What dashcam are you running?
Discussion in 'Arizona' started by HandOfGod, Jul 24, 2017.
  1. Jul 24, 2017 at 7:01 PM
    HandOfGod
    HandOfGod [OP] Well-Known Member
    Tacoma TRD 4x4
    Stock
    I want to add a dashcam to my Tacoma and want to know what brand everyone here is running? I am concerned about the Arizona heat and how to mount the dashcam.
    I have done some research and I think the Street Guardian sg96665gc v3 is what I will be purchasing.
    https://streetguardian.info/sg9665gcv3
  2. Jul 24, 2017 at 7:16 PM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    The goluk t2 is super nice I just installed it on a buddies truck
    HandOfGod[OP] likes this.
  3. Jul 24, 2017 at 7:18 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
  4. Jul 25, 2017 at 7:10 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Why do you need a dash cam???
  5. Jul 25, 2017 at 7:12 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    HandOfGod[QUOTED][OP] likes this.
  6. Jul 25, 2017 at 7:14 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    HandOfGod[OP] and IronPeak like this.
  7. Jul 28, 2017 at 11:11 PM
    Deet
    Deet Well-Known Member
    Tracy, CA
    2016 White TRD Off-Road 4x4 DCSB
  8. Jul 29, 2017 at 7:14 AM
    starforsaken
    starforsaken Well-Known Member
    Star
    Tucson, AZ
    2015 MGM DCSB OR
    I have the sg9665gcv3 and quite like it. I wired it so that if the truck is on, the cam is on. I have it tucked behind the rear view mirror and I largely forget that it is even there.
    I don't have an account any where to be able to upload video, but I do have a screen cap of a cow running out in front of a motorcycle. (Biker locked it up and the collision was avoided, both went their merry ways.)
    I was also worried about the heat, but I haven't had any issues with it being in the sun all day (I've had it for about 9 months.)
  9. Jul 29, 2017 at 10:03 AM
    Deet
    Tracy, CA
    All memory cards are very slightly "damaged" every time they get written to, or read from - Just the nature of the beast, so they all have a finite lifespan. And at the rate dash cams write data to those things, they need to clear their little skulls every so often. Most manufacturers recommend formatting the card at least every 30 days. You've got a nice little camera and I'm guessing that the camera itself can format the card for you without having to remove it. Give that a try and see if your camera cooperates again.
    These cards are specifically designed to better withstand the beat-down that dash cams constantly issue to memory cards;
    https://www.amazon.com/gp/product/B01BDKTRAE/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
  10. Jul 29, 2017 at 10:05 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  11. Jul 29, 2017 at 10:09 AM
    Eff3ction
    Eff3ction Well-Known Member
    Troy
    '11 TRD OR DCSB
    blackvue dr490l-2ch.
    i wanted a screen, and it has auto battery monitoring without needing the external kit while in parking mode.
  12. Jul 30, 2017 at 12:42 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    What's the difference between a dashcam and a gopro?
  13. Jul 30, 2017 at 12:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dash cams turn on and start recording automatically when you turn the car on, and turn off when you stop driving. They also overwrite themselves, so you never have to worry about it. Set it up once, and forget about it.
  14. Aug 12, 2017 at 5:07 AM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    also for arizona, make sure to get one with a capacitor not battery operated (which will explode and die)
  15. Aug 12, 2017 at 2:42 PM
    Oppositeboy
    Oppositeboy Well-Known Member
    AZ
    I've got a Street Guardian. I wired it up high (right in front of the rear view mirror), but need a shim or something since the power cord doesn't seem to fit right and I don't get steady power. This was most likely my fault on the install, and probably not due to manufacturing. I really liked it until the adhesive stopped working when it started warming up. I will have to find another mounting solution or something.
    I did like it, especially with the filter. Looking forward to getting it back in action.
  16. Aug 28, 2017 at 7:43 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    I did the Blackvue dr470-2ch with hardwire and GPS module. Works well. Once the newness wears off not having the wifi access is fine for me. Def get a capacitor model, and don't cheap out on the SD card. I've eaten a 128Gb SanDisk already. The rear cam is surprisingly interesting.
    cytocycle likes this.
