What could improve your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZachPrerunner, Aug 23, 2019.
  1. Aug 26, 2019 at 6:32 AM
    #61
    ecuarodz
    ecuarodz Active Member
    Josh
    Ocala FL
    19 Sr taco v6 4x4
    3" Lift and rims coming soon
    I can't toss anything heavy in the bed anymore :annoyed:
    It looks fragile instead of tougher. Something hot could melt, something heavy could crack it. My truck is a work truck :ballchain:
  2. Aug 26, 2019 at 7:16 AM
    #62
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    It's tough enough for farm stuff.
    T-posts, fencing, firewood, a freakin 1100lb Bush Hog...
    I'd have zero concerns dropping a loader bucket in there.
    High blood pressure?;)
    xxTacocaTxx likes this.
  3. Aug 26, 2019 at 7:21 AM
    #63
    StmbtDave
    StmbtDave Active Member
    Dave
    2019 Barcelona Red Tacoma Off-Road
    You know that's just a setting that's easily changed
  4. Aug 26, 2019 at 8:14 AM
    #64
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Front wells a little larger so you could fit a larger tire without a CMC, trimming, et al.
    More bottom end torque - my last truck had gobs of off-idle power (It also only got 10 MPG in the city)
    Full rear window roll down like the Tundra
    Tru-Trac type front locker
    Rear disc
    Apple/Android car play
  5. Aug 26, 2019 at 8:19 AM
    #65
    ZachPrerunner
    ZachPrerunner [OP] Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I will agree that the bed material could be better. I had a toolbox that ended up wearing down the black composite material. I feel like if it was bedlined it would meet my expectations.
    ecuarodz[QUOTED] likes this.
  6. Aug 26, 2019 at 8:33 AM
    #66
    TXnativeson
    TXnativeson Mmmmm tacos
    Alabama
    2019 TRD Sport DCSB 4X4 MGM
    This! So many times this! I live in the South where there are maybe 3 or 4 days below freezing. While heated seats are nice, I would only use them for a month total out of the year. Yet it has been above 90 everyday for the last 4 months with heat indexes in the 100’s. Cooled seats should be standard. Whether or not they are leather or fabric.
    Mikenewgun87, ancient11 and cwdog like this.
  7. Aug 26, 2019 at 9:41 AM
    #67
    ecuarodz
    Josh
    Ocala FL
    19 Sr taco v6 4x4
    Really? Ohh!
    you are going to make my day today! :cheers: how do I get that setting changed?
    I went to every screen I couldn't find it. It's annoying it stays for too long and they should have just done a small number in the corner to tell you the actual gear you are on
  8. Aug 26, 2019 at 9:47 AM
    #68
    TXnativeson
    Alabama
    It’s in the MID “multi information display “ in the center of the instrument panel scroll to the gear and go into settings, then pop-up display then unselect shift position.
    xxTacocaTxx and ecuarodz[QUOTED] like this.
  9. Aug 26, 2019 at 9:49 AM
    #69
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
    A long bed instead of a medium length bed. I don't mind the width, I can get by using the notches for the cross-bed supports. But I would really like to be able to close the tailgate when I carry a 4x8 sheet of plywood, without laying the plywood on top of the tailgate.
    Vmax540 likes this.
  10. Aug 26, 2019 at 10:38 AM
    #70
    ecuarodz
    Josh
    Ocala FL
    19 Sr taco v6 4x4
    don't it happens to you when someone shuts the door carefully never closes all the way and they have to slam it every time to close correctly?
    that's the air pressure trapped inside when closing, and having no vent to release it or a bad designed causes it.
    when you are driving and open the window, ever wondered where they air and the pressure goes to?
  11. Aug 26, 2019 at 11:15 AM
    #71
    MaTaco_4x4
    No, I don't wonder. Not about that.
    If the A/C dampers are shut, and the windows are up, and no other door is open, then a door should be difficult to shut because air pressure.
    If that doesn't happen then you have an air leak, probably a bad one. That's normal for a Ford, Chevy, or Dodge, but not for non-US vehicles. Finding a huge leak can be nearly impossible, too. If you don't find it, ya know what else happens? You get water, bugs, and mice in your $35k vehicle, then you get diagnosed with lung rot from the mold or haanta virus from the vermin, then you die.
    Try lifting some bricks or doing some pushups until closing a car door isn't so difficult that you pop a brain vessel fussing over it.
  12. Aug 26, 2019 at 11:18 AM
    #72
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    I second more telescoping wheel. I have short arms and mine barely moves close enough. Didn't they add vertical movement with the addition of power seats in the 2020? Shame they didn't include power seats before.
    cuda67, xxTacocaTxx and auskip07 like this.
  13. Aug 26, 2019 at 1:11 PM
    #73
    Mikenewgun87
    Mikenewgun87 Active Member
    Sparta, Wi
    19 Cement DCLB OR
  14. Aug 26, 2019 at 3:23 PM
    #74
    Rhinta
    Rhinta Well-Known Member
    2018 SR- double cab- auto- silver
    Firmer seats with more thigh support and CarPlay/Android auto. Entune is laughable.
  15. Aug 26, 2019 at 3:32 PM
    #75
    ecuarodz
    Josh
    Ocala FL
    19 Sr taco v6 4x4
    The vents have rubber filaments they are always closed, nothing comes in but air goes out, they basically work just like those manual oil pumps to suck it out the dipstick hole
  16. Aug 27, 2019 at 3:39 AM
    #76
    MaTaco_4x4
    Were you raised by lesbian badgers or something? What a foul natured little man. Go research dietary fiber supplements, because you need them.
    RH408RN likes this.
  17. Aug 27, 2019 at 4:45 AM
    #77
    ecuarodz
    Josh
    Ocala FL
    19 Sr taco v6 4x4
    I can give you a class in fitness culture as well buddy.
    Did you mean protein, by dietary fiber? That doesn't do much if you lack of testosterone to have it absorbed by your muscles. You Probably need more testosterone (what makes men more manly) :benchpress:we notice that excess of oestrogen in the way you write.
    What have you been doing all these years, other than masturbating, stop doing that, it lowers your self esteem and confidence:frusty:.
    Thread unfollowed (I won't get notified of a next reply :gossip:)
  18. Aug 27, 2019 at 4:51 AM
    #78
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I mean...you will if someone quotes you. Like this.
    RH408RN, cshrum, Littlemule1 and 2 others like this.
  19. Aug 27, 2019 at 5:01 AM
    #79
    MaTaco_4x4
    No, I mean fiber.
    You seem to be filled to overflowing with excrement. You're getting it everywhere. Fiber might help.
    How's that unfollow thing going?
  20. Aug 27, 2019 at 5:08 AM
    #80
    CamoColton
    CamoColton degen from upcountry
    Colton
    Oswego, NY
    2017 Inferno DCSB TRD OR 4x4
    Honda Ridgeline badges
    All of the 3rd gen owners to go back to Jeep JK's and Ridgelines.
