useless and the other not much better is a failure of power. I took a road trip to Wyoming 2 years ago, the interstate speeds are 85mph up there over the rolling planes. It was everything the truck had to pull 65 on those highways.
  6. Oct 19, 2021 at 9:55 PM
    #266
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    $1.99 per gallon gas.
    Vmax540 and jmw2434 like this.
  7. Oct 19, 2021 at 10:02 PM
    #267
    jasmits1
    Yeah I agree on the gearing, the two overdrives are stupid, I drive on the highway a lot and I do use 6th a good bit on downgrades or dead flat but I use 5th more and there isn’t really a situation where 5th wouldn’t be totally fine. Would’ve been much nicer if they made 6th the ratio as what they did make 5th, made 5th direct drive and then made 1-4 closer ratio, that extra gear would really fill the big gap between 1st and 2nd. I love the short first as an off roader but such a big gap to second.
    I still don’t have that much trouble on hilly highways and I live in the Pacific Northwest and drive all over the western US so am no stranger to highways and mountains. Just drop down enough gears to get past 4000rpm, running near redline won’t hurt the engine.
    Edit:thought of what 6th is useful for. Getting the engine to the absolute lowest RPM that will keep it moving at 55 on the EPA’s highway test.
  8. Oct 19, 2021 at 10:03 PM
    #268
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    You might look into your rig.
    I recently drove across the Dakotas, Utah and Nevada. Lots of 75 to 85 mph. Not a problem with the MT 6 speed in top gear. Call it 2600 rpm.
  9. Oct 20, 2021 at 8:06 AM
    #269
    tarbal255
    Dave
    19 Taco SR
    LOL you didn't say you added another car's worth of weight to your truck. Then what are you complaining about it's probably running fine. Like my COVID weight I packed on. I'm slower but still the same old me, just better insulated!
  10. Oct 20, 2021 at 9:38 AM
    #270
    jasmits1
    I was joking, sarcasm didn’t come through I guess
    Junkhead and tarbal255[QUOTED] like this.
  11. Oct 20, 2021 at 9:43 AM
    #271
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  12. Oct 20, 2021 at 9:57 AM
    #272
    graybeard4x4
    graybeard4x4 Well-Known Member
    Andrew
    Aransas Pass, TX
    2018 TRD Off-Road 4x4 DCSB
    SB cold air intake, MBRP 3" cat back exhaust, Rigid Industries 360 series LED fog lights, 17" Method Racing 610 Con 6 wheels in matte black, BF Goodrich All Terrain TA tires, CaliRaised LED sequential turn signals, AlphaRex Pro Series LED tail lights
    How about a freakin grab handle on the pillar inside the drivers side door?
  13. Oct 20, 2021 at 2:42 PM
    #273
    suprataco
    suprataco Well-Known Member
    MARK
    SoCal
    2016 Blazing Blue 4x4 Sports DCLB
    1994 Supra Turbo 6spd
    Had my truck since 2016 and I never got anything above 21 mpg. Maybe all this crazy traffic here in SoCal..
  14. Nov 2, 2021 at 4:10 PM
    #274
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    I still don't understand this one. It's a very common complaint, so it has either been perpetuated to the point that people feel shamed if they don't share the same complaint, or I'm a 6'2" (175lbs) man who doesn't sense when he is being crammed into tight spaces. Are y'all bouncing up and down in your seats? Maybe you need better suspension or fewer bumps? Maybe don't have such good posture while driving? A little gangster lean perhaps? My last rig was an FJ Cruiser, so it's not like I upgraded from a hardtop mini cooper.
    Kronk21, Junkhead and Chicken_Taco like this.
  15. Nov 2, 2021 at 4:20 PM
    #275
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    That's too funny!
    Ed
    Junkhead likes this.
  16. Nov 3, 2021 at 7:34 AM
    #276
    tarbal255
    Dave
    19 Taco SR
    I felted cramped when I went from my 99 ranger I think because the seats and floor are lower. Just felt much more spacious where I had to watch my head getting into the taco. I'm used to it now but the first year or so it did feel funny and I'm short. 5'7"
  17. Nov 3, 2021 at 10:20 AM
    #277
    RTweet
    Oregon
    Yah, I think it really boils down to what people are used to. I have about 3" of headroom, which is fine. In fact, I prefer a compact for off roading and general drivability because it feels like an extension of myself without having to sacrifice the truck bed in favor of a car.
  18. Nov 3, 2021 at 3:07 PM
    #278
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I use 6th gear even when cruising 35-40 in the city. Picks up speed just fine, even goes up slight inclines. Not sure why you are having issues.
    Im running bigger C load all terrains too.
  19. Nov 3, 2021 at 3:09 PM
    #279
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Full Electric Taco. Imagine how fast it would be???? :burnrubber:
    SwollenGoat likes this.
  20. Nov 3, 2021 at 3:12 PM
    #280
    will701
    will701 Member
    Will
    2019 Cement Grey Tacom TRD Off Road
    Eibach Pro suspension lift, Wulf AAL, Nitro 5.29's, Fuel Shok 17x9's, Cooper ST MAXX tires
    I did 5.29's already because the stock gears are stuuuuuuuuuupid, but it would be nice to have a transmission tune that doesn't suck. That, or just put a manual in it.
