What dash kit comes with metal brackets?
Discussion in 'Audio & Video' started by hacklerjason, Mar 23, 2013.
  1. Mar 23, 2013 at 9:32 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Gotcha. I must have misread your post. Yeah when I install sat radio, if its a Sirius antenna I know that its MUST be installed on the roof with no exceptions otherwise reception will be horrible. XM antennas could be installed on the dash inside the vehicle, or sometimes even under the dash and still work OK. Sirius antennas suck big time. Putting an XM antenna on the roof is the best possible option. Right now my XM is on my dash opposite of the VIN# and it works great. I have a few bad areas such as the 10 freeway between Mountain and Grove but other than that its good. I eventually want to buy the tiny adapter to plug into the OEM antenna, but its like $70 which is ridiculous so that can wait.
  2. Mar 23, 2013 at 9:41 PM
    ProForce
    Anthony
    Alaska
    So I just checked metra website and all their kits are "textured" and mine is not, which makes me think if I have Scosche or Metra. Its been 4 years since I bought it and I remember the one I originally bought sucked big time so i exchanged it for the other one. Not sure which I ended up with, but mine is Silver, Double Din, Smooth, with the 4 indents across the top like OEM. Whichever one it is, it works great!
  3. Mar 23, 2013 at 11:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ahh... maybe I'll leave it where it is. Or maybe I'll temporarily run it out the window to the roof to see if it helps.
    I wouldn't mind retrofitting a stock sharkfin.
    Mine doesn't have the 4 indentations, but it does have the "pebble" texture like the stock HU.
    But your trim ring looks just like mine. That is attached to the wings and the HU and you can pull the cover and clock module separately, right?
  4. Mar 23, 2013 at 11:42 PM
    ProForce
    Anthony
    Alaska
    Yeah the fave of the dash kit (main silver part) clips onto the 2 mounting brackets (actually glues on) then the radio bolts into between the mounting plates and the clock just clips in. So basically if I remove the 4 10mm bolts behind the AC controls and pull the dash kit off, the radio comes out with it. I've seen guys who can take off the face of their dash kit while the radio is still bolted in using the 10mm's. Either they didn't assemble their kit correctly, or they used the factory metal brackets which is incorrect.
  5. Mar 23, 2013 at 11:45 PM
    hacklerjason
    hacklerjason [OP] hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    but can the oem brackets be reused without complications? i prefer the metal over the plastic
  6. Mar 24, 2013 at 12:01 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Sounds like maybe you do have the Scocshe kit.
    My main cover is separate from the trim around the HU and can be removed without removing the HU.
    The trim around the HU snaps (I glued) to the mounting wings. I can not remove the trim ring without completely removing the HU... it slides into the trim ring from in front and screws run through the wings into the HU.
  7. Mar 24, 2013 at 5:37 PM
    hacklerjason
    Ewa Beach, HI
    are those blue leds all throughout your console or a photo mishap?
  8. Mar 26, 2013 at 8:14 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Crappy cellphone pic, but here's my Metra.
    The entire face can be removed without pulling the HU.
    The trim ring around the HU is attached to the "wings" that secure the HU to the dash, and the ring can't be pulled off of the front of the HU.
    Edit: Better picture from a less crappy cellphone...
  9. Nov 16, 2013 at 1:19 PM
    ottonavigps
    ottonavigps Well-Known Member
  10. Nov 16, 2013 at 2:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The Metra kit is 100% plastic.
    "Wings" and HU bezel kinda' "puzzle" together with the HU, or I just epoxied the wings to the HU bezel.
    HU slips in from the front, bolts to the "wings", and bolts into the dash.
    The front surround that includes the clock/airbag module snaps in over the top, then the HVAC is reinstalled.
  11. Nov 21, 2013 at 12:05 AM
    tractng
    tractng Well-Known Member
    I have the 2012 Metra. I notice it vibrates (more like squeaking plastic) the loudest the first 10 minutes when I start to drive the truck I didn't use epoxy as somebody noted here.
    The left top side of the face (finishing trim) wasn't tight so I glued it using liquid nail so now its sort of permanent unless I want to buy a new kit. :mad:
  12. Nov 21, 2013 at 6:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I glued the "wings" to the inner bezel, but did not glue the inner bezel to the main panel.
    No squeaks or rattles... rock solid here.
  13. Nov 24, 2013 at 4:37 PM
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
  14. Nov 24, 2013 at 5:09 PM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
  15. Nov 24, 2013 at 5:48 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    Never heard of the AI. Scoshe uses steel mounts, Metra is plastic.
  16. Nov 24, 2013 at 5:50 PM
    #36
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    After a little more viewing from what I can see the AI is shit... I'm going with the scosche in high gloss pearl black cause it will match and has the metal brackets..
  17. Jan 16, 2020 at 4:00 PM
    #37
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    Just curious and had to bump this bubba. But will that glossy dash kit fit on 2nd gen Tacoma’s before 2012? (2005-2011). I like the gloss but didn’t know why I couldn’t find one for those years. Is the clock area diff shaped ?
